Upgrade ArcGIS Monitor 2024.x
This content is not relevant to ArcGIS Monitor on Windows.
Learn more about upgrading ArcGIS Monitor 2024.x or later on a Windows system
Follow the steps in the sections below to upgrade ArcGIS Monitor 2024.x on a Linux system.
Learn more about upgrading Monitor 2025.0 or later
All machines in a Monitor deployment must be upgraded to the same major.minor version.
Prepare to upgrade Monitor
Review the following information and complete any required actions before you upgrade Monitor:
Review the Monitor system requirements to ensure that your hardware meets the current requirements.
Before upgrading Monitor, check the size of the Monitor database. Ensure that the machine hosting the database contains enough temporary free disk space to accommodate double the size of the database.
Tip:
To check the size of the Monitor database, run the following SQL query on the machine hosting the database, replacing <DatabaseName> in the example with the name of the Monitor database:
SELECT pg_size_pretty(pg_database_size('<DatabaseName>'));Create a backup of the Monitor database and all Monitor machines in the deployment, and store the backup files in a secure, remote location.
Download the latest ArcGIS Monitor software installation files and authorization file from My Esri.
Do not uninstall the previous version of ArcGIS Monitor Server or ArcGIS Monitor Agent until instructed to do so. There is no need to obtain and install each previously released version in sequence.
Only one version can be installed on a machine at a time; when you install a new version, the previous version is replaced.
For Monitor Agent machines to function, they must be the same major.minor version as the Monitor Server machine.
Ensure that the ArcGIS Monitor account has shell access.
In earlier versions of Monitor, the setup package automatically created the ArcGIS Monitor account without shell access. To create a password and allow shell access for the ArcGIS Monitor account, run the following commands as a user in the sudoers group:
sudo passwd <ArcGIS Monitor account name> sudo usermod -s /bin/bash <ArcGIS Monitor account name>Stop the
arcgis-monitor-serverservice on the Monitor Server machine and thearcgis-monitor-agentservice on all Monitor Agent machines by running the following commands as a user in the sudoers group:Monitor Server:
sudo systemctl stop arcgis-monitor-serverMonitor Agent:
sudo systemctl stop arcgis-monitor-agent
Monitoring is not available when the service is stopped.
Some deployments may contain an installation of Monitor Agent on the Monitor Server machine.
Upgrade a Monitor deployment
The recommended order of steps to upgrade a Monitor deployment is as follows:
Upgrade Monitor Server.
Upgrade Monitor Agent.
Starting with the Monitor 2024.0 release, all host machines must have Monitor Agent installed to collect metrics.
Learn more about deploying Monitor
Once you have the installation and backup files, complete the upgrade steps for Monitor Server. Do not uninstall the existing Monitor Server version until instructed to do so.
You can upgrade using an interactive command line interface (CLI), or silently upgrade Monitor Server from the CLI. The setup script detects and updates the existing installation of Monitor Server.
Upgrade using an interactive CLI
After you complete the prerequisites outlined in the Prepare to upgrade Monitor section, complete the steps below to upgrade Monitor Server using an interactive CLI. To perform a silent upgrade instead, proceed to the next section.
Start a terminal session on the Monitor Server machine with a user account in the sudoers group.
Run the following commands to uninstall previous versions of Monitor Server:
Ubuntu:
sudo systemctl stop arcgis-monitor-server sudo systemctl disable arcgis-monitor-server sudo rm -rf /usr/lib/systemd/system/arcgis-monitor-server.service sudo rm -rf /etc/systemd/system/multi-user.target.wants/arcgis-monitor-server.service sudo dpkg --purge arcgis-monitor-serverRed Hat Enterprise Linux Server:
sudo systemctl stop arcgis-monitor-server sudo systemctl disable arcgis-monitor-server sudo rm -rf /usr/lib/systemd/system/arcgis-monitor-server.service sudo rm -rf /etc/systemd/system/multi-user.target.wants/arcgis-monitor-server.service sudo rpm -ev ArcGIS-Monitor-server
Start a terminal session on the Monitor Server machine with the ArcGIS Monitor account.
sudo passwd <ArcGIS Monitor account name> sudo usermod -s /bin/bash <ArcGIS Monitor account name>Change the directory to the location that contains the Monitor
.tar.gzfile and uncompress it.The following is an example:
tar -zxvf ArcGIS_Monitor_Server.tar.gzChange the directory to the location that contains the extracted Monitor Server setup file.
From the command shell, run
Setup.sh.The following is an example:
./Setup.shDuring the installation, read the license agreement and accept it, or exit if you do not agree with the terms.
Tip:
Press Q on your keyboard to close the Master Agreement.
Follow the prompts on the screen to install the software.
