Add members to your portal
You can allow users to add their own accounts using the portal. You can also add built-in accounts individually or in bulk using the portal. A command line utility is also available for you to add built-in or SAML-based accounts in bulk.
If the portal has been configured to access your organization's Windows Active Directory (AD), LDAP, or SAML groups, organization-specific accounts can be added in bulk based on their Active Directory, LDAP, or SAML group membership.
If you're using the portal's built-in store to manage members, the member's account is added to the built-in identity store and appears in the portal. The account information is stored in the portal.
If you're using organization-specific logins or identity store to manage members, the account information is read from the organization-specific identity provider and appears as an entry in the portal. The account authentication information is not stored in the portal.
To learn more about how members are managed in the portal, see Manage access to your organization. For full instructions on how to add members to your portal, see the steps in the sections below.
Allow users to add their own accounts
Users can add their own organization-specific accounts or portal accounts.
Organization-specific accounts
If your portal is configured with an organization-specific identity store, you can configure the portal to register these accounts with it the first time the organization-specific accounts connect to it. By default, new installations of portal do not allow accounts from an organization-specific identity store to be registered to the portal automatically. For full instructions on how to configure your portal to allow this, see Automatic registration of organization-specific accounts.
Built-in portal accounts
By default, the portal does not allow users to create built-in accounts using the Sign In page. If your portal uses built-in accounts, you can allow users to add their own accounts by doing the following:
  1. Verify that you are signed in as an administrator of your organization.
  2. Choose a default user type and role to be assigned to new members.
  3. Click Organization > Settings > Security.
  4. Check the box next to Allow users to create new built-in accounts.
    A warning indicates that your portal will restart automatically upon clicking Save.
  5. Click Save.
    Your portal restarts, which may take a couple of minutes. Once the restart is complete, the page reloads.
Once the steps above are complete, you can send the portal URL to the people in your organization who need to use the portal. These people can paste the URL in a web browser and create their own account by doing the following:
  1. From the portal home page, click Sign In.
    You'll also see this page if you attempt to save a map without signing in.
  2. Click Create an account.
  3. Provide your username, password, first name, last name, and email address, and choose a security question and provide an answer to it.
    Usernames must be between 6 and 128 characters long and may contain only alphanumeric characters and the following special characters: ., _, @, -. Usernames cannot begin or end with a special character, and some areas of ArcGIS Enterprise require that you enter a case-sensitive username.
    Passwords must follow the organization's password policy, and weak passwords may not be accepted.
  4. Click Create account.
An account is added to the portal's identity store, and the user is signed in to the portal.
Add accounts using the portal
Using the portal, you can add built-in or organization-specific accounts to the organization. Accounts can be added individually or in bulk using a comma-separated values (.csv) file.
It is recommended that you use the CreateUsers command line utility to add more than a thousand users at once.
If the portal has been configured to access your organization's Active Directory, LDAP, or SAML groups, organization-specific accounts can be added from Active Directory, LDAP, or SAML groups in your organization.
Add built-in members
You can add built-in members one at a time or in bulk from a file.
Add one at a time
To add members one at a time, complete the following steps:
  2. Click Organization > Members > Add members.
  3. On the Add members page, under Method, select the Add built-in portal members option and click Next.
  4. Click the New member tab and provide the following information:
    • First name—The user's first name (for example, Jon).
    • Last name—The user's last name (for example, Cho).
    • Email address—An email address for the user, for example, jcho@email.com. If an email address is not available, use the email address of the administrator. The email address cannot contain an apostrophe.
    • Username—The username alias for the account. The username is populated automatically based on the default username format specified for the organization. You can modify it as desired (for example, jcho11). The username must be between 6 and 128 ASCII characters. Some areas of ArcGIS Enterprise require that you enter a case sensitive username. You must inform the user of their username.
    • User type—The user type to which the user will be assigned. Select any available user type from the drop-down list. You can click the compatible roles and compatible add-on licenses count to find out more about what is compatible with the selected user type. For more information, see User types.
    • Role—The role to which the member will be assigned. This can be any role (viewer, user, publisher, data editor, custom role, or administrator role) that is compatible with the selected user type.
    • Password—A password for the account (for example, jcho.1234). The password must be at least eight characters and have at least one number and letter. You must inform the user of their password. It's recommended that you encourage the user to change their password after signing in for the first time.
