Add and configure maps
Maps are a critical step of creating stories in ArcGIS StoryMaps. Maps provide geographic context and broaden the reader's perspective by allowing them to interact directly with location-based data.
Create express maps
Express maps are basic maps that you create directly in the ArcGIS StoryMaps builder. Use them to provide geographic context by quickly creating reference, locator, pushpin, or other types of maps. With express maps, you can draw features such as points, lines, and areas, and add pop-ups and annotations to complement your features.
Use the following steps to create an express map:
From the map browser, click Create express map to open the map designer.
Add features to the map by selecting drawing tools from the express map drawing toolbar.
As you draw features on the map, they are also added to the map layers side panel. Drawn features of the same type are grouped into a single layer, and you can add information to each feature's pop-up in the side panel.
You can delete map layers and features from the map layers side panel or by selecting the feature and dragging it to the recycle bin.
Express maps are integrated with the builder’s themes. Changing the theme automatically updates the express map's basemap and symbol color. You can also customize the color of the drawing features by choosing an accent color from the design panel. For more information, see Set a theme.
Optionally, add information to pop-ups.
In the map layers side panel, the following information can be added to feature pop-ups:
Image or video
For more information about the file types and sizes that can be used, see FAQ: What media file types and sizes are supported in ArcGIS StoryMaps.
Name
Optionally, change the color and style of the drawn features and annotations.
Assign a new layer color to a group of points, lines, or areas. In the map layers side panel, click the layer color dot next to the name of the feature group and select one of the accent colors.
In addition to the three theme accent colors, you can select a custom accent color if one has been set in the design panel or add a hexadecimal code to the Custom color field.
Change the color or line stroke for text annotations and arrows. Select the annotation or arrow to open the Annotation style options, and choose a color and line stroke for the feature.
Change the map options as needed.
Click Done.
Your express map is added. To make updates and revisions, click the Edit button on the map toolbar to return to the map designer.
In stories, you can change the size and placement of express maps using the toolbar that appears when you hover over a map. You can display the map in a small, medium, or large frame. The float option offsets the map to the side and allows text to wrap around it.
Express map drawing tools
The express map drawing toolbar contains the following tools:
Actions
Select—Click a drawn feature or annotation to select it. You can modify the position, points, pop-up, and styling of a selected feature or annotation.
Group Select—Draw a bounding box with Group Select to select multiple drawn features and annotations at the same time.
Undo—The Undo button only works in the current editing session.
Redo—The Redo button only works in the current editing session.
Points
Points—Press the Shift key to add multiple points at once.
Numbered Points—Press the Shift key to add multiple numbered points at once.
You can select an image as a point symbol and change the size of individual point symbols. You can also change the color of individual features for points, lines, and areas.
Lines
Lines—Click to draw line segments and double-click to complete the line. After a line has been drawn, you can modify it by pressing Ctrl to bend the midpoint of a line.
Freehand Lines—Click and drag to draw a line with the pointer. Release to stop drawing.
Areas
Areas—Click to draw the boundary of the area, and double-click to close the area. After an area has been drawn, you can modify the position of the area or points in the boundary by clicking and dragging them.
Freehand Areas—Click and drag to draw an area with the pointer. Release to stop drawing.
Circle—Click once to draw a circle, or click and drag to draw an oval. Release to stop drawing. After a circle or oval has been drawn, you can modify its position or its points by clicking and dragging them.
Square—Click once to draw a square, or click and drag to draw a rectangle. Release to stop drawing. After a square or rectangle has been drawn, you can modify its position or its points by clicking and dragging them.
Annotations
- Annotation—Drag the handle to draw a leader line that can snap to drawing features.
Arrows
Arrow—Click the start point and endpoint for the arrow line. After an arrow has been drawn, you can bend the line by dragging its midpoint.
Two-headed arrow—Click the start point and endpoint for the two-headed arrow line. After a two-headed arrow has been drawn, you can bend the line by dragging its midpoint.
Express map features can be added in groups. You can create up to 10 groups, and each group can have a combination of point, line, and area features. You can change the group style, rename the group, or delete the group. Express maps are specific to the stories in which they are created. They are not added as separate items to your ArcGIS content, they cannot be shared between stories, and they cannot be exported or edited outside of the builder.
