Configure clustering
If your map has a layer with a large number of points, you can aggregate your data using clustering to extract meaningful information from the data. When you enable clustering, Map Viewer groups point features that are within a certain distance of one another on the map into one symbol. Clustering allows you to see patterns in the data that are difficult to visualize when a layer contains hundreds or thousands of points that overlap and cover each other.
If your layer is styled by category, clusters show the predominant category in each cluster. You can also use pie chart clusters to show the proportions of categories in each cluster.
Tip:
For recommendations on applying clustering to high-density datasets, see Best practices for visualizing high-density data.
Clusters are represented by proportionally sized symbols based on the number of point features in each cluster. Smaller cluster symbols have fewer points, while larger cluster symbols have more points. You can adjust the size range applied to the cluster symbols.
Clustering is applied dynamically at multiple scales, which means that as you zoom out, more points are aggregated into fewer groups, and as you zoom in, more cluster groups are created. When you zoom to a level at which the clustering area around one point feature no longer contains other features, that point feature is not clustered; it is displayed as a single point feature with the styling options applied to the layer. You can adjust the number of point features grouped into clusters by setting the cluster radius.
Nonchart clusters appear on the map with a default label. All types of clusters have a default pop-up that appears when you click a cluster on the map. You can customize the cluster pop-up and labels.
Enable clustering
When you enable clustering on a point layer, clusters automatically appear on the map using a default configuration. As you make changes to the cluster settings, the changes are immediately shown on the map. This allows you to experiment with cluster radius and other settings to achieve the desired look and message of your map.
To enable clustering on a point layer, do the following:
  1. Confirm that you are signed in and, if you want to save your changes, that you have privileges to create, update, and delete content.
  2. In Map Viewer, open the map containing the layer, or add the layer directly.
  3. On the Contents (dark) toolbar, click Layers .
  4. In the Layers pane, select the layer on which you want to enable clustering.
  5. On the Settings (light) toolbar, click Aggregation .
  6. In the Aggregation pane, turn on the Enable aggregation toggle button.
  7. Choose one of the following:
  8. On your chosen clustering style, click Options and do any of the following to change the appearance of the clusters:
    • For Clustering, optionally turn on the Override cluster symbol toggle button.
      Clusters inherit the style options you configure for the layer. Turning on the Override cluster symbol toggle button allows you to style the clusters separately. Overriding the cluster symbol can help differentiate clusters from unclustered features in the same layer. See Use style options for more information on changing the symbol style.
    • For Clustering (chart), adjust the Shape slider to change the chart appearance from pie to donut.
    • Adjust the Cluster radius slider to change the number of features that are grouped into a cluster. Specify a lower cluster radius to group fewer features into each cluster. Specify a higher cluster radius to group more features into each cluster.
    • Adjust the Size range slider to set the minimum and maximum cluster size.
    • Adjust the Scale threshold slider or click the drop-down menu below the slider to choose a scale threshold level. When a scale threshold is set and you zoom in farther than the scale threshold, the map will draw unclustered features.
    • Add and edit fields to use in the clusters.
    • Customize the cluster labels.
    • Customize the cluster pop-ups.
  9. Close the Aggregation pane when you're finished.
Configure cluster fields
When you enable clustering, the clusters are created using one or more default fields. You can edit these fields, add new summary statistic fields for use in labels and pop-ups, and change the formatting. For example, you can change the number of decimal places that appear for a numeric field.
To configure cluster fields, do the following:
  1. Follow the steps of the Enable clustering section above.
  2. In the Clustering pane, click Cluster fields.
  3. Optionally, expand the default field and specify its properties:
    • Type a field alias in the text box.
    • If the default field is numeric, choose whether to use a thousands separator.
      Under Thousand separator, select Use locale preference from the drop-down menu to dynamically display thousands separators based on the viewer's locale.
  4. To add a new field, do the following:
    1. Click Add field.
      The field configuration options appear.
    2. Choose a data field from the drop-down menu.
      Tip:
      You can use a custom attribute expression written in Arcade instead of an attribute field to determine how the data is clustered. Click Add expression and use the editor window to create the expression.
      You can also use existing expressions to build new expressions; however, some variables may not work in all profiles—for example, an expression created for pop-ups may not work for aggregation. To use an existing expression, select it from the Suggestions tab under Existing.
      Date only and Time only fields are not supported for aggregate fields.
    3. If you used a custom attribute expression, under Field type, select the attribute field type.
    4. Choose a statistic type from the drop-down menu.
    5. Optionally, type a field alias in the text box.
    6. For number fields (such as population), select the number of decimal places to display and whether to use a thousands separator.
