Set up a local Business Analyst dataset
Доступно с лицензией Image Analyst.
Примечание:
Beginning with the U.S. 2026 dataset release, Windows Installer is no longer supported. All future local Business Analyst datasets must be accessed through connection rather than installation. For more information, see Reintroducing an easier way to connect to local ArcGIS Business Analyst datasets.
To set up a local Business Analyst dataset, perform the following steps:
Download the appropriate archive files and extract the files to a local or shared network folder.
Make a connection to the dataset from the ArcGIS Pro Options dialog box.
License the data.
Примечание:
The instructions in the section below provide guidance for setting up the latest Business Analyst U.S. dataset. They are intended to offer an overview of the setup process, which varies slightly for each dataset. For detailed instructions on specific datasets, see Business Analyst datasets.
To learn about setting up other country-specific datasets, contact your regional Esri distributor.
Download and extract Business Analyst dataset files
You can download Business Analyst data files from My Esri. To download the files from My Esri, complete the following steps:
Примечание:
You must install the 7-Zip open source program to extract and reassemble the Business Analyst data files from the downloads. You can download the latest version of 7-Zip from the official site: https://www.7-zip.org/.
On the My Esri site, click Downloads and click All Products and Versions.
In the Products section, under All Other Products, type Business Analyst in the Quick Search text box.
A list of Business Analyst data products is shown.
Find U.S. Data for use with ArcGIS Business Analyst Pro and click View Downloads.
On the Download Components tab, click Data and Content to expand the list of files.
For the U.S. 2026 data, there are nine zipped files. Each must be downloaded to a folder on your local drive. You need 229 GB of free space on the drive you are using.
There is also one zipped file containing semantic search resources. If you plan to enable semantic search, you must download this file:
ESRI_BA_2026_US_Semantic_Search_Resources.7z.Подсказка:
Once you have downloaded and uncompressed the files, you can delete the 7-Zip files and install directories to free up space.
Beside the first data file, click Download.
Примечание:
Depending on your browser, you may be prompted to select a location where you want the file downloaded.
Repeat step 5 for the remaining eight data files and the optional semantic search file.
Right-click ESRI_BA_2026_US_Data_Update.7z.001 and click 7-Zip > Extract Here.
All files in the set are extracted when the process is initiated on the first file. The
ESRI_BA_2026_US_Data_Updateinstall directory is created upon completion of the extraction.If the optional semantic search file was downloaded, right-click ESRI_BA_2026_US_Semantic_Search_Resources.7z and click 7-Zip > Extract Here.
The semantic search Resources folder is extracted to the correct location in the data folder.
Примечание:
You can verify that your downloaded files match the originals at the source by following the instructions in Verify an Esri download using the checksum. Matching your downloaded files to the originals ensures all files downloaded correctly, preventing potential issues.
Connect to the dataset in ArcGIS Pro
To start using a local Business Analyst dataset, you must first connect to it using the Options dialog box in ArcGIS Pro. To connect to the dataset, do the following:
Open the ArcGIS Pro settings page in one of the following ways:
From an open project, click the Project tab on the ribbon.
From the start page, click the Settings tab
In the list of side tabs, click Options.
In the Options dialog box, under Application, click Business Analyst.
In the Business Analyst Options pane, click the Add Dataset button.
The Add Business Analyst Dataset dialog box appears.
Browse to the directory where the Business Analyst data is stored and select the
dataset_description.xmlfile. Click OK.You can view information about the dataset in the Name, Path, and Status fields. Status shows whether the data is licensed. The data must be licensed before it can be used in ArcGIS Pro.
Click OK to close the Options dialog box.
Install a local Business Analyst dataset
Starting at ArcGIS 3.0, connecting to a local Business Analyst dataset, rather than installing it, is recommended.
Примечание:
Beginning with the U.S. 2026 dataset release, Windows Installer is longer supported.
You can install a local dataset to register it in the system by doing the following:
Run the setup installer from the ESRI_BA_2025_US_Data_Update folder to install the data components. As you click through the installation process, choose one of the two installation options:
Typical—This is the default installation, which automatically loads Business Analyst data components to your local hard drive to a default location,
C:\ArcGIS\Business Analyst\US_2025\Data.Custom—Use the custom option if you have limited space on the local hard drive. This option allows you to select which data components to install and where you want to install them. You can also choose not to install any data components and run Business Analyst from USB media or from a network location.
If the optional semantic search file was downloaded, do the following:
Right-click ESRI_BA_2025_US_Semantic_Search_Resources.7z and click 7-Zip > Open archive.
The 7-Zip File Manager opens.
Double-click the ESRI_BA_2025_Data_Update folder and locate the Resources folder.
Click the Extract button on the ribbon of the file manager.
