Indoors licensing configurations
The following are the three license types for ArcGIS Indoors that provide access to different apps and functionality:
  • ArcGIS Indoors Pro allows you to create and share floor-aware maps in ArcGIS Pro and use geoprocessing tools in the Indoors toolbox.
  • ArcGIS Indoors Maps includes Indoors capabilities at an ArcGIS organization level, such as configuring floor-aware maps in Map Viewer and creating Indoors apps. Indoors Maps includes unlimited use of ArcGIS Indoors Pro functionality for members of the organization, and access to Indoors Viewer, ArcGIS Indoors Mobile, and Indoors kiosk to support indoor mapping, wayfinding, and navigation.
    You can access ArcGIS Indoors Pro functionality in ArcGIS Pro when connected to an organization licensed with ArcGIS Indoors Maps.
  • ArcGIS Indoors Spaces is an add-on to ArcGIS Indoors Maps that enables workspace reservation capabilities in the Indoors Viewer and Indoors Mobile apps, as well as access to Indoors Space Planner to support space management and Indoors Floor Plan Editor to support floor plan updates.
ArcGIS Indoors licensing
The following table lists the functionality that is included with each Indoors licensing configuration. A green check mark (Required) in a column means the indicated license can be used to access the functionality.
Functionality
Indoors Pro
Indoors Maps
Indoors Maps and Indoors Spaces
Use Indoors geoprocessing tools
Required
Required
Required
Use the floor filter in ArcGIS Pro
Required
Required
Required
Create and share floor-aware maps in ArcGIS Pro
Required
Required
Required
Configure launch actions and categories
Required
Required
Required
Generate indoor routable networks
Required
(Network Analyst and 3D Analyst required)
Required
Required
Unlimited Indoors User user types for use with Indoors Viewer and Indoors Mobile
Required
Required
Configure floor-aware properties in Map Viewer
Required
Required
Use Indoors Viewer for indoor mapping, wayfinding, and navigation
Required
Required
Use Indoors Mobile for indoor mapping, wayfinding, and navigation
Required
Required
Blue dot location indicator for indoor positioning if you configured an indoor positioning system (IPS)
Required
Required
Location sharing with indoor positioning if you configured an IPS
Required
Required
Use Space Planner for space management
Required
Use Floor Plan Editor for managing floor plan updates
Required
Share Indoors Spaces feature layers for workspace reservations
Required
Reserve workspaces in Indoors Viewer and Indoors Mobile
Required
ArcGIS Indoors Pro licensing
ArcGIS Indoors Pro is licensed through Named User licensing if purchased separately. If your organization is licensed with Indoors Maps, Named User licensing is not required. You can set the active portal to the organization with the Indoors Maps license to access Indoors Pro functionality.
If ArcGIS Pro is licensed in a different way than ArcGIS Indoors, you can also set the active portal to an ArcGIS organization licensed for Indoors Maps to access Indoors functionality. For example, if ArcGIS Pro is licensed through a Single Use license, but your ArcGIS Enterprise portal contains an ArcGIS Indoors Maps organizational license, you can set the active portal to your Enterprise portal in ArcGIS Pro and access Indoors capabilities.
ArcGIS Indoors Maps, ArcGIS Indoors Spaces, and ArcGIS Indoors Pro licenses are supported at ArcGIS Pro 3.0 and later, ArcGIS Enterprise 11.0 and later, and the current release of ArcGIS Online.
Learn more about ArcGIS Pro license types
Additional license requirements
In addition to an Indoors license, the following licenses are required to create indoor routable networks using Indoors geoprocessing tools:
