Enable ArcGIS IPS
Available for an ArcGIS organization licensed with the ArcGIS IPS extension.
For ArcGIS IPS to function, Bluetooth or Wi-Fi infrastructure must be available in an indoor environment. The process for enabling ArcGIS IPS varies based on the infrastructure type you choose.
Enable Bluetooth-based ArcGIS IPS
To enable ArcGIS IPS with a Bluetooth infrastructure, complete the following steps:
  1. Create the ArcGIS IPS Information Model.
    You can choose either a file or an enterprise geodatabase to manage your Bluetooth infrastructure and the indoor positioning data.
  2. Prepare and share a map for ArcGIS IPS Setup.
    You can use the shared web map in the IPS Setup mobile app to facilitate infrastructure deployment, maintenance, and on-site troubleshooting.
  3. Create a beacon placement plan.
  4. Deploy and configure the beacons throughout the facility according to your beacon placement plan with the IPS Setup app.
  5. Create survey-less positioning data using beacon data and the floor plan.
  6. Optionally, add geometry to the IPS positioning dataset.
  7. Create an IPS-aware map.
Enable Wi-Fi-based ArcGIS IPS
To enable ArcGIS IPS with a Wi-Fi infrastructure, complete the following steps:
    You can choose either a file or an enterprise geodatabase to manage your Wi-Fi infrastructure and the indoor positioning data.
  3. Create an IPS survey plan.
  4. Perform a planned IPS survey with the IPS Setup app to produce survey recordings.
    Wi-Fi survey recordings can only be collected on Android devices.
  5. Create survey-based positioning data.
