Add Point Layer Based Suitability Criteria (Business Analyst Tools)
Краткая информация
Adds criteria based on spatial relationships between the input layer and a specified point layer.
Использование
  • You can use the Make Suitability Analysis Layer tool to create the analysis layer.
  • The influence for the point can be based on count, a weight, or minimum distance.
  • For weight, a numeric field and Statistics Type parameter value must be specified.
  • For minimum distance, the centers of the sites must be specified. The centers of the sites are used for calculating the distance to the points.
  • Set the influence for each criteria using the Set Criteria Property tool.
Параметры
Подпись Объяснение Тип данных
Input Suitability Analysis Layer
The Suitability Analysis layer that will be used in the analysis.
Feature Layer; Group Layer
Site Layer ID Field
A field containing unique values for each record in the Suitability Analysis layer.
String
Point Features
The layer containing point locations that will be added as criteria based on the spatial relationship to the Suitability Analysis layer.
Feature Layer
Criteria Type
Specifies the type of spatial relationship that will be used as criteria.
  • Count–A count of points that fall within each Suitability Analysis layer polygon will be used as criteria. This is the default.
  • Weight–Field-weighted criteria of points that fall within each Suitability Analysis polygon based on the user-selected statistical type will be used as criteria.
  • Minimal Distance–The distance from the closest point to each of the Suitability Analysis layer centroids will be used as criteria.
String
Distance Type
(Дополнительный)
The method of travel that will be used to calculate the minimal distance.
String
Measure Units
(Дополнительный)
The unit of measure that will be used when calculating minimal distance.
String
Site Centers Features
(Дополнительный)
The point layer that will be used as site centers. This point layer will replace default polygon centroids of the Suitability Analysis layer.
Feature Layer
Site Centers Layer ID Field
(Дополнительный)
A field in the Site Centers Features parameter value that uniquely identifies each record.
Field
Weight Field
Numeric fields that exist in a point layer that will be selected for weighting.
Field
Statistics Type
(Дополнительный)
Specifies the type of statistical operation that will be applied to the weighted field.
  • Sum–The total of the field values will be calculated for each point feature.
  • Average–The average field value will be calculated for each point feature.
  • Standard Deviation–The standard deviation of the field values will be calculated for each point feature.
  • Minimum–The smallest field value will be determined for each point feature.
  • Maximum–The largest field value will be determined for each point feature.
String
Cutoff
(Дополнительный)
The distance beyond which points will not be considered in the calculation.
Double
Производные выходные данные
Output Suitability Analysis Layer
A container for the output layer.
Output Criteria Name
The name of the criteria that will be added to the Suitability Analysis layer.
String
Параметры среды
Current Workspace, Data Source, Network Source
Информация о лицензировании
  • Basic: Requires Business Analyst and Network Analyst
  • Standard: Requires Business Analyst and Network Analyst
  • Advanced: Requires Business Analyst and Network Analyst
