Report fields
Organization reports are a way for administrators to export important information about their organization's members and content. There are two types of reports available to administrators: member reports and item reports.
Member fields
Member reports allow you to download data about the members of your organization in a .csv file. The following is a table of fields included in a member report:
Field |
Description |
Username |
The user's ArcGIS Enterprise username. |
Name |
The user's first and last name. |
The email address associated with the user's account. |
Profile Visibility |
The visibility of the user profile: public, account or organization, or private. |
User Type |
The user's assigned user type. |
Role |
The user's assigned role. This can be either a default or a custom role. Account_user and account_publisher refer to the default roles of a user and publisher. |
Last Login Date |
The date the user last signed in to ArcGIS Enterprise. |
Date Created |
The date the user's ArcGIS Enterprise account was created. |
Add-On Apps |
The names of add-on apps for which the user is assigned a license. These licenses are in the Licenses section of My Settings for each user. |
# of Items Owned |
The number of items owned by the user. This number can include items that are not listed on the Content page of the portal website, such as offline map areas. |
# of Groups Owned |
The number of groups owned by the user. |
# of Groups Total |
The number of groups the user is a member of. |
Login Type |
The type of login used to sign in to the portal—for example, ArcGIS or OIDC (OpenID Connect). |
Member Account Status |
The status of a user's account. Account status is enabled unless an administrator has disabled the member account. |
Member categories |
If your organization has set up member categories, this field indicates the member categories assigned to members. |
Multifactor authentication |
If your organization has multifactor authentication (MFA) enabled, this field indicates whether the member has enabled MFA for their account. |
IdP Username |
The user's username in the identity provider. |
Item fields
Item reports allow you to download data about your organization's content in a .csv file. The following is a table of fields included in an item report:
Field |
Description |
Title |
The title of the content item. |
Item ID |
The ID of the item, useable in advanced search. For example, id:4e770315ad9049e7950b552aa1e40869 returns the item for that ID. |
Item Url |
The web address for the item. |
Item Type |
The item type. Options include Web Map, Web Mapping Application, Feature Collection, |
Date Created |
The date the item was created. |
Date Modified |
The most recent date the item was edited. |
Content Category |
The categories the item has been sorted into. This field is populated if your organization has categories set up and if categories have been used for the item. |
View Counts |
The number of times the item has been viewed. |
Owner |
The username of the member who owns the item. |
File Storage Size |
The amount of file storage charged for any service or file, measured in megabytes. |
Feature Storage Size |
The amount of feature storage charged for the data or table storage of a feature service, measured in megabytes. |
Share Level |
The share level of the item is one of the following:
# of Groups shared with |
The number of groups with which the item has been shared. |
Tags |
The terms used to tag the item. |
Number of Comments |
The number of comments on the item. |
Is Hosted Service |
A value of |
