- (Negate) operator
サマリー
Changes the sign of the cell values (multiplies by -1) of the input raster on a cell-by-cell basis.
Negate illustration
OutRas = -Raster("InRas1")
ディスカッション
When using an operator with a raster input, the result will be a raster. However, if all inputs are numbers, the result will be a number.
When there are multiple operators in an expression, the operators are not necessarily run in left-to-right order. The operator with the highest precedence value will be run first. For more information, see the operator precedence table in Work with operators in map algebra. Use parentheses to control the run order.
If the input is integer, the output will be integer. If the input is floating point, the output will be floating point.
If the input is a multiband raster, the output will be a multiband raster. The operator will perform the operation on each band in the input.
If the input is a multidimensional raster, all slices from all variables will be processed, and the output will be a multidimensional raster.
オペランド
オペランド 説明 データ タイプ
in_raster_or_constant
The input raster to be negated (multiplied by -1).
Raster Layer | Constant
環境
Cell Size, Current Workspace, Mask, Output Coordinate System, Extent, Scratch Workspace, Snap Raster
コードのサンプル
Unary - (Negate) example 1 (Python window)
This sample changes the sign of the values in the input raster.
import arcpy
from arcpy import env
from arcpy.ia import *
env.workspace = "C:/iapyexamples/data"
outNegate = - Raster("degs")
outNegate.save("C:/iapyexamples/output/outneg")
Unary - (Negate) example 2 (stand-alone script)
# Name: Op_Negate_Ex_02.py
# Description: Changes the sign (multiplies by -1) of the cell values
#              of the input raster on a cell-by-cell basis
# Requirements: Image Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inRaster = Raster("degs")
# Run Negate
outNegate = -(inRaster)
# Save the output
outNegate.save("C:/iapyexamples/output/outnegate")
