ArcGIS for Excel errors, messages, and warnings
The following sections and tables are a log that provides a list of errors, warnings, information, and validation messages you may encounter when using ArcGIS for Excel.
Message codes are defined as integers and organized into groups based on categories of service.
Add an ArcGIS layer
The following messages may occur when adding a layer from ArcGIS.
Learn more about ArcGIS layers
Code
Category
Title
Message
1001
Information
Web map cannot be added
There are no operational layers.
When adding a web map from ArcGIS Online, the source web map must contain operational layers such as a feature service, tile layer, or imagery layer.
1002
Information
Layer cannot be added
The coordinate system or tiling scheme must align with the basemap.
The layer coordinate system of a layer being added must match that of the basemap. Check the layer coordinate system and try again with an aligned layer.
1003
Warning
Layer cannot be added.
The layer cannot be added. Check the source item in your organization or contact your administrator.
1004
Error
Layer failed to fetch.
Your layer is unable to load on the map. Contact your administrator to troubleshoot.
1005
Information
Spatial reference incompatible.
This layer's spatial reference is incompatible with the spatial reference of the basemap. You can either use a different basemap and read the layer. Or you can open the item in ArcGIS Online and republish the item with a different coordinate system.
Learn more on the Incompatible with current basemap Technical Support page
1006
Error
The layer failed to copy.
Remove the layer you want to copy and add again or contact your administrator to check the layer properties in ArcGIS Online.
1007
Information
No access
You are currently signed in as Username. You do not have access to layer.
You do not have adequate permissions to add this content, for example, your user type, role, ArcGIS account, or organization settings do not allow this content, or if the content is private or not shareable. Contact your organization administrator for more information.
1008
Information
The layer contains no data.
Your layer has no features to display on the map.
1009
Information
Unsupported Version
The version must be 2.0 or higher. The webmap can be resaved to a newer version.
This happens when adding a layer from ArcGIS Online that contains an incompatible web map version. Go to ArcGIS Online, open the web map, and resave to a current version.
1010
Error
The layer was deleted or has become inaccessible.
Your layer has been deleted or become inaccessible. Check source layer or contact your organization administrator to troubleshoot.
1011
Warning
Query capability disabled
Check layer edit settings.
This appears when a layer does not have query capabilities and new geometries are recorded but hidden. To resolve, in the layer settings, change What features can editors see? from Editors can't see any features, even those they add to Editors can see all features.
Learn more on the Capability 'Query' is not set on the layer Technical Support page
1999
Warning
Unexpected error
Contact Esri Technical Support.
Add a data layer
The following messages may occur when adding a data layer from ArcGIS for Excel.
Learn more about adding a data layer
Code
Category
Title
Message
2001
Error
Adding data failed
Check your data source and try again.
Ensure your location data is correct and accessible.
2002
Error
The selected column doesn't contain any valid JSON geometry.
When adding Microsoft data as a JSON type, the geometry column must contain an attribute formatted in valid JSON format. Check your source data for import or formatting errors or choose a different attribute.
2003
Information
No ArcGIS World Geocoder or custom geocoders that support batching are configured
Contact your organization administrator.
Go to your portal and configure a geocoder that supports batching.
2004
Warning
Verify that your data has valid location information.
Your layer may not contain spatial data.
2005
Error
Layer failed to copy.
Remove the layer you want to copy, and add again.
2006
Error
The file contains invalid JSON.
JSON format not valid; check source data for formatting or other errors and try again or select a different attribute.
2007
Error
Unknown spatial reference
Check the format of the CRS property in your GeoJSON.
2008
Information
Large geometries were generalized to avoid memory issues.
Geometries were simplified to stay within memory limits.
2009
Error
File size limit of 500 MB exceeded.
The layer being added exceeds size limits.
2999
Warning
Unexpected error
Contact Esri Technical Support .
Work with basemaps
The following messages may occur while working with basemaps.
Learn more about basemaps
Code
Category
Title
Message
3001
Information
Basemap cannot be changed
The basemap and layer must have the same coordinate system.
The basemap and layer coordinate systems must be the same. Try again.
3002
Warning
Basemap cannot be loaded
Check the basemap service or select a different basemap.
Analyze Buffer/Drive time
The following messages may occur when working with drive time or buffer analysis.
Learn more about Buffer/Drive time analysis
Code
Category
Title
Message
4001
Information
The service is not available
Spatial analysis server is not configured in your portal. Contact your administrator.
