Create and manage shared charts
Available with Workflow Manager license.
Shared charts allow you to visualize jobs in the Map view and change the color of job locations based on attribute values defined in the charts. You can create custom shared charts and share them with workflow item users or specific groups. Shared charts can be accessed on the Manage page in the summary panel.
Create shared charts
To create shared charts, complete the following steps:
  1. Access the Workflow Manager web app.
  2. Click the Design tab.
    The Design page appears.
    If you don't have sufficient privileges, the Design tab is not available.
  3. Click Settings .
    If you don’t have sufficient privileges, Settings is not available.
  4. Click the Shared Charts tab.
  5. Click Create New in the Saved Charts panel.
  6. Provide a name for the shared chart in the Chart Name text box.
  7. Provide a field name in the Display Field text box.
    The data from this field is used to create the chart.
  8. Provide a name for the field in the Display Name text box.
    The Display Name text is what appears in the chart and should concisely convey the contents of the field to help others understand the data.
  9. Optionally, click the Sort Direction drop-down arrow and change the sort order.
  10. Optionally, click the Color Ramp drop-down arrow and change the chart's color scheme.
  11. Choose one of the following options in the Share Chart With section:
    • Everyone—Share the chart with all workflow item users.
    • Group—Check the Shared To check box next to each of the workflow item groups you want to give access to the shared chart.
  12. Click Save to save the chart.
Change the display order of shared charts
To change the display order of shared charts in the summary panel on the Manage page, complete the following steps:
  3. Click Settings .
  5. Click the chart that you want to reorder in the Saved Charts list.
  6. Click Move To Top or Move To Bottom , or click Reorder Chart and drag the chart to the desired location.
  7. Click Save to update the display order.
  8. Repeat these steps to reorder more shared charts.
Duplicate shared charts
Duplicating a shared chart allows you to make a copy of a shared chart that can be used as a starting point for charts with similar criteria.
To duplicate a shared chart, complete the following steps:
  3. Click Settings .
  5. Click the shared chart that you want to duplicate in the Saved Charts list.
  6. Click More Actions and click Duplicate Chart.
    The duplicated shared chart appears in the Saved Charts list with - Copy appended to its name.
The shared chart can now be edited and used to create a chart with similar criteria.
Edit shared charts
To edit shared charts, complete the following steps:
  3. Click Settings .
  5. Click the name of the shared chart you want to edit in the Saved Charts list.
    Tip:
    You can filter the Saved Charts list by providing a search term in the Search Saved Charts text box.
  6. Update the chart settings as necessary.
  7. Click Save to save the changes.
Delete shared charts
Deleting a shared chart is permanent and can’t be undone.
To delete a shared chart, complete the following steps:
  3. Click Settings .
  5. Click the name of the shared chart you want to delete in the Saved Charts list.
    Tip:
  6. Click More Actions and click Delete Chart.
    A confirmation message appears.
  7. Click Yes to delete the shared chart or click No to cancel.
Display fields
The following is a list of display fields and their descriptions:
Tip:
Use the syntax tablename.fieldname to search for a field in an extended properties table. This format cannot be used to search for feature service extended properties.
Field name
active_versions
The active branch versions associated with the job
assigned_to
The user to whom the job is assigned
assigned_type
The type of assignment (User, Group, or Unassigned)
closed
The closed state of the job in integer format
closed_by
The user who closed the job
created_by
The user who created the job
created_date
The job's creation date
current_step
The step name of the job's current step
current_step_id
The unique identifier of the current step in the job's workflow diagram
description
The job description
diagram
The job's workflow diagram
diagram_version
The job's workflow diagram version
due_date
The job's scheduled end date
end_date
The date the job was closed
job_id
The unique identifier of the job
job_name
The job's name
job_status
The job's status
job_template_id
The unique identifier of the job template that was used to create the job
job_template_name
The name of the job template that was used to create the job
owned_by
The job's owner
priority
The priority of the job in string format
priority_rank
The priority of the job in integer format
start_date
The job's scheduled start date
step_action_type
The step action associated with the step template. Accepted values include the following:
  • AdvancedAssignment
  • Attachment
  • ClaimVersion
  • Cleanup
  • CreateJob
  • CreateReplica
  • CreateVersion
  • DataQualityRules
  • DefineLocation
  • Email
  • GPService
  • JobProperties
  • JobProperties1M
  • Manual
  • OpenApp
  • ProGPTool
  • ProMappingAndTask
  • Question
  • ReconcilePost
  • SetVersion
  • Survey
  • WebRequest
