Create and manage shared searches
Available with Workflow Manager license.
Shared searches allow workflow item administrators to create custom searches to share with workflow item users or groups. Shared searches can be accessed on the Work page on the search bar. You can also access shared searches on the Manage page in the searches drop-down menu or on the Search tab in the Search/Create panel.
Create shared searches
To create shared searches, complete the following steps:
Access the Workflow Manager web app.
Click the Design tab.
The Design page appears.
If you don't have sufficient privileges, the Design tab is not available.
Click Settings
.Note:
If you don’t have sufficient privileges, Settings
is not available.Click the Shared Searches tab.
Click Create New
in the Saved Searches panel.Provide a name for the search in the Search Name text box.
Provide an SQL expression in the Filter text box using the following example:
Searches for all high-priority jobs that are not closed.
priority='High' AND closed=0Optionally, specify the number of results to display per page in the Results Per Page text box.
Optionally, add a display field for the search results:
Click Add Display Field.
Provide a field name in the Display Fields text box.
Provide a name for the column displayed in the search results in the Display Names text box.
Click Add Display Field and repeat these substeps to add more display fields.
To delete a field, click Delete Field
.Tip:
To change the order of the fields, hover over the field and click Move Field To Top
or Move Field To Bottom
, or click Reorder Field
and drag the field to the new location.
In ArcGIS Pro, the first three display fields appear in the job tile.
If
assignedToorjobNameare one of the first three display fields, the next display field is used.If
currentStepisn't included in the first three display fields and your workflow has parallel steps, only the first step is shown in the job tile instead of the parallel steps drop-down menu.
Optionally, add sort fields to set the sort order of the shared search results:
Click Add Sort Field.
Provide a field name in the Sort Fields text box.
Click the Sort Order drop-down arrow and choose a sorting method.
Click Add Sort Field and repeat these substeps to add more sort fields.
.Tip:
Choose one of the following options in the Share Search With section:
Everyone—Share the search with all workflow item users.
Group—Check the Shared To check box next to each workflow item group that you want to share the search with.
Optionally, click Test Search to test the search settings.
Click Save to save the search.
Edit shared searches
To edit shared searches, complete the following steps:
Click Settings
.Note:
Click the name of the shared search you want to edit in the Saved Searches list.
Tip:
You can filter the Saved Searches list by providing a search term in the Search Saved Searches text box.
Update the search settings as necessary.
Click Save to save the changes.
Change the display order of shared searches
You can specify the order in which shared searches are displayed on the Manage and Work pages in the Workflow Manager web app and the Workflow pane in ArcGIS Pro for all workflow item users.
To change the display order of shared searches, complete the following steps:
Click Settings
.Note:
Click the search that you want to reorder in the Saved Searches list.
Click Move To Top
or Move To Bottom
, or click Reorder Search
and drag the search to the desired location.Click Save to update the display order.
Repeat the steps to reorder more shared searches.
Duplicate shared searches
Duplicating a shared search allows you to make a copy of a shared search that can be used as a starting point for similar job searches.
To duplicate a shared search, complete the following steps:
Click Settings
.Note:
Click the shared search that you want to duplicate in the Saved Searches list.
Click More Actions
and click Duplicate Search.The duplicated shared search appears in the Saved Searches list with - Copy appended to its name.
The shared search can now be edited and used to search for jobs with similar search criteria.
Delete shared searches
Deleting a shared search is permanent and can’t be undone.
To delete a shared search, complete the following steps:
Click Settings
.Note:
Click the name of the shared search you want to delete in the Saved Searches list.
Tip:
Click More Actions
and click Delete Search.A confirmation message appears.
Click Yes to delete the shared search or click No to cancel.
Configure custom search
Custom Search is a predefined shared search that contains the default display and sort fields for the Manage and Work page. You can add, edit, or remove values to apply custom search results for workflow item users.
To modify the Custom Search results, complete the following steps:
Click Settings
.Note:
.Tip:
If
.Tip:
Edit or remove search values as necessary.
Click Save to save the changes or Discard Changes to cancel.
To revert to the default search values, click More Actions
and click Revert To Default.
Searchable fields
The following is a list of searchable fields and their descriptions:
Tip:
Use the syntax tablename.fieldname to search for a field in an extended properties table. This format cannot be used to search for feature service extended properties and ArcGIS Survey123 extended properties.
Field name |
Description |
Example SQL expression |
The active branch versions associated with the job |
The user to whom the job is assigned |
The type of assignment (User, Group, or Unassigned) |
The closed state of the job in integer format |
The user who closed the job |
The user who created the job |
The job's creation date |
The step name of the job's current step |
The unique identifier of the current step in the job's workflow diagram |
The job description |
The job's workflow diagram |
The job's workflow diagram version |
The job's scheduled end date |
The date the job was closed |
The unique identifier of the job |
The job's name |
The job's status |
The unique identifier of the job template that was used to create the job |
The name of the job template that was used to create the job |
The job's owner |
The priority of the job in string format |
The priority of the job in integer format |
The job's scheduled start date |
The step action associated with the step template. Accepted values include the following:
Display and sort fields
The following is a list of display and sort fields and their descriptions:
Field name |
Description |
The job's name |
The job's status |
The job's owner |
