ArcGIS Data Store vocabulary
The following sections define terms related to ArcGIS Data Store. Because ArcGIS Data Store is part of an ArcGIS Enterprise deployment, additional terms are included here to clarify data stores in the overall context of ArcGIS Enterprise.
ArcGIS Data Store
ArcGIS Data Store is the software component that allows you to configure system storage for hosted layers in ArcGIS Enterprise.
Note that data store is a general term for any location where data is stored. ArcGIS Data Store allows you to configure a subset of data store types. The data stores you configure with ArcGIS Data Store are always used as part of an ArcGIS Enterprise deployment, the data in them is managed by ArcGIS, and the data storage locations are registered with your hosting server.
ArcGIS Data Store account
The ArcGIS Data Store account is the account you used to sign in to the machine when you installed ArcGIS Data Store.
The ArcGIS Data Store account is the account under which your ArcGIS Data Store service runs. You specify this account when you install ArcGIS Data Store.
See ArcGIS Data Store account for more information.
ArcGIS Data Store content directory
This is a directory you specify to store the files ArcGIS Data Store needs to run. This directory must be local to the ArcGIS Data Store installation on each machine.
This directory initially stores backup files for relational stores, but once you create a relational store, you should configure it to create backup files in a shared network location instead.
ArcGIS Enterprise
ArcGIS Enterprise is the product line that allows you to create a Web GIS. It includes ArcGIS Server, Portal for ArcGIS, ArcGIS Data Store, and ArcGIS Web Adaptor.
See What is ArcGIS Enterprise? for more information.
ArcGIS GeoEvent Server
ArcGIS Server sites are licensed to fill specific roles. An ArcGIS GeoEvent Server site is a stand-alone or federated server site that allows you to stream real-time data.
In the context of ArcGIS Data Store, a federated ArcGIS GeoEvent Server can archive data from stream services into a feature layer that runs on the hosting server. The archived data is stored in a spatiotemporal big data store. Note that when you delete the archiving feature layer from the portal, the feature service is not deleted and neither is the data stored in the spatiotemporal big data store.
See Manage spatiotemporal big data stores in the GeoEvent Server help for more information on archiving streamed data.
ArcGIS GIS Server
(ArcGIS GIS Server is also called GIS Server.)
ArcGIS Server sites are licensed to fill specific roles. An ArcGIS GIS Server site allows you to serve such GIS resources as map services, feature services, geoprocessing services (tools), geocoding services (locators), and geodata services.
A hosting server must be licensed as an ArcGIS GIS Server site to publish the types of services that hosted web layers require.
ArcGIS Image Server
ArcGIS Server sites are licensed to fill specific roles. An ArcGIS Image Server site is a stand-alone or federated server site that allows you to serve cached or dynamic image services.
In the context of ArcGIS Data Store, the ArcGIS Enterprise deployment with which you are using ArcGIS Data Store must have a federated ArcGIS Image Server site if you want to publish hosted image layers to the portal.
You can have multiple federated ArcGIS Image Server sites that fill different roles, such as the raster analysis server or image hosting server.
ArcGIS Knowledge Server
Knowledge graphs created in ArcGIS Pro run on an ArcGIS Knowledge Server site that is federated with the ArcGIS Enterprise deployment.
See Get started with ArcGIS Knowledge Server for more information.
ArcGIS Video Server
Adding an ArcGIS Video Server site to ArcGIS Enterprise allows you to stream web-enabled video services, and a video layer item is created in ArcGIS Enterprise. The ArcGIS Video Server site administrator configures storage for the video layer content: either on disk (the default), in the object store, or in a cloud store.
See ArcGIS Video Server for more information.
Integrating a cloud database service allows you to take advantage of the cloud provider's service level agreements, scalability, performance improvements, and additional backup and recovery options. However, your organization must have the expertise to create and manage the database service. ArcGIS Enterprise continues to manage the information model, data, and services, but you are responsible for managing the cloud database service.
data store
In the context of ArcGIS, a data store is any location where you keep the data used by ArcGIS.
In the specific context of ArcGIS Server, data stores are the file, database, geodatabase, or cloud storage locations you register with an ArcGIS Server site. Registering these locations with the ArcGIS Server site ensures the services you publish can access the data.
User-maintained data stores registered with ArcGIS Server point to your data source; the data is maintained in that data store and is not copied anywhere else. When a service is published to the ArcGIS Server site, the data that populates the service comes from this registered source data.
Data stores implemented through ArcGIS Data Store are also registered with ArcGIS Server (specifically, with the hosting server), but they are maintained by ArcGIS and the data is only accessible through the web layer. When you publish certain hosted web layers, ArcGIS copies data into one of these data stores.
See ArcGIS Server web services for more information.
federated server
A federated server is an ArcGIS Server site you have integrated into your ArcGIS Enterprise deployment. Federated servers share authentication with the rest of the ArcGIS Enterprise deployment and allow you to automatically create portal content items for the services you publish to the federated server.
See Federate a server site for more information.
GIS Server
See the ArcGIS GIS Server entry above.
graph store
The graph store is a capability-based system storage type for ArcGIS Enterprise. For more information, see Graph store.
hosted web layers
Hosted web layers are items that have corresponding services running on the hosting server. The one exception is hosted image layers; they run on a federated ArcGIS Image Server site rather than your hosting server.
Tip:
When the owner of the layer or the organization administrator opens the layer item's page in the portal, (hosted) is included in the layer type label on the Overview tab. When viewed in ArcGIS Pro, hosted layers are labeled as such when you view them in the Catalog pane or window.
The data that populates most of these services and, therefore, populates the hosted web layers is copied to ArcGIS Data Store when you publish. Hosted web layers require you to create a specific type of data store to hold this data. See the table in Introduction to ArcGIS Data Store to determine which type of data store you need for each type of hosted web layer. Hosted image layer data is copied to a registered file or cloud storage data store, not a data store created through ArcGIS Data Store.
When you delete a hosted web layer, the service is deleted from the ArcGIS Server site, and the data is deleted from the data store.
For more information on hosted web layers, see ArcGIS Server web services and Hosted layers.
hosting server
A hosting server is the GIS Server site that is federated with ArcGIS Enterprise and maintains storage requirements for hosted web layers.
See Behavior of a hosting server for more information.
location tracking service
This is a feature service that records the location of mobile users. The data that populates the location tracking service can be stored in the spatiotemporal big data store.
object store
The object store is a required system storage type for all ArcGIS Enterprise deployments. For more information, see Object store.
relational store
The relational store is a required system storage type for all ArcGIS Enterprise deployments. For more information, see Relational store.
A cloud relational store is a relational store configuration in which data is stored in a supported cloud database service instead of locally on the ArcGIS Data Store machine. For more information, see Considerations for using a cloud relational store.
The spatiotemporal big data store is a capability-based system storage type for ArcGIS Enterprise. For more information, see Spatiotemporal big data store.