  5. Click Next to complete adding this user, or click Next, add another to add more users.
  6. On the Compile member list page, review the list of members that will be added to the organization. Select and click Remove to remove members from the list if needed. Click Next.
  7. On the Set member properties page, assign add-on licenses, groups, and settings to the selected members.
    1. If you want to assign add-on licenses to the new members and default add-on licenses have not been configured for new organization members (or you want to modify the specified default add-on licenses for the new members), click Manage in the Add-on licenses section. Select the add-on licenses that are compatible with the user types in your member list and click Save.
      You only see this option if you have privileges to manage licenses.
      If you're adding more than one member at a time with different user types, the available licenses are based on the user type with the fewest compatible add-on licenses. For example, if you're adding four Creators and one Contributor, and you want to assign ArcGIS AllSource, the option won't be available because it's not compatible with both user types. You can click Compile member list to return to the list of new members, select the member with the incompatible user type, and click Remove so you can assign the license. Otherwise, you can assign the add-on licenses later on the Licenses tab.
    2. In the Groups section, if you want to add the new members to groups in your organization and default groups have not been configured for new members (or if you want to modify the specified default groups for the new members), click Manage. Select the desired groups and click Save.
    3. In the Member categories section, if your organization has set up member categories and you want to assign member categories to the new members, click Assign categories. Select up to 20 categories to assign and click Save.
      You only see this option if the organization has configured member categories and you have the administrative privilege to update member information.
    4. In the Settings section, modify the following member settings: profile visibility, language, number and date format, and a member's start page.
      You only see these options if you have privileges to update members.
  8. Click Next.
  9. Review the summary page to ensure the details are correct, and select Add Members to add the new members to your organization.
The member accounts are added to the portal. The users can now sign in using the credentials you specified.
Add from a file
To add members from a file, complete the following steps:
  1. Create a plain-text .csv file that contains a header (first line) with the following fields: First Name, Last Name, Email, Username, Role, User Type, and Password.
    Field names must be spelled correctly. The fields can be separated with a comma, semicolon, or tab.
    Tip:
    To download a UTF-8 encoded .csv file with the required fields prepopulated in your specified language, click Download CSV template on the Add members from a file page (step 6 below).
    Subsequent lines include the actual member account information as follows:
    • First Name—The user's first name (for example, Jon).
    • Last Name—The user's last name (for example, Cho).
    • Email—An email address for the user, for example, jcho@email.com. If an email address is not available, use the email address of the administrator. The email address cannot contain an apostrophe.
    • Role—The role to which the user will be assigned. This can be any role (viewer, user, publisher, data editor, custom role, or administrator role).
    • User Type—The user type to which the user will be assigned. This can include any user type available to your organization. For more information, see User types.
    The format for the file is as follows:
    First Name,Last Name,Email,Username,Role,User Type,Password
    Jon,Cho,jcho11@email.com,jcho11,publisher,Creator,jcho.1234
    Satish,Rajhandas,srajhandas@email.com,srajhandas,viewer,Viewer,sraj.abcd1
  2. Save the document as a plain-text .csv file and close it.
  3. Verify that you are signed in as an administrator of your organization.
  4. Click Organization > Members > Add Members.
  5. On the Add members page, under Method, select the Add built-in portal members option and click Next.
  6. Click the New members from a file tab and click Browse to select the .csv file. Click Open.
    The file is checked for field errors. If errors are found, click Edit beside the listed error, fix the error, and click Save. To remove a member with invalid properties, check the box beside the member name and click Remove. Alternatively, you can fix the errors directly in your file and click Choose a different file to select the updated file.
  7. On the Compile member list page, review the list of members that will be added to the organization and remove members from the list if needed. Click Next.
  8. On the Set member properties page, assign add-on licenses, groups, and settings to the selected members.
    1. If you want to assign add-on licenses to the new members and default add-on licenses have not been configured for new organization members (or you want to modify the specified default add-on licenses for the new members), click Manage in the Add-on licenses section. Select the add-on licenses that are compatible with the user types in your member list and click Save. (You only see this option if you have privileges to manage licenses.)
  9. Review the summary page to ensure the details are correct, and select Add members to add the new members to your organization.
