Alphabetical list of arcpy.mp functions
The following is a list of each of the arcpy.mp functions along with their required and optional input parameters. This document is intended to serve as a quick reference. For more specific information on each parameter (data type, default value, and so forth), click the corresponding link.
arcpy.mp functions
ArcGISProject (aprx_path)
ColorRamp (color_ramp_name, {index})
ConvertLayoutFileToLayout (layout_file)
ConvertWebMapToArcGISProject (webmap_json, {template_pagx}, {mapframe_name}, {notes_gdb}, {template_rptt})
CreateArcGISProject (project_path, project_name, {create_parent_folder}, {home_folder}, {default_database}, {default_toolbox})
CreateExportFormat (format, {file_path})
CreateExportOptions (class_type)
CreateWebLayerSDDraft (map_or_layers, out_sddraft, service_name, {server_type}, {service_type}, {folder_name}, {overwrite_existing_service}, {copy_data_to_server}, {enable_editing}, {allow_exporting}, {enable_sync}, {summary}, {tags}, {description}, {credits}, {use_limitations})
LayerFile (layer_file_path)
ListTimeZones ({wildcard}, {time_zone_type})
PDFDocumentCreate (pdf_path)
PDFDocumentOpen (pdf_path, {user_password}, {master_password})
Table (table_data_source)
