Quick Import (Data Interoperability Tools)
サマリー
Converts vector or tabular data in any format supported by the ArcGIS Data Interoperability extension into feature classes or tables.
The output is written to a geodatabase. The geodatabase can then be used directly or additional postprocessing can be performed.
使用法
  • This tool imports nonnative data into ArcGIS. The output will typically require additional processing before you can integrate it with existing data or formats.
  • The number of output feature classes depends on the input data and the format. For example, if you import two MapInfo MIF/MID files, the tool will create two features classes.
  • To convert raster and point cloud data, create a spatial ETL tool with a reader and writer of your choice.
  • This tool creates a default output schema for the output geodatabase. If the output requires schema changes, use the spatial ETL tool instead.
  • When using ModelBuilder, access the feature classes in the output geodatabase using the Select Data tool.
  • Any Bézier curves in the input will be maintained as Bézier curves in the output.
パラメーター
ラベル 説明 データ タイプ
Input Dataset
The input data source, which can be a file, folder, or URL.
Interop Source Dataset
Output Geodatabase
The output file geodatabase.
Workspace
環境
このツールは、ジオプロセシング環境を一切使用しません。
ライセンス情報
  • Basic: Requires Data Interoperability
  • Standard: Requires Data Interoperability
  • Advanced: Requires Data Interoperability
