CreateWebLayerSDDraft
Resumen
Converts a map, layer, or list of layers in an ArcGIS Project to a Service Definition Draft (.sddraft) file.
Debate
Heredado:
The arcpy.sharing module was introduced at ArcGIS Pro 2.2 to provide a better experience when sharing web layers over the previously existing function CreateWebLayerSDDraft. The original function is provided only for continuing backward compatibility. For more information, see Introduction to the sharing module.
CreateWebLayerSDDraft is the first step to automate the publishing of a map, layer, or list of layers to a hosted web layer using ArcPy. The output created from the CreateWebLayerSDDraft is a Service Definition Draft (.sddraft) file.
To share a web layer, you must have the following:
An account that is part of an online organization
Membership in a Publisher or Administrator role for your account
The Service Definition Draft can then be converted to a fully consolidated Service Definition (.sd) file using the Stage Service tool. Staging compiles all the necessary information needed to successfully publish the GIS resource. Finally, the Service Definition file can be uploaded and published as a GIS service to a specified online organization using the Upload Service Definition tool. This step takes the Service Definition file, copies it onto the server, extracts required information, and publishes the GIS resource.
When publishing hosted services to ArcGIS Online, sign-in information is obtained from the user name and password that you were prompted to enter when you started ArcGIS Pro.
Sintaxis
CreateWebLayerSDDraft(map_or_layers, out_sddraft, service_name, {server_type}, {service_type}, {folder_name}, {overwrite_existing_service}, {copy_data_to_server}, {enable_editing}, {allow_exporting}, {enable_sync}, {summary}, {tags}, {description}, {credits}, {use_limitations})
| El parámetro | Explicación | Tipo de datos |
map_or_layers |
A variable that references a Map object, Layer object, or a list of Layer objects. If publishing a list of Layer objects, they must be from the same map. |
Object |
out_sddraft |
A string that represents the path and file name for the output Service Definition Draft ( |
String |
service_name |
A string that represents the name of the service. This is the name people will see and use to identify the service. The name can only contain alphanumeric characters and underscores. No spaces or special characters are allowed. The name cannot be more than 120 characters in length. |
String |
server_type |
A string representing the server type. Currently, the only supported value is The default value is MY_HOSTED_SERVICES. |
String |
service_type |
A string representing the service type.
Nota:Map image layers and map services are not supported service types in the The default value is FEATURE_ACCESS. |
String |
folder_name |
A string that represents a folder name to which you want to publish the service definition. If the folder does not currently exist, it will be created. The default folder is the server root level. The default value is None. |
String |
overwrite_existing_service |
A Boolean that determines whether to overwrite an existing service or not. The default value is False. |
Boolean |
copy_data_to_server |
A Boolean that indicates whether the data referenced in the map or layers are copied to the server or not. The default value is False. |
Boolean |
enable_editing |
A Boolean that determines if editing of feature services is enabled. Query capability is always on. Editing is optional. The default value is False. |
Boolean |
allow_exporting |
A Boolean that determines if users can export the service to different formats. The default value is False. |
Boolean |
enable_sync |
A Boolean that determines if users can work with a local copy of the data even when they are offline and synchronize changes when they are online. The default value is False. |
Boolean |
summary |
A string that represents the summary. The default value is None. |
String |
tags |
A string that represents the tags. Multiple tags can be added or separated by a comma or semicolon. The default value is None. |
String |
description |
A string that represents the description. The default value is None. |
String |
credits |
A string that represents the credits. The default value is None. |
String |
use_limitations |
A string that represents the use limitations. The default value is None. |
String |
Muestra de código
The following script publishes a map as feature access layers to ArcGIS Online.
import arcpy
aprx = arcpy.mp.ArcGISProject('C:/Project/Counties.aprx')
m = aprx.listMaps('USA Counties')[0]
arcpy.mp.CreateWebLayerSDDraft(m, 'C:/Project/Counties.sddraft', 'Counties', 'MY_HOSTED_SERVICES', 'FEATURE_ACCESS')
arcpy.server.StageService('C:/Project/Counties.sddraft', 'C:/Project/Counties.sd')
arcpy.server.UploadServiceDefinition('C:/Project/Counties.sd', 'My Hosted Services')
The following script publishes a list of layers as tiled layers to ArcGIS Online.
import arcpy
lyrs=[]
lyrs.append(m.listLayers('Cities')[0])
lyrs.append(m.listLayers('Counties')[0])
arcpy.mp.CreateWebLayerSDDraft(lyrs, 'C:/Project/Counties.sddraft', 'Counties', 'MY_HOSTED_SERVICES', 'TILED')
The following script publishes a single layer as a feature access layer to ArcGIS Online.
import arcpy
lyr = m.listLayers('Cities')[0]
arcpy.mp.CreateWebLayerSDDraft(lyr, 'C:/Project/Cities.sddraft', 'Cities', 'MY_HOSTED_SERVICES', 'FEATURE_ACCESS')
arcpy.server.StageService('C:/Project/Cities.sddraft', 'C:/Project/Cities.sd')
arcpy.server.UploadServiceDefinition('C:/Project/Cities.sd', 'My Hosted Services')