Add members using their organization-specific logins
You can add members directly to the organization by creating ArcGIS accounts that the member can access using an organization-specific login. This option is only available if your organization has configured SAML logins or OpenID Connect logins. You can add members one at a time or in bulk using a .csv file.
Add one at a time
  3. Select the Add members for organization-specific logins option and click Next.
    • Email address—Email address for the user, for example, jcho@email.com. If an email address is not available, use the email address of the administrator. The email address cannot contain an apostrophe.
    • Identity type—If your organization has both SAML and OpenID Connect configured, select the Identity type option you want to use.
    • User identifier—The user identifier for the account. The user identifier must match the corresponding value in the SAML or OpenID Connect identity provider (IdP). If it doesn't match, the ArcGIS account will be created but cannot be used. Verify that the SAML or OpenID Connect user identifier is correct before proceeding.
      For SAML logins, the user identifier must match the value returned by the SAML IdP in the NameID attribute of the SAML assertion response. In the following example, the user identifier value in the SAML assertion response is John.Smith.23511.
      <samlp:Response>
              <Assertion>
                      <Subject>
                               <NameID>John.Smith.23511</NameID>
                      </Subject>
              </Assertion>
      </samlp:Response>
      To view the SAML assertion response, you must use a SAML tracer extension in your web browser.
      For OpenID Connect logins, if you did not specify a custom value for the optional User identifier claim when configuring the login, the user identifier value must match the value of the subject identifier (sub) attribute sent in the ID token from the OpenID Connect provider (for example, the Google ID Token from Google) to ArcGIS. The subject identifier uniquely identifies each user. For example, the sub value may be 10769150350006150715113082367 for Google user jsmith or auth0|123456 for Auth0 user Jane Doe.
      In the following sample Microsoft Identity OpenID Connect ID token, the custom oid attribute is configured as the User identifier claim value and the user identifier value for the user Abe Lincoln is 05833b6b-aa1d-42d4-9ec0-1b2bb9194438.
        "typ": "JWT",
        "alg": "RS256",
        "x5t": "7_Zuf1tvkwLxYaHS3q6lUjUYIGw",
        "kid": "7_Zuf1tvkwLxYaHS3q6lUjUYIGw"
        "aud": "b14a7505-96e9-4927-91e8-0601d0fc9caa",
        "iss": "https://sts.windows.net/fa15d692-e9c7-4460-a743-29f2956fd429/",
        "iat": 1536275124,
        "nbf": 1536275124,
        "exp": 1536279024,
        "aio": "AXQAi/8IAAAAqxsuB+R4D2rFQqOETO4YdXbLD9kZ8xfXadeAM0Q2NkNT5izfg3uwbWSXhuSSj6UT5hy2D6WqApB5jKA6ZgZ9k/SU27uV9cetXfLOtpNttgk5DcBtk+LLstz/Jg+gYRmv9bUU4XlphTc6C86Jmj1FCw==",
        "amr": [
          "rsa"
        "email": "abeli@microsoft.com",
        "family_name": "Lincoln",
        "given_name": "Abe",
        "idp": "https://sts.windows.net/72f988bf-86f1-41af-91ab-2d7cd011db47/",
        "ipaddr": "131.107.222.22",
        "name": "abeli",
        "nonce": "123523",
        "oid": "05833b6b-aa1d-42d4-9ec0-1b2bb9194438",
        "rh": "I",
        "sub": "5_J9rSss8-jvt_Icu6ueRNL8xXb8LF4Fsg_KooC2RJQ",
        "tid": "fa15d692-e9c7-4460-a743-29f2956fd429",
        "unique_name": "AbeLi@microsoft.com",
        "uti": "Lxe_46GqTkOpGSfTln4EAA",
        "ver": "1.0"
      }.[Signature]
    • ArcGIS username—This option is only available if you specified a custom value for the optional ArcGIS username claim value when configuring the OpenID Connect login. The ArcGIS username must match the value of the corresponding attribute sent in the ID token from the OpenID Connect provider.
      In the following sample Microsoft Identity OpenID Connect ID token, the custom unique_name attribute is specified for the ArcGIS username claim value and the ArcGIS username value is AbeLi@microsoft.com.
