Items in ArcGIS Enterprise
Items are the contents made available through an ArcGIS Enterprise organization. Items include content such as files, layers (services), maps, scenes, apps, tools, and templates.
Some items are added as a result of the process of creating the content. For example, when you run an analysis tool, it may create a layer item that contains the analysis results. Similarly, when you create a dashboard or template in other apps, or when you create and save a map or scene, those are saved as items in the organization. Items are also created when you add files to Map Viewer.
In other cases, the content exists elsewhere—such as a file stored on your hard drive, a service available over the internet or your intranet, or an app or file available through a URL. You can add this content to make it available as an item in your organization if you have privileges to create, update, and delete content.
Files—You can add supported file types from your device or a network location in My content.
Content available through a URL—You can add and store a URL that references web services and documents or apps.
User-managed data storage locations—Add a data store item that provides access to data storage locations such as databases, network file shares, and cloud storage services.
When an item is added, the date that the item was created is recorded and displayed at the top of the Overview tab of the item page.
The items you add are accessible only to you until you share them.
