Alter configuration keywords
Available with Standard or Advanced license.
Configuration keywords represent a set of configuration parameters and values that specify how data is stored in your geodatabase. If you want to change how data is stored in your geodatabase, you can alter the parameter settings of existing keywords or create your own keywords.
If you want to create a custom configuration keyword or alter the parameter values of an existing keyword, use the Export Geodatabase Configuration Keywords tool to export your current settings to a text file. Edit and save the text file, and then run the Import Geodatabase Configuration Keywords tool to import your changes. Alternatively, you can use an ArcPy function to export to a text file, edit and save the file, and use an ArcPy function to import your changes.
Run geoprocessing tools
If you have access to ArcGIS Pro (Standard or Advanced), connect to the geodatabase from the Catalog pane, run the Export Geodatabase Configuration Keywords tool to create a text file containing the geodatabase's current configuration settings, edit and save the text file, and import changes using the Import Geodatabase Configuration Keywords tool.
Connect to the geodatabase as the sde user.
Export the current configuration keyword settings to a text file using the Export Geodatabase Configuration Keywords tool.
Specify the connection you created in the previous step for the Input Database Connection.
Provide an output file name and location.
Click Run to run the tool.
A file containing the current geodatabase configuration settings is created in the location you specified.
Open the exported file in a text editor and make the changes you want.
You can alter the values for parameters of existing keywords or create your own custom keywords.
Save and close the text file.
Import the edited file using the Import Geodatabase Configuration Keywords tool.
Use the same geodatabase connection you specified when you exported the configuration keywords.
The new configuration settings are now available for use when data is created in ArcGIS.
Use Python
You can script the creation of a database connection file, provide it as input to the ExportGeodatabaseConfigurationKeywords_management ArcPy function, edit the resultant text file, save and close the file, and then use the connection file and the ImportGeodatabaseConfigurationKeywords_management ArcPy function to import your changes.
Python scripts must be run from a machine where ArcGIS Server or ArcGIS Pro (Standard or Advanced) is installed.
Open a command window, import the ArcPy module, and create a database connection (
.sde) file using theCreateDatabaseConnection_managementfunction.Connect as the sde user. Save the username and password with the file.
In this example, a connection file named admin.sde is created in the
/usr/connectionfilesdirectory on a Linux server. The connection is made to the cataloged database TEAMDATA as the sde user.import arcpy arcpy.management.CreateDatabaseConnection (r'/usr/connectionfiles', "admin.sde", "DB2", "TEAMDATA", "DATABASE_AUTH", "sde", "Cky00r", "SAVE_USERNAME")Export the current geodatabase configuration.
In this example, the config file is exported to the
/usr/tmpdirectory.arcpy.management.ExportGeodatabaseConfigurationKeywords (r'/usr/connectionfiles/admin.sde', r'/usr/tmp/config.vi')Open the exported file in a text editor and make the changes you want.
Alter the values for parameters of existing keywords or create your own custom keywords.
Import the edited file.
arcpy.management.ImportGeodatabaseConfigurationKeywords (r'/usr/connectionfiles/admin.sde', r'/usr/tmp/config.vi')The new configuration settings are now available for use when data is created in ArcGIS.