4002
Information
Additional permissions are required
You need permissions to use Analysis tools. Contact your administrator.
4003
Error
Buffer analysis failed
Insufficient credits to perform analysis.
4004
Warning
Unable to connect to server
Check your internet connection.
Internet connection issue, incomplete buffer.
4005
Error
The result layer name length should be no more than 98 characters.
Modify the length of the buffer output layer name to match requirements.
4006
Error
A result layer already exists with this name
Use a different name.
Cannot create buffer/drive time layers with the same name. Rename your result layer with a different name.
4007
Error
The result layer name contains one or more invalid characters (<, >, #, %, :, ", ?, &, +, =, /, *, @, |, or \).
Check for typos or invalid characters in the output name.
4008
Error
The number of features in the layer cannot be greater than 1,000.
This message shows up inline under the input layer of the buffer tool. Buffer drive time can only accept up to 1,000 features.
4009
Information
Location access disabled
Location services or permissions must be enabled.
To use your current location as the input for the buffer drive time tool, you must enable access to location services or permissions. This could be blocked by your browser, or your ArcGIS account or your organization does not have the necessary permissions to use location data within the application.
4010
Error
Contact your administrator or Esri Technical Support.
4011
Error
There is an error with the feature service. Try again.
4012
Error
Unable to access geoprocessing server.
4013
Error
Result layer cannot be found in ArcGIS ArcGIS Online, or ArcGIS Enterprise.
4999
Error
Unexpected error
Work with the Information tool
The following messages may occur when working with the Information tool.
Learn more about the Information tool
Code
Category
Title
Message
5001
Information
The service is not available.
The GeoEnrichment Service is not available.
5002
Information
Additional permissions for the GeoEnrichment Service are required.
5003
Warning
The maximum selection for Information tool has been exceeded
Select a maximum of 100 features.
When you select features on the map, a displayed infographics card will update to show the demographic information for the areas within the specified distance around the selected feature for a maximum of 100 selected features.
5004
Warning
Too many selections
Limit to 10 locations when using drive time in Information.
You have selected more than the allowed number of features that can be selected when using selections and drive time in the Information tool.
5005
Information
Recenter the map to enable information data.
The area that your infographic card is representing is not currently shown on the map. Recenter the map.
5999
Warning
Unexpected error
Work with layers
The following messages may occur when working with layers.
Learn more about layers
Code
Category
Title
Message
6001
Error
The following invalid characters will be removed from the layer name list ( $, <, >).
An attempt was made to use invalid characters when naming your layer.
6002
Information
More than 200+ values
Values not listed here will still display on the map in this category.
No more than 200 unique values can be displayed.
Select features
The following messages may occur when selecting features.
Learn more about Selection tools
Code
Category
Title
Message
7001
Warning
Too many selections
Select up to count locations or fewer.
Selection has a maximum limit.
Sign in
The following messages may occur when signing in.
Learn more about signing in to ArcGIS
Code
Category
Title
Message
8001
Error
The specified ArcGIS Online or ArcGIS Enterprise URL is not valid.
8002
Information
You don't have access to this resource.
Add permissions for this resource to your account or switch accounts.
8003
Information
Public ArcGIS Online account not supported
Sign in with ArcGIS Online organizational account.
ArcGIS public accounts are not supported. Sign in to ArcGIS with an organizational account.
8004
Error
Subscription has expired since MM/DD/YY
Subscription expired.
8005
Error
Subscription has been cancelled.
An ArcGIS subscription may be canceled if it expires or if all credits are used.
Contact your administrator or Esri Technical Support to get a new license.
8006
Error
Subscription has been disabled
Your subscription has been disabled because you consumed all your credits.
Your subscription has been suspended. Possible reasons for suspension include: the subscription has expired, the credit balance is zero or negative, and the organization's subscription has reached its capacity.
8007
Error
Subscription in a restricted state
Subscription restricted. An organization is moved to a restricted state when it uses all of its credits. With an organization that is in a restricted state, access to some capabilities and workflows is blocked.
8008
Error
Your organization has used all available credits and could enter restricted status.
You are attempting to sign in to an organization that has used all available credits. An organization is moved to a restricted state when it uses all of its credits. With an organization that is in a restricted state, access to some capabilities and workflows is blocked.
8009
Error
Invalid URL
Check the URL and reenter the proper address to sign in.
8999
Warning
Unexpected error
Share
The following messages may occur when working with the Share|Export pane.
Learn more about content sharing
Code
Category
Title
Message
10001
Information
Unable to find shared information
A new layer would be published upon sharing.
