An overview of overlay classes
Disponible con licencia de Spatial Analyst.
Disponible con licencia de Image Analyst.
Weighted overlay objects define the reclassification that will be used to put diverse or dissimilar input rasters into a common scale of values and the weights to be applied to perform an integrated analysis. The input rasters are reclassified or weighted by importance and added together to produce an output raster.
Class
WOTable
Defines the input rasters, the field identifying the input values, the remap of their values, the weight of each raster, and the evaluation scale to use in the Weighted Overlay tool.
WSTable
Defines the input rasters and their weights which will be added together in the Weighted Sum tool.
The following tools use the overlay objects:
Licencia:
The WSTable class is also available if you have an Image Analyst extension license.