A Copy dialog box opens.
Set the Copy to location setting as C:\ArcGIS\Business Analyst\US_2025. Click OK.
For more information about using semantic search with local data, see Semantic search with local datasets.
The installed dataset contains the following components:
Demographic data
Business data
ArcGIS StreetMap Premium
Geocoding data for ArcGIS Pro
License the data
To unlock the data supplied by the local Business Analyst dataset, you must download the .sdlic file and install it.
Примечание:
For users outside of the United States and Canada, if you do not have a My Esri account, contact your regional Esri distributor to obtain the necessary data license file. Some regional datasets do not require a data license file.
Download the license file
To download the data license file from My Esri, complete the following steps:
Sign in to My Esri.
Click Licensing and click License Files.
Click Business Analyst and StreetMap Premium.
Click Download to download the
.sdlicfile.
Install the license file
To install the license file in ArcGIS Pro, complete the following steps:
Start ArcGIS Pro as an administrator.
On the ArcGIS Pro start page, click Settings
in the upper left corner of the application window. Alternatively, if you have a project open, click the Project tab on the ribbon.On the Settings page, click Licensing.
Under Settings, click Manage your data licensing.
Click Add and browse to where the
.sdlicfile is located.Select the
.sdlicfile and click Open.In the Manage Data Licenses window, a list of the Business Analyst datasets is shown.
Click OK and exit the Licensing window.
Restart ArcGIS Pro.
Set up ArcGIS StreetMap Premium
The Business Analyst dataset includes a limited license for ArcGIS StreetMap Premium for North America, which includes locators for ArcGIS Pro, the StreetMap Premium street network for the U.S., and the StreetMap Premium basemap, which can be used exclusively with Business Analyst workflows. The license included with the Business Analyst dataset does not include all features of StreetMap Premium.
Внимание:
Using the StreetMap Premium locators, street network, and basemap that are included with the local data outside of Business Analyst workflows violates the terms of use.
Authorize ArcGIS StreetMap Premium license
Authorization files are provided on My Esri to enable the StreetMap Premium items. To enable your StreetMap Premium authorization files, perform the following steps:
Примечание:
StreetMap Premium appears in your My Esri downloads list to enable the authorizations. You do not need to download these files—all required geocoding files are included in the data.
On the My Esri site, click Licensing and click License Information.
Click Authorizations.
In the Quick Search text box, type
StreetMap Premiumorstreetmap.Look for StreetMap Premium North America for Pro and click Expand Details.
A list of authorization files appears.
Apply the authorizations with the ArcGIS licensing process.
Set up locators for geocoding
To perform geocoding operations locally, without connecting to an online geocoding service, you must add the locators provided with the Business Analyst dataset as part of the limited license for ArcGIS StreetMap Premium.
To set up locators, do the following:
Open a project in ArcGIS Pro.
Open the Catalog pane and right-click Locators.
Click Add Locator.
On the Select Existing Locator window, browse to the location of the local Business Analyst dataset on your machine.
Подсказка:
In a local Business Analyst dataset, the typical location of the geocoding locator is Data > Geocoding Data. The locator uses an
.locfile type.Select the relevant locator and click OK.
The locator is added to the project.
Optionally, set the folder containing the locator as a favorite item for quick access in future projects. To set the locator folder as a favorite for all projects, do the following:
On the Catalog pane, click the Favorites tab.
If necessary, click My Favorites
.Click Add Item and select Add Folder.
Browse to the folder containing the locator (for example, the Geocoding Data folder), select the folder, and click OK.
Follow the instructions to add a favorite to all new projects.
The next time you open a new project, the folder location is available on the My Favorites tab, allowing quick access for adding the locator to the project.
Manage Business Analyst datasets
You can add, remove, and view information about local Business Analyst datasets in the ArcGIS Pro Options dialog box. Datasets you can connect to are listed in the dialog box, as well as datasets that you have installed.
Примечание:
The Options dialog box displays all available Business Analyst datasets:
Datasets you can connect to are shown in black.
Datasets you have installed are shown in grey.
To manage Business Analyst datasets, do the following:
In the Business Analyst Options pane, use or review any of the following options:
Option
Add Dataset button
Add or connect to a dataset.
Remove Dataset button
Disconnect from a dataset. If you remove a dataset, you are no longer able to connect to it.
Path column
Indicates where the dataset is stored on your computer or network. Best practices for storing datasets:
Store your data in an accessible local drive location, such as your C drive.
You can store data on a shared or network drive, but it may affect performance.
It is not recommended to save data in the default installed Esri data location.
Status column
A green checkmark icon
indicates that you have the appropriate license to use the data. A red exclamation icon
indicates that you do not have the appropriate license.