        "typ": "JWT",
        "alg": "RS256",
        "iat": 1536275124,
        "nbf": 1536275124,
        "exp": 1536279024,
        "amr": [
          "rsa"
        "name": "abeli",
        "nonce": "123523",
        "rh": "I",
        "ver": "1.0"
      }.[Signature]
  7. On the Set member properties page, assign licenses, apps, groups, and settings to the selected members. Click Next.
  8. Review the summary page to ensure the details are correct, and select Add Members to add the new members to your organization.
The member accounts are added to the organization. The user can now sign in to the portal.
Add from a file
  1. Create a plain-text .csv file that contains a header (first line) with the required fields.
    Tip:
    • Identity type—This information is only required if your organization has both SAML and OpenID Connect configured.
      <samlp:Response>
              <Assertion>
                      <Subject>
                      </Subject>
              </Assertion>
      </samlp:Response>
      For OpenID Connect logins, if you did not specify a custom value for the optional User identifier claim value when configuring the login, the user identifier value must match the value of the subject identifier (sub) attribute sent in the ID token from the OpenID Connect provider (for example, the Google ID Token from Google) to ArcGIS. The subject identifier uniquely identifies each user. For example, the sub value may be 10769150350006150715113082367 for Google user jsmith or auth0|123456 for Auth0 user Jane Doe.
        "typ": "JWT",
        "alg": "RS256",
        "iat": 1536275124,
        "nbf": 1536275124,
        "exp": 1536279024,
        "amr": [
          "rsa"
        "name": "abeli",
        "nonce": "123523",
        "rh": "I",
        "ver": "1.0"
      }.[Signature]
    • ArcGIS username—This information is only required if you specified a custom value for the optional ArcGIS username claim value when configuring the OpenID Connect login. The ArcGIS username must match the value of the corresponding attribute sent in the ID token from the OpenID Connect provider.
        "typ": "JWT",
        "alg": "RS256",
        "iat": 1536275124,
        "nbf": 1536275124,
        "exp": 1536279024,
        "amr": [
          "rsa"
        "name": "abeli",
        "nonce": "123523",
        "rh": "I",
        "ver": "1.0"
      }.[Signature]
    If your organization has both SAML and OpenID Connect configured, the format for the file is as follows:
    First Name,Last Name,Email,Identity Type,User identifier,Role,User Type
    Jon,Cho,jcho@email.com,SAML,jcho11,publisher,Professional Plus
    Satish,Rajhandas,srajhandas@email.com,SAML,srajhandas,viewer,Viewer
    If your organization has only SAML or OpenID Connect configured, the format for the file is as follows:
    First Name,Last Name,Email,User identifier,Role,User Type
    Jon,Cho,jcho@email.com,jcho11,publisher,Professional Plus
    If your organization has only OpenID Connect configured with custom ArcGIS username, the format for the file is as follows:
    First Name,Last Name,Email,Role,User Type,User identifier,ArcGIS username
    Jon,Cho,jcho@email.com,publisher,Professional Plus,jcho11,JCho@email.com
    Satish,Rajhandas,srajhandas@email.com,viewer,Viewer,srajhandas,SRajhandas@email.com
  4. Click Organization > Members > Add members.
  5. Select the Add members for organization-specific logins option and click Next.
  7. On the Compile member list page, review the list of members that will be added to the organization. Select and click Remove to remove members from the list if needed. Click Next.
  8. On the Set member properties page, assign licenses, apps, groups, and settings to the selected members. Click Next.
The member accounts are added to the organization. The users can now sign in to the portal.
Add members from AD or LDAP identity providers
If your portal has been configured with an organization-specific identity provider based on Active Directory (AD) or Lightweight Directory Access Protocol (LDAP), organization-specific accounts can be added individually, in bulk, or from AD or LDAP groups managed by the identity provider.
Accounts must include an email address to be added to the portal. Any special characters in account names will be changed to an underscore (_), except the at sign (@), point (.), or dash (-).
Add one at a time
  3. On the Add members page, select the Add members based on existing Active Directory or LDAP users option and click Next.
    • Username—The username alias for the account. The username must match the existing Active Directory or LDAP user and format defined in the identity provider (for example, jcho11). Click the magnifying glass to search for and select the desired username.
    • User Type—The user type to which the user will be assigned. Select any available user type from the drop-down list. You can click the compatible roles and compatible add-on licenses count to find out more about what is compatible with the selected user type. For more information, see User types.
