00132: <value> is unsupported within a registered folder for task <value>
ArcGIS Server platforms do not support all the data formats that ArcGIS Desktop supports. If any of the following data formats are present in a folder registered with the server's data store, and the task uses this data, you cannot publish:
  • Personal geodatabase
  • Excel table
Solution
There are two solutions: unregister the folder in the data store or convert the data.
Convert the data
You must convert the data to a supported format (typically a file geodatabase), rerun the tool using the supported format, and share the newly created result. In general, the steps are as follows:
  1. Create a file geodatabase in the folder registered with the server's data store. You can use the Create File GDB tool to create the file geodatabase.
  2. Convert the unsupported data to a file geodatabase by doing any of the followings:
  • Open and run the tool again to create a new history item. Use the converted datasets, or layers based on the converted dataset, as inputs to the tool.
  • Share the new history item.