    7. For Date and Timestamp offset fields, select a date format from the Date format drop-down menu. Optionally, turn on the Show time toggle button and select an hour and time format for displaying time.
      Under Hour format, select Use locale preference from the drop-down menu to dynamically display time in 12- or 24-hour format based on the viewer's locale.
  5. To delete a field, click Options and choose Delete.
    The default fields used to create the cluster—for example, count and predominant value for a pie chart cluster—cannot be deleted.
The fields you configure are available for use in labels and pop-ups. Formatting changes are automatically applied to fields that are currently in use for the clusters.
Configure cluster labels
Labeling clusters is similar to labeling individual features in a layer. You control the label style—font, text size, placement, and so on. You can keep the labels simple by showing the number of features in each cluster, or, if the layer is styled using an attribute, you can use this attribute for the cluster label. For example, if the layer shows parcels by their value per square foot, you can configure the cluster label to show the average value per square foot of all the points in each cluster. Map Viewer also allows you to use a label filter to only display labels on clusters that meet the filter criteria.
Configuring label classes allows you to further customize cluster labels. For example, you can use label classes to label each cluster based on two attributes, such as the average earthquake magnitude and the earthquake count, using a different label style for each attribute. Cluster label classes are configured in the same way as label classes for features.
Any unclustered point feature displays a feature label if feature labels are enabled for the layer.
To configure cluster labels, do the following:
  2. In the Clustering pane, click Cluster label.
  3. In the Label features pane, turn on the Enable labels toggle button.
  4. Click Add label class to configure label classes, and specify the options for each class:
    See Configure labels for more information about label configuration.
    • Click the Label field selector, select a different field for the label, and click Replace.
      The default label field is the number of features in the cluster. If the layer is styled using an attribute, you can use the attribute as a label. To use a different summary statistic as a label, add a cluster field.
      Tip:
      You can use a custom attribute expression written in ArcGIS Arcade instead of an attribute field. Click Use expression , and use the editor window to create the expression.
      You can also use existing expressions to build new expressions; however, some variables may not work in all profiles—for example, an expression created for pop-ups may not work for styles. To use an existing expression, select it from the Suggestions tab under Existing.
    • Click Edit label filter, click Add expression, and set up a filter fo display labels on a subset of clusters. For more information, see Apply filters.
    • Click Edit label style. In the Label style window, change the label style options, including the font, text size and color, placement, offsets, and halo effect.
    • Adjust the Visible range slider to change the visible range for the cluster labels.
Configure cluster pop-ups
Cluster pop-ups appear when you click a cluster on the map. The information displayed in cluster pop-ups depends on the style applied to the layer. For example, if the Predominant category style is applied, the default cluster pop-up includes the value of the predominant attribute for each cluster. You can customize the cluster pop-ups to suit your needs.
Clicking an unclustered point feature displays a feature pop-up if feature pop-ups are enabled for the layer.
To configure cluster pop-ups, do the following:
  2. In the Clustering pane, click Cluster pop-ups.
  3. In the Pop-ups pane, customize the cluster pop-ups by doing any of the following:
    See Configure pop-ups for more information about pop-up configuration.
    • Optionally, click Attribute Expressions to create and modify Arcade expressions to use in the cluster pop-up.
    • Expand the Title section and type a title for the pop-up. You can enter static text and click Add field to select attribute fields from the data.
    • Click the Text content block and click the cluster pop-up text. Change the default content and click OK.
    • Click Add content, click the content type, and add content and media to the cluster pop-up, including images and attribute fields.
    • Drag the content blocks to new positions in the pop-up to change the order.
  4. Click the clusters on the map to view the pop-ups.
    To learn more about the individual features in a cluster, click Browse features on the pop-up and click the forward and back arrows to scroll through information for each feature. To go back to the summary information for the cluster, click the record count between the arrows.
    Tip:
    You can click Dock on the pop-up to lock the pop-up display to the top of the map. Click Undock to display pop-ups near their associated clusters.
Considerations
Keep the following in mind:
  • Clustering is supported for hosted point feature layers, ArcGIS Server 10.3.1 and later point feature layers that support pagination, CSV layers, and feature collections.
  • Clustering is not supported for multipoint feature layers.
  • The Heat Map style is not supported for layers with clustering enabled.
  • Publishing hosted tile layers from hosted feature layers is not supported for layers with clustering enabled.
  • Clustering is unavailable during an edit session and when using feature effects.
  • Override cluster symbol is not available for the Clustering (chart) style. Unclustered features are symbolized as charts.
  • Clustering (chart) supports a maximum of 10 slices per chart. If there are more than 10 categories in a cluster, the top 9 categories appear in the chart and all other values are grouped into Other.