Express maps in ArcGIS Enterprise
In the ArcGIS Enterprise environment, express maps use basemaps from ArcGIS Living Atlas. Alternatively, you can use a web map in the Web Mercator projection as a basemap. For more information, see the Options settings in step 5 above.
Express maps will continue to be available in the builder even if access to ArcGIS Living Atlas content is disabled in your ArcGIS Enterprise portal. In this case, the express map basemap will appear from the selected group in the basemap gallery if the default basemap is in the Web Mercator projection.
If the default basemap is not in the Web Mercator projection, you must select a web map as a basemap from your content, favorites, groups, or organization for the express map. For more information, see Configure ArcGIS Living Atlas content.
Add web maps and scenes
Use the following steps to add a web map or web scene to an ArcGIS StoryMaps item:
From the map browser, click the web map or web scene you want to add.
The map designer appears.
Configure the map or scene.
Set the extent or viewpoint manually or by choosing a bookmark (for web maps) or slide (for web scenes). Additionally, you can configure how the map or scene behaves across different screen sizes in the Map view section of the Settings tab.
In the side panel, the map or scene can be configured in the following ways:
Rename layers.
Turn layers on and off.
Modifying layers in the side panel does not save changes to the web map or scene item in ArcGIS. To edit the original item content, click Edit map in ArcGIS or Edit scene in ArcGIS.
Click Save to add the map or scene.
The web map or web scene is added. To return to the map designer to make updates and revisions, click the Edit button on the map.
Subscription:
Layers that contain premium content are marked in the map designer. Using a premium content layer in a published ArcGIS StoryMaps item consumes credits from your organization every time the item is accessed by one of your readers.
When publishing an ArcGIS StoryMaps item that contains premium content, you are prompted to authorize possible credit charges. Items that contain subscriber content are automatically authorized for public use because they do not incur a credit charge. For more information, see Service credits in ArcGIS StoryMaps.
Troubleshoot issues with web maps and web scenes
If a web map or web scene does not load or does not display as expected, the issue may be related to one of the following limitations:
The ArcGIS StoryMaps builders require that web maps and web scenes be version 2.x to load. For more information, see WebMap in the API reference.
Some layers are not yet supported in ArcGIS Maps SDK for JavaScript. For a list of currently supported layers, see ArcGIS Maps SDK for JavaScript Functionality matrix.
Web maps, web scenes, or feature layers secured with ArcGIS Server web-tier authentication cannot be used with ArcGIS StoryMaps on ArcGIS Online.
If you have added, removed, or renamed layers in a map, the map must be removed from the ArcGIS StoryMaps item and added again to view the changes.
Configure map options
When editing a map, the Options tab of the side panel provides several ways to customize the appearance, behavior, and available tools for the map.
Use the following steps to access the map options:
Hover over an express map, web map, or web scene.
Click Edit on the map toolbar.
Click the Options tab.
The sections below describe the available map configuration options.
Base layer
For an express map, choose a base layer:
Basemap—Choose a basemap from the gallery, or click Browse more maps to select a web map in the Web Mercator projection from your content, favorites, groups, organization, or ArcGIS Living Atlas. Only the basemap layer group of the selected web map is added to the express map. The theme basemap is determined by the selected theme and may change if you apply a different theme. If you choose a basemap from the All basemaps section, it persists even if the theme changes.
Image—Upload an image to use as the map's base layer. The image will replace the basemap, and you can add features and annotations using the express map drawing tools. You can clip the map container to the image aspect ratio to keep the navigation controls within the image boundary. Some map options, such as Search and Overview map, are not available when using an image base layer.
Map configuration
The following options may be available, depending on the type of map.
Allow map navigation—This option allows readers to pan and zoom the map. You can disable this option to prevent readers from navigating the map; however, pop-ups and hover interactions remain active.
Search—The Search option allows readers to find geographic regions and points of interest and navigate the map to those places. The map search uses the ArcGIS World Geocoding Service to find addresses and places around the world. Map search can be enabled for web maps, web scenes, and express maps. To enable this option, first enable Allow map navigation.
Locators that are configured in your organization's settings are also available for your readers to search. Additionally, if the web map has feature search configured, that is available to readers through the map search.
Current location—The Current location option provides readers with a button that shows their location on the map. This can be enabled for web maps, web scenes, express maps, and map tours. To enable this option, first enable Allow map navigation
If an ArcGIS StoryMaps item is embedded in an unsecured (HTTP) web page, the Current location tool is blocked by the browser for security reasons. This feature only works on secure (HTTPS) pages.
