NbrWedge
サマリー
Defines a wedge neighborhood which is created by specifying a radius and two angles in either map units or number of cells.
NbrWedge neighborhood for FocalStatistics function
NbrWedge neighborhood example for the FocalStatistics function (radius 3 cells, start angle 0, end angle 90).
NbrWedge neighborhood for BlockStatistics function
NbrWedge neighborhood example for the BlockStatistics function (radius = 3 cells, start angle = 0, end angle = 270).
ディスカッション
Tools that use neighborhood wedge object: Block Statistics, Focal Statistics, Point Statistics, Point Density, and Topographic Position Index.
ライセンス:
This class is also available if you have an Image Analyst extension license, but only for the Focal Statistics tool.
A wedge is specified by a radius, a startAngle, an endAngle, and the units. The wedge extends counterclockwise from the starting angle to the ending angle. Angles are specified in arithmetic degrees (counterclockwise from the positive x-axis). Negative angles may be used.
The radius is identified in cells or map units, measured perpendicular to the x- or y-axis. When the radius is specified in map units, it is converted to a radius in cell units. The resulting radius in cell units produces an area that most closely represents the area calculated by using the original radius in map units. Any cell center encompassed by the wedge will be included in the processing of the neighborhood.
構文
NbrWedge({radius}, {startAngle}, {endAngle}, {units})
名前 説明 データ タイプ
radius
(オプション)
The radius is the distance from the corner of the wedge to the outer limit of the wedge. The radius is an integer or floating-point value.
The default value is 3.
Double
startAngle
(オプション)
The startAngle is an integer or floating-point value from 0 to 360.
The start angle is measured counterclockwise from the positive x-axis (3:00 on a clock) to the closest edge of the wedge.
The default value is 0.
Double
endAngle
(オプション)
The endAngle is an integer or floating-point value from 0 to 360.
The end angle is measured counterclockwise from the positive x-axis (3:00 on a clock) to the outer edge of the wedge.
The default value is 90.
Double
units
(オプション)
Defines the units of the neighborhood.
  • CELL—The unit of measurement is in cells.
  • MAP—The units are in map coordinates.
The default value is CELL.
String
プロパティ
名前 説明 データ タイプ
radius
(読み取り/書き込み)
Double
startAngle
(読み取り/書き込み)
The startAngle is a value from 0 to 360. It can be integer or floating-point.
Double
endAngle
(読み取り/書き込み)
The endAngle is a value ranging from 0 to 360. It can be integer or floating-point.
The endAngle is measured counterclockwise from the positive x-axis (3:00 on a clock) to the outer edge of the wedge.
Double
units
(読み取り/書き込み)
  • CELL—The units are the number of cells.
String
コードのサンプル
NbrWedge example 1 (Python window)
Demonstrates how to create a NbrWedge class and use it in the BlockStatistics tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
outNbrWedge = BlockStatistics("block", NbrWedge(5, 10.5, 40, "MAP"))
outNbrWedge.save("C:/sapyexamples/output/blstatsnbrw2")
NbrWedge example 2 (stand-alone script)
Implements the BlockStatistics tool using the NbrWedge class.
# Name: NbrWedge_Ex_02.py
# Description: Uses the NbrWedge object to run BlockStatistics tool
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inRaster = "block"
# Create the Neighborhood Object
radius = 5
startAngle = 5
endAngle = 10
myNbrWedge = NbrWedge(radius, startAngle, endAngle, "")
# Run BlockStatistics
outBlkStats =  BlockStatistics(inRaster, myNbrWedge, "MINIMUM", "DATA")
# Save the output
outBlkStats.save("C:/sapyexamples/output/blkst_wedge4")
