Huff Model Calibration (Business Analyst Tools)
Краткая информация
Calculates exponent values for use in the Huff Model tool.
Использование
  • The output exponents are based on attractiveness values of the existing facilities and their spatial relationship to customer points.
  • Customer point data is a required input.
  • The Huff Model Calibration output is stored in the Business Analyst container in the Catalog pane.
  • Exponent values are correlated to the market defined by the inputs. Although they can be applied to additional markets, they may be less reliable in those scenarios.
  • The Huff Model Calibration output can be applied to the Huff Model tool.
Параметры
Подпись Объяснение Тип данных
Input Facility Features
The input point feature class representing competitors or existing stores.
Feature Layer
Facility ID Field
A unique ID field representing a store or facility location.
Field
Input Customer Features
The input point feature class representing customer locations.
Feature Layer
Associated Facility ID Field
The field that will be used as an ID to assign individual customers to a facility or store.
Field
Input Sales Potential Features
The input polygon feature class used to determine the potential sales market.
Feature Layer
Sales Potential ID Field
A unique ID field representing the sales potential area.
Field
Output Calibration
The output calibration file that will contain the calibrated Huff model results, which is the exponent values for the attractiveness variables and distance. The output file extension will be *.huffmodel.
File
Attractiveness Variables
The fields that will be used to determine the attractiveness of each competitor. In many cases, the size of the store is used as a substitute for attractiveness.
Value Table
Customer Weight Field
(Дополнительный)
A calculated weighted value field assigned to each customer.
Field
Distance Type
(Дополнительный)
The method of travel that will be used to calculate distance. The default value is Straight Line.
String
Distance Units
(Дополнительный)
The distance-measuring units that will be used when calculating distance.
String
Travel Direction
(Дополнительный)
Specifies the direction of travel that will be used between stores and sales potential features.
  • Toward Stores–The direction of travel will be from sales potential features to stores. This is the default.
  • Away from Stores–The direction of travel will be from stores to sales potential features.
String
Time of Day
(Дополнительный)
The time and date that will be used when calculating distance.
Date
Time Zone
(Дополнительный)
Specifies the time zone that will be used for the Time of Day parameter.
  • Time Zone at Location–The time zone in which the territories are located will be used. This is the default.
  • UTC–Coordinated universal time (UTC) will be used.
String
Параметры среды
Current Workspace, Data Source, Network Source
Информация о лицензировании
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Advanced: Requires Business Analyst
