Add layers to scenes
Add layers to new or existing scenes to help tell a story. You can browse Scene Viewer resource options such as ArcGIS Online, My content, Living Atlas, and Hub catalogs to add content and enhance a scene. You can also add a layer by providing a URL.
See Choose a global or local scene for layer requirements.
To add layers to a scene, complete the following steps:
Verify that you are signed in to your organization, and open Scene Viewer.
On the Designer toolbar, click Add Layers
.Add the layers you want to the scene.
Click Save
to save the layers that you added to the scene.
Layers that Scene Viewer supports
Scene Viewer supports the following layer types:
* Scene Viewer doesn't support all the image rendering properties set in Map Viewer.
** Scene Viewer doesn't support all the capabilities of this layer.
See Scene Viewer layer support for information about ArcGIS Enterprise and ArcGIS Online layer availability in Scene Viewer.
Browse layers
To search for layers to add to Layer Manager
and the scene, complete the following steps:
Click Add Layers
on the Designer toolbar.Click Browse layers
to search for layers from the following options:My content—Includes layers you own.
My favorites—Includes layers you've marked as favorites.
My groups—Includes layers from groups to which you belong.
Subscription content—Includes layers available through ArcGIS Marketplace if your organization assigned licenses for purchasing the data layers.
ArcGIS Marketplace will be retired in the first quarter of 2027. The ArcGIS Marketplace website was shut down in March 2026. See the ArcGIS Marketplace Retirement article for details.
My organization—Includes layers from your organization.
Living Atlas—Includes selected layers from ArcGIS Living Atlas, including web scenes, feature and 3D layers, imagery, demographics, and land cover.
ArcGIS Online—Includes layers you've added, layers from groups to which you belong, and public layers.
Hub catalogs—Layers from ArcGIS Hub sites you've marked as favorites or layers you've opened in Scene Viewer from an ArcGIS Hub site.
Do any of the following to find the layers you want:
Type search terms in the search box. You can also use advanced search to help narrow the search results.
Click Filter
to sort the layer results, change the sort direction, and narrow the search results.The filter options available depend on where you are searching for layers, and whether and how you are signed in.
For example, if you are searching for layers in an organization and content categories have been set up, you can use the Categories filter to narrow the results. Use the Status filter to only return layers that have been designated by the administrator as authoritative.
To limit search results based on the current map extent, turn on the Only show content within map area toggle button. For example, if the map is zoomed to Nevada, USA, the search results are ordered and based on the map extent. Changing the map extent to Pennsylvania typically returns different results (depending on your keywords). All layers that overlap the current map extent (and match your keywords) are returned.
Click the title of an item to see its details. In the item details pane, expand Overview, Description, and Details to see more information about the item. If the item contains multiple layers, expand Layers to see more information about each layer. Click Add to add the layer to the scene. Click View item
to open the item page to see more information about the layer.
Click Add in the search results to add a layer to a scene.
Repeat the previous step for each layer you want to add.
Tip:
You can add any of the layer results to your favorites by clicking Add to favorites in the layer details pane. You can view your complete list of favorites by choosing My favorites when searching for layers in Scene Viewer or from the My favorites tab on the content page.
Click Remove to remove a layer from a scene.
On the Designer toolbar, click Save
to save the layers that were added to the scene.Add more layers to the scene, or click Done.
Add more layers
After you click Add Layers
, in addition to searching for layers, you can also add the following layers to Layer Manager
Layer |
Description |
A web service that can be added by providing a URL of the layer. |
An open standard geospatial data interchange format that represents simple geographic features and their nonspatial attributes. |
A web-based text file ( |
You can also create the following analysis layers that are added to Layer Manager
upon completion:
Layer |
Description |
Perform 3D visibility analysis from an observer to multiple target points. |
Perform 3D visibility analysis from an observer to an area in a scene. |
Annotate multiple dimensions with labels that display either the horizontal, vertical, or diagonal distance between the points. |
Highlight the project area and fade the background of the scene. |