  5. Click Next to complete adding this user, or Next, add another to add more users.
  7. On the Set member properties page, you can assign licenses, apps, groups, and settings to the selected members. Click Next.
  8. Verify that the member account information is correct and click Add members.
The member account is added to the organization. The user can now sign in to the portal.
Add from a file
  1. Create a plain-text .csv file that contains a header (first line) with the following fields: Username, Role, and User Type.
    Tip:
    • Username—The username alias for the account. The username must match the existing Active Directory or LDAP user and format defined in the organization-specific identity provider (for example, jcho11).
    jcho11,publisher,Contributor
    If you add Windows Active Directory users, use the following format:
    domain\jcho11,publisher,Contributor
    domain\srajhandas,viewer,Viewer
  5. Select the Add members based on existing Active Directory or LDAP users option and click Next.
Add from a group
If your portal has been configured with AD or LDAP-based groups, you can add accounts from the AD or LDAP groups you've connected to your portal. See Create groups for more information.
  3. Select the Add members based on existing Active Directory or LDAP users option and click Next.
  4. Click the From a group tab and provide the following information:
    • Active Directory or LDAP Group—The Active Directory or LDAP group name. Click the magnifying glass to search for and select the desired Active Directory or LDAP group.
    • Role—The role to which the selected accounts will be assigned. This can be any role (viewer, user, publisher, data editor, custom role, or administrator role).
    • User Type—The user type to which the member will be assigned. For more information, see User types.
  5. On the Compile member list page, review the list of members that will be added to the organization. Select and click Remove to remove members from the list if needed. Click Next.
  6. On the Set member properties page, assign licenses, apps, groups, and settings to the selected members. Click Next.
    If your group is from a Windows Active Directory server, members of nested groups are also added to the portal.
    If your group is from an LDAP server, members of nested groups are not added to the portal.
  7. Review the summary page to ensure the details are correct, and select Add members to add the new members to your organization.
Add members in bulk using a command line utility
Adding members in bulk is useful if you want to add multiple built-in or organization-specific accounts to the portal at once. The CreateUsers tool is located in the <Portal for ArcGIS installation location>/tools/accountmanagement directory. The tool takes a text file as input and must be run on the machine where the portal is installed. The tool will automatically assign add-on licenses and groups as specified in the new member defaults as long as they're compatible with the new member's user type. If either the name or description (described below) includes non-English characters, save the input file as UTF-8; otherwise, non-English characters will not save properly.
Adding members in bulk is useful if you want to add multiple built-in or organization-specific accounts to the portal at once. The CreateUsers tool is located in the <Portal for ArcGIS installation location>\tools\accountmanagement directory. The tool takes a text file as input and must be run on the machine where the portal is installed. The tool will automatically assign add-on licenses and groups as specified in the new member defaults as long as they're compatible with the new member's user type. If either the name or description (described below) includes non-English characters, save the input file as UTF-8; otherwise, non-English characters will not save properly.
The utility can only be run by a built-in administrator account; you cannot use an organization-specific administrator account. The built-in account you use can be the initial administrator account you set up when you configured the portal or another built-in account that has been granted administrator privileges. If you deleted the initial administrator account and do not have any other built-in administrator accounts available, you must create one to run the utility. For instructions, see the Built-in portal accounts section above.
Register organization-specific accounts
By default, new installations of Portal for ArcGIS do not allow users to register their organization-specific accounts automatically the first time they sign in. Therefore, you must preregister your organization-specific users with the CreateUsers command line utility tool. If you want organization-specific users to be able to register their own accounts, you can enable automatic registration of organization-specific accounts.
  1. Create a text file that contains information for registering organization-specific accounts. Use a separate line for each account, and separate values using pipes (|).
    The format for each entry is as follows:
    <login>|<email address>|<name>|<role>|<user type id>|<description>|<IdP UserName>|<first name>|<last name>
    • login—The login is the organization-specific login to be registered. Logins must contain alphanumeric ASCII characters or underscores and can contain up to 128 characters.
      • If you're using Active Directory, this login should be in the form sAMAccountName@DOMAIN. The domain name must be in all capital letters.
      • If you're using LDAP, the login should match the value of the userNameAttribute you specified when configuring the identity store.