After the installation has finished, run the following command as a user in the sudoers group to configure the
arcgis-monitor-serverservice to automatically start with the operating system:sudo <Monitor Server installation location>/framework/etc/scripts/create_Monitor_Server_service.shThe default installation directory is
<ArcGIS Monitor user account home directory>/arcgis/monitor/server.The service is configured to start with the operating system and a message appears indicating the service's status. If the service is not running, run the following command as a user in the sudoers group to start the service:
sudo systemctl start arcgis-monitor-serverOnce you update the Monitor Server installation, open a supported web browser, access Monitor, and verify that the software is updated and licensed.
Depending on the number of components in the Monitor deployment, it may take several minutes for post-upgrade tasks to complete. Access to Monitor is not available until these tasks are completed.
Upgrade silently from the CLI
Rather than running the interactive CLI, you can upgrade Monitor Server silently.
After you complete the prerequisites outlined in the Prepare to upgrade Monitor section, complete the following steps to upgrade Monitor Server:
Ubuntu:
tar -zxvf ArcGIS_Monitor_Server.tar.gzChange the directory to the location that contains the extracted ArcGIS Monitor Server setup file.
Setup.sh.The
--license-agreementparameter is required to accept the End User License Agreement (EULA) during a silent installation. Specifyyesto agree to the EULA and install the software. Specifyingnoresults in a failed installation.The following is an example:
./Setup.sh -l yes [options]-l; --license-agreement CHOICE
This property is required to accept the EULA during a silent installation. Specify yes to agree to the EULA and install the software. Specifying no or omitting this property will result in a failed installation. The download contains a PDF of the EULA. The
EULA.pdffile is in theDocumentationfolder.-d; --directory DIRECTORY
This property is optional. By default, Monitor Server is installed to the $HOME directory. DIRECTORY specifies a different installation directory.
The
/arcgis/monitor/serverpath is appended to the installation directory.-h; --help
This property displays command line help and exits.
Once you have the installation and backup files, complete the upgrade steps on each Monitor Agent machine in the Monitor deployment. All machines in the Monitor deployment must be upgraded to the same major.minor version. Do not uninstall the existing Monitor Agent version until instructed to do so.
You can upgrade using a CLI, or silently upgrade Monitor Agent from the CLI. The setup script detects and updates the existing installation of Monitor Agent.
After you complete the prerequisites outlined in the Prepare to upgrade Monitor section, complete the steps below to upgrade Monitor Agent using an interactive CLI. To perform a silent upgrade instead, proceed to the next section.
Start a terminal session on the Monitor Agent machine with a user account in the sudoers group.
Run the following commands to uninstall previous versions of Monitor Agent:
Ubuntu:
sudo systemctl stop arcgis-monitor-agent sudo systemctl disable arcgis-monitor-agent sudo rm -rf /usr/lib/systemd/system/arcgis-monitor-agent.service sudo rm -rf /etc/systemd/system/multi-user.target.wants/arcgis-monitor-agent.service sudo dpkg --purge arcgis-monitor-agentRed Hat Enterprise Linux Server:
sudo systemctl stop arcgis-monitor-agent sudo systemctl disable arcgis-monitor-agent sudo rm -rf /usr/lib/systemd/system/arcgis-monitor-agent.service sudo rm -rf /etc/systemd/system/multi-user.target.wants/arcgis-monitor-agent.service sudo rpm -ev ArcGIS-Monitor-agent
Start a terminal session on the Monitor Agent machine with the ArcGIS Monitor account.
tar -zxvf ArcGIS_Monitor_Agent.tar.gzChange the directory to the location that contains the extracted Monitor Agent setup file.
Tip:
arcgis-monitor-agentservice to automatically start with the operating system:sudo <Monitor Agent installation location>/framework/etc/scripts/create_Monitor_Agent_service.shThe default installation directory is
<ArcGIS Monitor user account home directory>/arcgis/monitor/agent.The service is configured to start with the operating system and a message appears indicating the service's status. If the service is not running, run the following command as a user in the sudoers group to start the service:
sudo systemctl start arcgis-monitor-agentOnce you update the Monitor Agent installation, open a supported web browser, access Monitor, and verify that the Monitor Agent machine is connected to Monitor Server.
Rather than running the interactive CLI, you can upgrade Monitor Agent silently.
After you complete the prerequisites outlined in the Prepare to upgrade Monitor section, complete the following steps to upgrade Monitor Agent:
Ubuntu:
Setup.sh.The
--license-agreementparameter is required to accept the EULA during a silent installation. Specifyyesto agree to the EULA and install the software. Specifyingnoresults in a failed installation.The following is an example:
The
/arcgis/monitor/agentpath is appended to the installation directory.-h; --help
Considerations after upgrading
It is recommended that you create a backup of the Monitor database and all Monitor machines in the deployment after upgrading. After upgrading, confirm that the deployment is collecting data as expected by accessing Monitor and viewing collection details and component details.