Bookmarks—Show the Bookmarks tool so readers can access the bookmarks saved in a web map or slides saved in a web scene.
Legend—Allow readers to show or hide a legend that includes names and symbols for all map layers. When enabled, there is an additional Keep legend open option that shows the legend in the open state when the map first appears.
Keep pop-up open—When enabled, a feature pop-up that is visible when you save the map is shown to readers when the map first appears.
Docked pop-up—When enabled, the pop-up appears docked in the bottom corner of the map. When disabled, pop-ups appear anchored to their corresponding feature.
Time animation—Show a control bar for time-enabled maps that enables readers to play and pause the time animation. The time bar inherits the time settings of the web map or web scene and displays the date, or date range, of its time data. If the interval of the temporal data is less than one day, the time bar will also display the time of day.
Tip:
For more information about configuring time, see Configure time settings in the ArcGIS Online documentation.
Overview map—Add an overview map to provide global context.
Scale bar—Show or hide a scale bar in the attribution bar. This toggle button is available for web maps. The scale bar is always shown for express maps that use a basemap base layer, and it is always hidden for express maps that use an image base layer. Web scenes do not have a scale bar.
Apply theme—Apply theme colors to the pop-up and legend of a web map or web scene. Disable this option if the theme makes content in these areas unreadable or if you prefer to show them in standard light mode. Map controls—such as zoom in and out, home, and search—are always themed.
Map view
The Map view option determines how a map looks when its panel changes size or when the map is viewed on different devices.
Preserve extent—The boundary of the map will always show the same area, even if the map needs to zoom in or out to a different scale. This is recommended when the edges of the map are as important as what's in the center.
Preserve scale—The map will always show at the same scale, even if parts around the outside must be cropped out. This is recommended when the center of the map is the most important or when using scale dependent layers.
Add alternative text
Alternative text is descriptive information about visual media that is announced by screen readers. It is required for media to provide support for search engines and readers using assistive technologies, and it is shown to readers if the media can’t be loaded.
Use the following steps to add alternative text to media:
Hover over the media and click the Options button.
Click the Accessibility tab, if needed.
Type or paste alternative text that describes the media in the Alternative text field.
Tip:
You can use AI to generate alternative text suggestions for your content. To generate alternative text, click the Suggest button, if available. You can edit the suggested alternative text, if needed.
For more information, see AI in ArcGIS StoryMaps.
Click Save.
Alternative text is added for the media.
Add offline media
When creating a briefing, you can add offline media for interactive blocks—such as maps, apps, and embeds—to improve the experience for readers who download the briefing using the ArcGIS StoryMaps Briefings mobile app. When a briefing is downloaded, the offline media is downloaded with the rest of the briefing content and shown when the reader accesses the briefing from the device without a network connection.
Use the following steps to add offline media for a content block:
Hover over the content to show the toolbar.
On the toolbar, click Options.
On the Offline tab, select the type of media you want to add.
Available options for offline media may include an image, a video, a mobile map package (for web maps), or a mobile scene package (for web scenes).
Choose the offline media file, and click Save.
The offline media is added.
Sync map navigation on a briefing or frame slide
When a briefing or frame slide contains two or more maps, you can synchronize them so that navigating one map automatically updates the others.
Web maps, web scenes, and express maps using basemap base layers can be synchronized. Express maps using image base layers are not synchronized.
Use the following steps to enable map synchronization:
Add at least two maps to a briefing or frame slide.
Click the Slide actions button.
Click Enable map sync.
The maps are synchronized. Navigating a map updates the other maps to the same extent. Clicking the Home button on any map returns all maps on the slide to the last saved extent.
Tip:
To update the initial extent of all maps on a slide, edit and save a new extent for any map.
Publish the item so readers can use map synchronization.
To disable map synchronization, click Slide actions, click Disable map sync, and publish the item.
ArcGIS Living Atlas
ArcGIS Living Atlas is a collection of web-based geographic content from around the globe. Its maps can be used in ArcGIS StoryMaps to support your storytelling, and they can be found on the Living Atlas tab of the map browser.
Subscription:
Maps and scenes from ArcGIS Living Atlas may contain premium content layers, which are identified with a badge and consume credits. For more information about authorizing premium content for public consumption, see the note in Add web maps and web scenes.
