FuzzyMSSmall
サマリー
Defines a fuzzy membership through a function based on the mean and standard deviation, with the smaller values having a membership closer to 1.
ディスカッション
The tool that uses the FuzzyMSSmall object: Fuzzy Membership.
There are two equations for this function, depending on the product of \(a * m\).
  • If \(x > a * m\):
    \(u(x) = \Large \frac {(b * s)}{(x - (a * m) + (b * s))}\)
    • where:
      \(m\) is the mean
      \(s\) is the standard deviation
      \(a\) is a multiplier of the mean
      \(b\) is a multiplier of the standard deviation
      The \(a\) and \(b\) multipliers are input parameters.
  • If \(x <= a * m\):
    \(u(x) = 0\)
This function is useful when the small input values have a higher membership.
The input values can be either integer or floating point positive values.
The result can be similar to the FuzzySmall membership function, depending on how the multipliers of the mean and standard deviation are defined.
構文
FuzzyMSSmall(meanMultiplier, STDMultiplier)
名前 説明 データ タイプ
meanMultiplier
The multiplier for the mean of the input values in the function equation.
The default value is 1.
Double
STDMultiplier
The multiplier for the standard deviation of the input values in the function equation.
Double
プロパティ
名前 説明 データ タイプ
meanMultiplier
(読み取り/書き込み)
The multiplier for the mean of the input values in the membership function equation.
Double
STDMultiplier
(読み取り/書き込み)
The multiplier for the standard deviation of the input values in the membership function equation.
Double
コードのサンプル
FuzzyMSSmall example 1 (Python window)
Demonstrates how to create a FuzzyMSSmall class and use it in the FuzzyMembership tool within the Python window.
import arcpy
from arcpy.sa import *
from arcpy import env
env.workspace = "c:/sapyexamples/data"
outFzyMember = FuzzyMembership("as_std", FuzzyMSSmall(1.2, 3.2))
outFzyMember.save("c:/sapyexamples/fzymssml")
FuzzyMSSmall example 2 (stand-alone script)
Performs a FuzzyMembership using the FuzzyMSSmall class.
# Name: FuzzyMSSmall_Ex_02.py
# Description: Scales input raster data into values ranging from zero to one
#     indicating the strength of a membership in a set.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
env.workspace = "C:/sapyexamples/data"
# Set local variables
inRaster = "as_std"
# Create the FuzzyMSSmall algorithm object
meanMultiply = 1.5
stdMultiply = 1
myFuzzyAlgorithm = FuzzyMSSmall(meanMultiply, stdMultiply)
# Run FuzzyMembership
outFuzzyMember = FuzzyMembership(inRaster, myFuzzyAlgorithm)
# Save the output
outFuzzyMember.save("c:/sapyexamples/fzymssml2")
