Use Windows Active Directory and client certificate authentication to secure access
This topic is not relevant for ArcGIS Enterprise on Linux.
When using Windows Active Directory to authenticate users, you can use public key infrastructure (PKI)-based client certificate authentication to secure access to your organization.
To use Integrated Windows Authentication and client certificate authentication, you must use ArcGIS Web Adaptor (IIS) deployed to Microsoft's IIS web server. You cannot use ArcGIS Web Adaptor (Java Platform) to perform Integrated Windows Authentication. If you haven't done so already, install and configure ArcGIS Web Adaptor (IIS) with your portal.
Configure your portal with Windows Active Directory
First, configure the portal to use SSL for all communication. Then update your portal's identity store to use Windows Active Directory users and groups.
Configure the organization to use HTTPS for all communication
Complete the following steps to configure the organization to use HTTPS:
Sign in to the organization website as an administrator.
The URL is in the format
https://webadaptorhost.example.com/webadaptorname/home.Click Organization and click the Settings tab, and then click Security on the left side of the page.
Enable Allow access to the portal through HTTPS only.
Update your portal's identity store
Next, update your portal's identity store to use Active Directory users and groups.
Sign in to the Portal Administrator Directory as an administrator of your organization.
https://webadaptorhost.example.com/webadaptorname/portaladmin.Click Security > Config > Update Identity Store.
In the User store configuration (in JSON format) text box, paste your organization's Windows Active Directory user configuration information (in JSON format).
Alternatively, you can update the following sample with user information specific to your organization:
{ "type": "WINDOWS", "properties": { "userPassword": "secret", "isPasswordEncrypted": "false", "user": "mydomain\\winaccount", "userFullnameAttribute": "cn", "userEmailAttribute": "mail", "userGivenNameAttribute": "givenName", "userSurnameAttribute": "sn", "caseSensitive": "false" } }In most cases, you'll only need to alter values for the
userPasswordanduserparameters. Although you type the password in clear text, it will be encrypted when you click Update Configuration (below). The account you specify for the user parameter only needs permissions to look up the email address and full name of Windows accounts on the network. If possible, specify an account whose password does not expire.In the rare case where your Windows Active Directory is configured to be case sensitive, set the caseSensitive parameter to true.
To create groups in the portal that leverage the existing Active Directory groups in your identity store, paste your organization's Windows Active Directory group configuration information (in JSON format) in the Group store configuration (in JSON format) text box as shown below. To use the portal's built-in groups, delete any information in the text box and skip this step.
Alternatively, you can update the following sample with group information specific to your organization.
{ "type": "WINDOWS", "properties": { "isPasswordEncrypted": "false", "userPassword": "secret", "user": "mydomain\\winaccount" } }In most cases, you'll only need to alter values for the
userPasswordanduserparameters. Although you type the password in clear text, it will be encrypted when you click Update Configuration (below). The account you specify for the user parameter only needs permissions to look up the names of Windows groups on the network. If possible, specify an account whose password does not expire.Click Update Configuration to save your changes.
If you've configured a highly available portal, restart each portal machine. See Stop and start the portal for full instructions.
Add organization-specific accounts
By default, organization-specific users can access the ArcGIS Enterprise organization. However, they can only view items that have been shared with everyone in the organization. This is because the organization-specific accounts have not been added and granted access privileges.
Add accounts to your organization using one of the following methods:
Individually or in bulk (one at a time, in bulk from a
.csvfile, or from existing Active Directory groups)
It's recommended that you designate at least one organization-specific account as an administrator of your portal. You can do this by choosing the Administrator role when adding the account. When you have an alternate portal administrator account, you can assign the initial administrator account to the User role or delete the account. See Delete the initial administrator account for more information.
Once the accounts have been added and you complete the steps below, users can sign in to the organization and access content.
Install and enable Active Directory Client Certificate Mapping Authentication
Active Directory Client Certificate Mapping is not available in the default installation of IIS. You must install and enable the feature.
Install Active Directory Client Certificate Mapping Authentication
Complete the following steps to install Client Certificate Mapping on Windows Server 2016, 2019, 2022, and 2025:
Open Server Manager.
In the Server Manager Dashboard, click Add roles and features.
The Add Roles and Features Wizard appears.
Accept the default settings and click Next on the Before You Begin, Installation Type, and Server Selection pages.
On the Server Roles page, enable Web Server (IIS).
On the dialog box that appears, click Add Features and click Next.
On the Features and Web Server Role (IIS) pages, click Next.
On the Role Services page, expand the Security section, select Client Certificate Mapping Authentication, and click Next.
On the Confirmation page, click Install.
When the installation completes, click Close to close the wizard.
Enable Active Directory Client Certificate Mapping Authentication
After you install Active Directory Client Certificate Mapping, complete the following steps to enable the feature:
Start Internet Information Server (IIS) Manager.
In the Connections node, click the name of your web server.
Double-click Authentication in the Features View window.
Verify that Active Directory Client Certificate Authentication is displayed.
If the feature is not displayed or unavailable, you may need to restart your web server to complete the installation of the Active Directory Client Certificate Authentication feature.
Double-click Active Directory Client Certificate Authentication and choose Enable in the Actions window.
A message appears indicating that SSL must be enabled to use Active Directory Client Certificate Authentication. You'll address this in the next section.
Configure ArcGIS Web Adaptor to require SSL and client certificates
Complete the following steps to configure ArcGIS Web Adaptor to require SSL and client certificates:
Start Internet Information Services (IIS) Manager.
Expand the Connections node and select your ArcGIS Web Adaptor site.
Disable all forms of authentication.
Select your ArcGIS Web Adaptor from the Connections list again.
Double-click SSL Settings.
Enable the Require SSL option, and choose the Require option under Client certificates.
Click Apply to save your changes.
For client certificate authentication to work on Microsoft Windows Server 2022, TLS 1.3 must be disabled under the HTTPS site bindings.
Verify you can access the portal using Windows Active Directory and client certificate authentication
Complete the following steps to verify you can access the portal using Windows Active Directory and client certificate authentication:
Open the portal.
https://organization.example.com/<context>/home.Verify that you are prompted for your security credentials and can access the website.
Prevent users from creating their own built-in accounts
If you enabled users to create their own built-in portal accounts before configuring IWA, they will still be able to do so after you've configured it. For more information on how to control the creation of new accounts, see Allow users to add their own accounts.
