Upgrade a relational store on AWS
This information applies to upgrading an ArcGIS Data Store relational store configured on an Amazon Elastic Compute Cloud (EC2) instance or instances separate from other ArcGIS Enterprise components.
How you upgrade depends on how and when you created the ArcGIS Data Store relational store on Amazon Web Services (AWS).
  • You can use manual procedures to upgrade any relational stores running on their own Amazon Elastic Compute Cloud (EC2) instance or instances. If you created the relational store on its own instance before 10.9, you must use the manual procedures to upgrade.
  • If you created the relational store on its own EC2 instance or instances using the 10.9 or later ArcGIS Enterprise Cloud Builder for Amazon Web Services app, you can use the 12.1 Cloud Builder app to upgrade to 12.1. If the deployment is still at 10.9 or 10.9.1, you must first upgrade to an interim version before you can upgrade to 12.1.
  • If you created the relational store on its own EC2 instance or instances using 10.9 or later Amazon Web Services (AWS) CloudFormation templates provided by Esri, you can use 12.1 CloudFormation templates to upgrade to 12.1. If the deployment is still at 10.9 or 10.9.1, you must first upgrade to an interim version before you can upgrade to 12.1.
  • If the relational store is part of a single-machine or highly available ArcGIS Enterprise deployment you created using a CloudFormation template provided by Esri or using the Cloud Builder app, the data store will be upgraded when you upgrade the ArcGIS Enterprise deployment. See Upgrade a single-machine ArcGIS Enterprise deployment on AWS or Upgrade a highly available ArcGIS Enterprise deployment on AWS for more information.
Before you upgrade
Regardless of the upgrade method you use, review the following information before you upgrade the deployment:
  • Read ArcGIS upgrades on Amazon Web Services to determine whether your deployment requires that you perform extra tasks before upgrading to 12.1. Complete all required tasks before upgrading to 12.1.
  • Create a backup of the data store.
    You can create a backup of the ArcGIS Enterprise deployment (which includes the relational store) using the webgisdr utility installed with Portal for ArcGIS. See ArcGIS Enterprise backups for more information.
  • You must upgrade the ArcGIS GIS Server site (the hosting server) with which the relational store is registered before you upgrade the relational store.
Upgrade using manual upgrade procedures
The manual upgrade procedure for ArcGIS Data Store on its own EC2 instance or instances on AWS is similar to upgrading ArcGIS Data Store on-premises. Therefore, follow instructions in Upgrade ArcGIS Data Store to upgrade. Read the instructions specific to the operating system on your EC2 instances.
If the starting version or components in your deployment require you to upgrade to an interim version, follow the instructions provided in the interim help version before following instructions to upgrade to 12.1.
Upgrade using a CloudFormation template
If you created the relational store on its own EC2 instance or instances using 10.9 or later Amazon Web Services (AWS) CloudFormation templates provided by Esri, you can use the corresponding 12.1 CloudFormation upgrade template to upgrade to 12.1.
The following table lists corresponding deployment and upgrade templates and provides links to instructions for using the upgrade templates:
Deployment template
Upgrade template
Instructions to use upgrade template
arcgis-datastore-singlemachine.template.json
arcgis-datastore-singlemachine-upgrade.template.json
Upgrade a single-machine ArcGIS Data Store using CloudFormation
arcgis-datastore-primarystandby.template.json
arcgis-datastore-primarystandby-upgrade.template.json
Upgrade a primary-standby ArcGIS Data Store deployment using CloudFormation