      • If you're using SAML-based organization-specific logins, the login value specified should match the NameID attribute in the SAML identity provider.
      • If you're using OpenID Connect-based organization-specific logins, the login value specified should match the unique identifier assigned to each user by the OpenID Connect provider (for example, Google).
    • email address—The email address should be the email associated with the login and match the value in the identity store. If the user account does not have an email address, provide a false or generic value.
    • name—The name is the alias for the login that will be used in your ArcGIS organization. Most identity stores use the user's full name as the default alias. When the user is connected to the portal, this name appears at the top of the website.
    • role—This is the role the organization-specific login will have in the organization. Valid role values are viewer, user, publisher, data editor, admin, or <custom_role_name>, where <custom_role_name> is the name of the custom role (for example, hostedservicepublisher).
      Ensure that the roles that are specified correspond with a compatible user type. For more information, see User types.
    • description—Optionally, you can include text to describe the account. This value does not correspond to any attribute in the identity store. Descriptions cannot exceed 250 characters.
    • IdP UserName—Optionally, you can specify the username of the organization-specific account in the identity provider. If this value is not provided, the value specified for the login parameter is used instead.
    • first name—Optionally, you can specify the user's first name. If this value is left blank or set to no firstName, the name parameter will be used. If the name parameter consists of more than one word, the first word before a space will be used for the first name. If the first name is left blank or set to no firstName and the name parameter is empty, the user will not be created.
    • last name—Optionally, you can specify the user's last name. If this value is left blank or set to no lastName, the name parameter will be used. If the name parameter consists of more than one word, the first word after a space will be used for the last name. If the last name is left blank or set to no lastName and the name parameter is empty, the user will not be created. If both the first and last name for a user are left blank or set to no firstName and no lastName and the name parameter contains one word, that word will be used for both the first and last names.
    • user type id—The ID of the user type to which the member will be assigned. The user type ID value is the name of the user type with UT appended to the end. Some examples of user type ID values for the standard user types include viewerUT, editorUT, fieldWorkerUT, creatorUT, GISProfessionalStdUT, and GISProfessionalAdvUT.
    You're required to provide a value for the login, email address, name, role, and user type. The description, IdP UserName, first name, and last name are optional. For each account listed in the file, verify that the values you entered for the login, email address, and name exactly match the values in your identity store. The portal will not connect to your identity store to validate these values.
    The following is an example of an entry to register an Active Directory organization-specific account for login jcho111, with an email address of jcho@example.com and a full name of Jon Cho. The login is placed in the user role (user) and a Creator user type and is described as a user in department b.
    jcho111@DOMAIN|jcho@example.com|Jon Cho|user|department b|creatorUT
    The following is an example of an entry to register an organization-specific account from a SAML identity provider. The user's login is rsmith@example.com, with an email address of rsmith@example.com and a full name of Robert Smith. The login is placed in the publisher role (publisher) with an IdP UserName of rsmith@example.com and a Creator user type.
    rsmith@example.com|rsmith@example.com|Robert Smith|publisher|rsmith@example.com|creatorUT
    The following is an example of an entry to register an LDAP organization-specific account for login sjames4513, with an email address of sjames@example.com and a full name of Sara James. The login is placed in the viewer role (admin) and a Viewer user type, and a description is provided.
    sjames4513@DOMAIN|sjames@example.com|Sara James|viewer|Department Lead and GIS Manager|viewerUT
    The following is an example of an entry to register an organization-specific account for login srajhandas, with an email address of srajhandas@example.com and a full name of Satish Rajhandas. The login is placed in the user role (user) and an Contributor user type.
    srajhandas@DOMAIN|srajhandas@example.com|Satish Rajhandas|user|editorUT
    The following is an example of an entry to register an organization-specific account from a SAML identity provider. The user's login is djohnson308, with an email address of djohnson@example.com and a full name of Daisha Johnson. The login is placed in the user role (user), with a description; the IdP UserName, which is defined as djohnson@example.com; and a Professional user type.
    djohnson308@DOMAIN|djohnson@example.com|Daisha Johnson|user|Account Specialist|djohnson@example.com|GISProfessionalStdUT
    The following is an example of an entry to register an organization-specific account from an OpenID Connect provider. The user's login is mbrown, with an email address of mbrown@example.com and a full name of Marie Brown. The login is placed in the publisher role (publisher) and a Creator user type, with a description; the IdP UserName, which is defined as 110565518009184644438; and a first name of Marie and a last name of Brown.