Previously shared layer may have been deleted.
10002
Information
A new map would be created upon sharing.
10003
Error
The size of the summary text cannot be more than 2,048 characters.
Your summary is too long. Keep summary text under the character limit.
10004
Error
The size of the title cannot be more than 256 characters.
Your title is too long. Keep title text under the character limit.
10005
Error
The size of the tag text cannot be more than 256 characters.
Your layer tags have exceeded the limit. Keep tag text within the character limit.
10006
Error
Enter a title for the map.
A map title is required. Add a title before sharing.
10007
Error
Enter a title for the layer.
A layer title is required. Add a title before sharing.
10008
Warning
Unable to connect to the server
Connection to server lost. Check your internet connection.
10999
Warning
Unexpected error
Print
The following messages may occur when exporting a printer-friendly page of a map in various formats.
Learn more about printing
Code
Category
Title
Message
11001
Error
The size of the copyright text cannot be more than 250 characters.
Copyright text has exceeded the limit. Keep text within the character limit.
11002
Error
The map has a large number of client-side features
Zoom in and retry printing, or click the Screenshot option.
The printing service has a limit for client-side features. Zoom in and retry printing, or click the Screenshot option.
11003
Error
The title has exceeded the limit. Keep text within the character limit.
Navigation tools
The following messages may occur when working with navigation tools, home extent, or bookmarks.
Learn more about navigation tools
Code
Category
Title
Message
12001
Information
Home extent unavailable
Your home extent is outside the boundaries of basemap.
When trying to navigate to the home extent, the home extent is located out of bounds when compared to the basemap's full extent. Clear the home extent and reset within the basemap bounds.
12002
Information
Map extent is locked
Zoom to layer is disabled.
Map must be unlocked to zoom to this layer.
12003
Information
Unlock map extent to use bookmarks.
The map is locked, preventing panning. Unlock the map to navigate to other locations to bookmark.
12004
Error
Link must start with https://.
Thumbnail link must start with the proper address format.
12005
Error
Link may not contain file:.
Image link must be in the correct format.
12006
Error
Invalid URL
The image URL is not valid. Check and try again.
12007
Information
Your location services or permissions must be enabled to navigate to your current location.
Spatial filter
The following messages may occur when working with the Create spatial filter tool in ArcGIS for Excel.
Learn more about the Create spatial filter tool
Code
Category
Title
Message
13001
Error
Spatial filter failed.
13002
Error
Large datasets may cause errors or fail to complete.
The dataset is too large to run the analysis.
13003
Warning
No features found.
No features were found when running the spatial filter.
13004
Error
This feature requires credits to successfully run.
13005
Error
The feature service couldn't be created.
13006
Error
Unable to access geoprocessing service.
13007
Error
Result layer cannot be found in ArcGIS Online or ArcGIS Enterprise.
13008
Warning
Internet issue. The spatial filter cannot successfully complete.
13009
Error
The result layer name has exceeded the character limit.
13010
Error
Cannot create a layer with the same name as an existing one.
13011
Warning
The result layer name contains one or more invalid characters, for example, (<, >, #, %, :, ", ?, &, +, =, /, *, @).
Characters must be valid to name a layer.
13999
Warning
Unexpected error
Layer styling
The following message may occur when configuring layer styling, such as renderer, labeling, and so on.
Learn more about styling map layers
Code
Category
Title
Message
14001
Warning
Arcade expression is not supported for changing its configuration when used in layer renderers.
Layers with Arcade expressions are not supported. Choose a different layer.
Application
The following message may occur when downloading or updating an application.
Code
Category
Title
Message
15001
Information
Update available
Ask your administrator to update to the latest version.
Upgrade to the latest version.
Spatial aggregation
The following messages may occur when using the Spatial aggregation tool.
Learn more about aggregating features
Code
Category
Title
Message
18001
Error
Spatial aggregation failed.
18002
Error
Your result layer name must be within the character limit.
18003
Error
A result layer already exists with this name. Use a different name.
You cannot use an existing result layer name. Choose a unique layer name.
18004
Error
The result layer name contains one or more invalid characters.
The result layer name must contain valid characters only. Check your input and adjust.
18005
Error
Credits are required to perform this analysis.
18006
Error
18007
Error
18008
Error
Result layer cannot be found in ArcGIS Server.
Try again or contact your administrator or Esri Technical Support.
Uncategorized
The following message occurs unexpectedly.
Code
Category
Title
9999
Warning
Unexpected error
