Introduction to 3D tiles
What is a 3D tiles dataset
A 3D tiles dataset references a tileset that defines mesh or 3D object type data in a hierarchical data structure. 3D tiles are an OGC standard such as Indexed Scene Layer (i3s) specification 3D layers, allowing you to visualize large amounts of 3D content. 3D tiles are based on the 3D tiles specification. You can choose a tileset in a supported file format such as JSON or 3TZ on the Add Data dialog box
. A 3D tiles dataset is added to the scene as a mesh layer or 3D object layer.
You can work with 3D tile services hosted in ArcGIS Online, ArcGIS Enterprise, or in a third-party web server. Services hosted outside of ArcGIS must not require authentication or use token-based authentication. For example, you can add the Google Photorealistic 3D tiles dataset and your Google Maps API key as a custom request parameter. You can add 3D tile services using the Add Data From Path dialog box
3DTiles supported features
The 3D tiles specification contains various features and extensions that may or may not be supported. Support for 3DTiles version 1.1 is partial and limited to version 1.0 extensions. Version 0.x is not supported in ArcGIS clients. Some aspects of the specification may not be supported and are listed as partially supported. Currently unsupported extensions may become available in future releases.
3DTiles feature or extension |
Supported |
Core 1.0 |
Yes |
Core 1.0 |
No |
Core 1.0 |
No |
3DTiles_batch_table_hierarchy |
Partial |
3DTiles_content_gltf |
Yes |
3DTiles_imlicit_tiling |
No |
3DTiles_multiple_contents |
No |
3DTiles_bounding_volume_S2 |
No |
3DTiles_metadata |
Partial |
KHR_draco_mesh_compression (glTF specification) |
Yes |
EXT_mesh_features (glTF specification) |
Partial |
EXT_meshopt_compression (glTF specification) |
Yes |
EXT_feature_metadata (glTF specification) |
Partial |
EXT_texture_webp (glTF specification) |
Yes |
KHR_texture_basisu (glTF specification) |
Yes |
KHR_materials_unlit (glTF specification) |
Yes |
Absolute path in tile content.uri |
No |
3D layers in a scene
In ArcGIS, geospatial information is organized in layers with specific capabilities. 3D layers are drawn in local and global scenes in the 3D Layers category. 3D tile datasets can contain many types of data. ArcGIS Pro requires the layer type to be defined to draw. For example, continuous meshes with textures are represented as a mesh layer type, while a 3D object layer draws as individual features such as buildings.
General information and display control for a 3D layer can be found on the layer properties dialog box. To access the properties, right-click the 3D layer in the Contents pane and click Properties
3D tiles coordinate system
ArcGIS Pro supports the default coordinate system for 3D layers in accordance with the 3D tiles specification. 3D layers (powered by 3D tiles) have a default horizontal coordinate system of WGS 84 and WGS 1984 for a vertical coordinate system. ArcGIS Pro supports defining vertical coordinate systems that are gravity related or ellipsoidal if no Esri_crs extension is specified.
Ellipsoidal heights in contrast to gravity-related heights may not reflect movement of gravity such as in the case of water. Water can appear to run uphill when working with ellipsoidal heights. Often, geographic data is in gravity-related heights using a mean sea level of 0. If no vertical coordinate system is defined, z-values are treated as gravity related.
Adding layers to a new local or global scene sets the coordinate system of the scene to coordinate system of the first layer. Multiple layers may have different vertical coordinate systems, and the data may not align correctly unless a transformation is applied. For example, you can add a 3D layer (powered by 3D tiles) to a scene and the scene's coordinate system will be set to WGS 1984 for both the horizontal and vertical coordinate system. Additional layers that have a gravity-related coordinate system such as EGM96 or EGM2008 are projected and drawn at the correct height.
Layers that do not have a vertical coordinate system are assumed to render in gravity-related heights. Set the scene's vertical coordinate system to EGM96 or EGM2008 for ArcGIS Pro to apply the datum transformation.
Additional transformations may need to be installed from My Esri. See Install supplementary coordinate system files to learn more.
An elevation surface layer may need a vertical coordinate system to apply the correct datum transformation and align the ground with the layers in the scene. When using the Esri-hosted elevation source layer Terrain 3D, the gravity-related heights are based on different elevation coverage and not a uniform vertical coordinate system. When 3D tiles layers and Esri-hosted elevation source layers are present and the scene vertical coordinate system is WGS84, the elevation layers will be drawn with EGM96 Geoid as the vertical coordinate system.
Esri_crs extension
The ESRI_crs extension allows you to work in any well-defined coordinate system (WKID) for the horizontal and vertical coordinate system. For example, you can view the 3D layer in ArcGIS Pro or other ArcGIS applications in the projected coordinate system you require for your project. You can view the same data in WGS 1984 if you also want to provide the 3D layer to other third-party applications. With this extension, you are no longer required to provide the data in WGS 1984 with an ellipsoidal vertical coordinate system. You can define your own coordinate system and use the data in a scene defined as WGS 1984 without the need to duplicate the data.
You can generate a 3D tiles dataset in a projected coordinate system with the ArcGIS Reality Pro.
Add a 3D layer from a 3D tiles dataset or 3D tiles archive file
Follow these steps to add a 3D tiles layer from a .json or .3tz file:
On the Map tab, in the Layer group, click Add Data
.On the Add Data dialog box, browse to the tileset in JSON or 3TZ format
and click OK.Tilesets in JSON format are recognized only if they have the file name
tileset.json.On the Add Data From Path dialog box, choose the Integrated Mesh or 3D Object layer type depending on the underlying data type.
Click Add.
A 3D layer is added to the scene.
Add a 3D tiles service
Follow these steps to add a 3D tiles service from ArcGIS Online, ArcGIS Enterprise or a third-party web-server:
On the Map tab, in the Layer group, click Add Data From Path
.Type the path or URL to the dataset.
Choose the layer type as Integrated Mesh or 3D Object.
You can specify a token if the service requires authentication in the custom request parameters.
Click Add to create a layer in the scene referencing the data.
Troubleshoot 3D tiles drawing
The 3D tiles specification is an open specification and not all properties are supported. If a 3D layer does not render, you can view logs to troubleshoot the problem.
Investigate 3D tiles drawing issues with Diagnostic Monitor
Follow these steps to troubleshoot a 3D layer (powered by 3D tiles) that is not drawing properly:
On the Insert tab, click the New Map drop-down menu
and click New Local Scene
.Press Ctrl+Alt+M.
Diagnostic Monitor opens in a separate window.
In the Diagnostic Monitor window, click the Log tab.
Add a 3D layer to your scene.
Drawing issues may be reported at initial load time or when zooming in and out of the scene. If the layer is already present in the scene, you can click refresh
to see all warnings or errors.In the Diagnostic Monitor window in the filter text box, type 3DTiles.
Any 3D tiles drawing issues are listed in the logs.
Click the listed log to see the event log details with a more specific message.
Share a 3D layer
You can share a 3D layer as a web layer or in a web scene to ArcGIS Online or ArcGIS Enterprise 12.0 or later. Alternatively, use the Transfer Files tool to share a folder of 3D tiles content to a cloud store and publish a 3D tiles service to ArcGIS Enterprise 12.0 or later. Use the Package 3D Tiles tool to create a 3D tiles archive to share a single portable file with other users.
3D tiles of type 3D Object can be shared to your portal but only visualized in ArcGIS Pro. Scene Viewer only supports visualizing 3D layers of type integrated mesh.
