Portal authentication configuration
The primary factor you should use to determine how you configure security in your ArcGIS Enterprise organization is the source of users and, optionally, groups. This source of users and groups is called your identity store. Users and groups within or outside your organization are managed through the identity store.
Understand identity stores
The identity store for your organization defines where the credentials of your portal accounts are stored, how authentication occurs, and how group membership is managed. The ArcGIS Enterprise organization supports two types of identity stores: built-in and organization-specific identity stores.
Built-in identity store
ArcGIS Enterprise can be configured to allow members to create accounts and groups. When enabled, you can use the Create an account link on the Sign In page to add a built-in account to your portal and start contributing content to the organization or access resources created by other members. When you create accounts and groups this way, you are using the built-in identity store, which performs authentication and stores account usernames, passwords, roles, and group membership.
You must use the built-in identity store to create the initial administrator account for your organization, but you can later switch to an organization-specific identity store. The built-in identity store is useful to get your organization up and running, and also for development and testing. However, production environments typically use an organization-specific identity store.
If you need to revert from an organization-specific identity store to a built-in identity store, you can do so by deleting any information in the User store configuration and Group store configuration text boxes in the Update Identity Store page within the Portal Administrator Directory. For more information, see the ArcGIS REST API documentation.
Organization-specific identity store
ArcGIS Enterprise is designed so you can use organization-specific accounts and groups to control access to your ArcGIS organization. For example, you can control access to the organization by using credentials from your Lightweight Directory Access Protocol (LDAP) server and identity providers that support Security Assertion Markup Language (SAML) 2.0 Web Browser Single Sign On. This process is described throughout the documentation as setting up organization-specific logins.
ArcGIS Enterprise is designed so you can use organization-specific accounts and groups to control access to your ArcGIS organization. For example, you can control access to the organization by using credentials from your Lightweight Directory Access Protocol (LDAP) server, Windows Active Directory server, and identity providers that support Security Assertion Markup Language (SAML) 2.0 Web Browser Single Sign On. This process is described throughout the documentation as setting up organization-specific logins.
The advantage of this approach is that you do not need to create additional accounts in the organization. Members use the login that is already set up in the organization-specific identity store. The management of account credentials, including policies for password complexity and expiration, is completely external to the organization. This enables a single sign-on experience so users do not need to reenter their credentials.
Similarly, you can also create groups that use the existing Windows Active Directory, LDAP, or SAML groups in your identity store. Also, organization-specific accounts can be added in bulk from the Active Directory, LDAP, or SAML groups in your organization. When members sign in, access to content, items, and data is controlled by the membership rules defined in the Active Directory, LDAP, or SAML group. The management of group membership is completely external to the organization.
For example, a recommended practice is to disable anonymous access to your organization, connect to the desired Active Directory, LDAP, or SAML groups in your organization, and add the organization-specific accounts based on those groups. In this way, you restrict access based on specific Active Directory, LDAP, or SAML groups in your organization.
Use an organization-specific identity store if your organization wants to set policies for password expiration and complexity, control access using existing LDAP or SAML groups, or use authentication over LDAP or public key infrastructure (PKI)-based client certificate authentication. Authentication can be handled at the web-tier level (using web-tier authentication), at the portal-tier level (using portal-tier authentication), or through an external identity provider (using SAML).
Use an organization-specific identity store if your organization wants to set policies for password expiration and complexity, control access using existing Active Directory, LDAP, or SAML groups, or use authentication over Integrated Windows Authentication (IWA) or public key infrastructure (PKI)-based client certificate authentication. Authentication can be handled at the web-tier level (using web-tier authentication), at the portal-tier level (using portal-tier authentication), or through an external identity provider (using SAML).
Using an Active Directory identity store, ArcGIS Enterprise supports authentication from multiple domains with a single forest, but it does not provide cross-forest authentication. To support organization-specific users from multiple forests, a SAML identify provider is required.
Support multiple identity stores
Using SAML 2.0, you can allow access to your organization using multiple identity stores. Users can sign in with built-in accounts and accounts managed in multiple SAML-compliant identity providers configured to trust one another. This is a good way to manage users who may reside within or outside your organization. For details, see Configure a SAML-compliant identity provider with a portal.
Configure built-in users and groups using the portal's identity store
No steps are necessary to configure the organization when using built-in users and groups; it is ready for built-in users and groups immediately after installing the software. If you are using organization-specific users, see the following sections and related links for more information.
Configure organization-specific logins
The following organization-specific identity providers can be configured. Authentication can be handled at the web tier (using ArcGIS Web Adaptor) or at the portal tier.
Web-tier authentication
If your organization is running on a Microsoft Windows server and you have a Windows Active Directory configured, you can use Integrated Windows Authentication to connect. This enables an automatic or single-sign on experience for users through web-tier authentication. To use Windows authentication, the ArcGIS Web Adaptor must be deployed to the Microsoft Internet Information Server (IIS) web server.
If you have a Lightweight Directory Access Protocol (LDAP) directory, you can use it with ArcGIS Enterprise. See Use LDAP and web-tier authentication for more information. To use LDAP, deploy the ArcGIS Web Adaptor to a Java application server such as Apache Tomcat, IBM WebSphere, or Oracle WebLogic.
If your organization has public key infrastructure (PKI)-based client certificate authentication, you can use certificates to authenticate communication using HTTPS. It is not possible to enable anonymous access when using client-certificate authentication. See Use LDAP and client certificate authentication to secure access for more information.
If your organization has public key infrastructure (PKI)-based client certificate authentication, you can use certificates to authenticate communication using HTTPS. When authenticating users, you can use Windows Active Directory or LDAP. To use Windows authentication, the ArcGIS Web Adaptor must be deployed to the Microsoft IIS web server. To use LDAP, the ArcGIS Web Adaptor must be deployed to a Java application server such as Apache Tomcat, IBM WebSphere, or Oracle WebLogic. It is not possible to enable anonymous access when using client-certificate authentication.
Portal-tier authentication
To allow access to the organization using both organization-specific and built-in identity stores without using SAML, you can use portal-tier authentication. This is achieved by configuring the portal with your LDAP identity store, and enabling anonymous access in your Java application server. When a user accesses the sign-in page, they will be able to sign in using either organization-specific credentials or built-in credentials. Organization-specific users will be required to enter their account credentials each time they sign in; automatic or single-sign on is not available. This type of authentication also allows anonymous users access to maps or other organization resources that are shared with everyone.
To allow access to the organization using both organization-specific and built-in identity stores without using SAML, you can use portal-tier authentication. This is achieved by configuring the portal with your Active Directory or LDAP identity store, and enabling anonymous access in Microsoft IIS or your Java application server. When a user accesses the sign-in page, they will be able to sign in using either organization-specific credentials or built-in credentials. Organization-specific users will be required to enter their account credentials each time they sign in; automatic or single-sign on is not available. This type of authentication also allows anonymous users access to maps or other resources that are shared with everyone.
When using portal-tier authentication, members sign in using the following syntax:
If using Active Directory, the syntax can be
domain\usernameorusername@domain. Regardless of how the member signs in, the username always displays asusername@domainin the organization.If using LDAP, the syntax is always
username. The organization also displays the account in this format.
Configure organization-specific logins using SAML
ArcGIS Enterprise supports all SAML-compliant identity providers. For more information, see Configure a SAML-compliant identity provider.