    mbrown|mbrown@example.com|Marie Brown|publisher|creatorUT|GIS Analyst|110565518009184644438|Marie|Brown
  2. Save the text file.
  3. Run the CreateUsers command line tool using one of the following methods:
    • To add OpenID Connect accounts, run the CreateUsers command line tool with the IdP option set to oidc_[idvalue] (for example, ./CreateUsers.sh --file usr/adminfiles/users.txt --idp oidc_[idvalue]). Replace idvalue with your Open ID Connect registration ID.
    • To add OpenID Connect accounts, run the CreateUsers command line tool with the IdP option set to oidc_[idvalue] (for example, CreateUsers --file C:\scripts\users.txt --idp oidc_[idvalue]). Replace idvalue with your Open ID Connect registration ID.
    • To add other organization-specific accounts, run the CreateUsers command line tool with the IdP option set to orgSpecific (for example, ./CreateUsers.sh --file usr/adminfiles/users.txt --idp orgSpecific).
    • To add other organization-specific accounts, run the CreateUsers command line tool with the IdP option set to orgSpecific (for example, CreateUsers --file C:\scripts\users.txt --idp orgSpecific).
    If you do not specify -idp, organization-specific accounts are registered by default. Also, be sure to use the correct case for command line options and file names.
Once users sign in to the portal, they can add or change the security question and answer by editing their account profiles.
Add built-in portal accounts
To add built-in portal accounts, complete the following steps:
  1. Create a text file that contains information for creating built-in portal members. Use a separate line for each account, and separate values using pipes (|).
    <account>|<password>|<email address>|<name>|<role>|<user type id>|<description>|<first name>|<last name>
    • account—The account is the username to be used for the built-in account. Accounts must contain alphanumeric ASCII characters or underscores and can contain up to 128 characters. Some areas of ArcGIS Enterprise require that you enter a case sensitive username.
    • password—This is a password to be assigned to the account. Users can use this password the first time they sign in to the portal, and then they can change their password by editing their profile.
    • email address—Provide an email address for this account. This parameter is required; therefore, you must provide a value for the email address even if it's not a valid address.
    • name—The name is the alias for the account that will be used in your ArcGIS organization. When the user is connected to the portal, this name appears at the top of the website.
    • role—This is the role the account will have in the ArcGIS organization. Valid role values are viewer, user, publisher, data editor, admin, or <custom_role_name>, where <custom_role_name> is the name of the custom role (for example, hostedservicepublisher).
    • description—Optionally, you can include text to describe the account. Descriptions cannot exceed 250 characters.
    • user type id—The ID of the user type to which the member will be assigned. The user type id value is the name of the user type with UT appended to the end. Some examples of user type id values for the standard user types include viewerUT, editorUT, fieldWorkerUT, creatorUT, GISProfessionalStdUT, and GISProfessionalAdvUT.
    The following is an example of an entry that adds a built-in portal account with the username bwills2 for Barbara Williams and an email account of bwilliams@example.com. It also adds bwills2 to the publisher role and the Professional Plus user type:
    bwills2|changepasswordlater1|bwilliams@example.com|Barbara Williams|publisher|GISProfessionalAdvUT
    The following is an example of an entry that adds a built-in portal account with the username jocho1 for Jon Cho and an email account of jcho@example.com. It also adds jocho1 to the administrator role and the Creator user type, describes it as the GIS manager, and lists the first and last names for the user:
    jocho1|changepasswordlater1|jcho@example.com|Jon Cho|admin|creatorUT|GIS Manager|Jon|Cho
  3. Run the CreateUsers command line tool with the IdP option set to builtin (for example, ./CreateUsers.sh --file portalmembers.txt --idp builtin).
  4. Run the CreateUsers command line tool with the IdP option set to builtin (for example, CreateUsers --file D:\scripts\addmembers.txt --idp builtin).
    If you do not specify -idp, organization-specific accounts are registered by default. Be sure to use the correct case for command line options and file names.
Once users sign in to the portal, they can add or change the security question and answer by editing their account profiles. Users can also change their passwords by editing their account profiles.
