Monitor the status of work
Available with Workflow Manager license.
ArcGIS Workflow Manager allows you to search for jobs, and visualize and monitor work to help you make informed decisions in the deployment of your workforce. Summary charts provide a graphical representation of job properties, including Job Status, Job Type, and Job Priority. You can also create custom charts and share them with workflow item users or specific groups. Complete these steps to search for jobs and to filter, visualize, and monitor the status of work in the Workflow Manager web app:
Access the Workflow Manager web app.
Click the Manage tab.
The Manage page appears.
If you don't have sufficient privileges, the Manage tab is not available.
Click Search/Create to expand the Search panel.
Search for jobs by doing one of the following:
Click a shared search in the Shared section.
Provide a keyword or an SQL expression in the Search Jobs text box.
Searches that you perform appear under Recent in the Search panel. Hover over a recent search to review the search criteria. You can also edit a recent search by clicking Edit Search
or delete it by clicking Delete Search
. Recent searches are available until you sign out of the Workflow Manager web app.
Jobs that match your search criteria appear in the List view and jobs with location information appear on the map with job name labels in the Map view.
Job name labels are only available for jobs that contain line or polygon features.
Optionally, hover over a job that contains a job location in the List view and click Zoom to job location
to zoom to the job's location on the map.Optionally, click Filter and turn on Restrict results to map extent to filter the List view to jobs that appear in the current extent of the Map view.
Click Refresh results to update the job list when the map extent is changed.
Optionally, click Group and turn on Group by parent job to visualize parent-child job relationships on the map.
Optionally, click a section of a chart in the summary panel to visualize jobs on the map and change the color of the locations based on attribute values defined in the chart.
The chart expands and displays a legend with attribute values. Click Clear Selection to collapse the chart and remove the chart visualization from the job locations in the Map view.
