Create and modify LRS intersections
Available with the Linear Referencing license.
ArcGIS Linear Referencing allows you to create a new intersection feature class for an existing LRS Network. You can also modify an existing intersection feature class.
Create an LRS intersection
Use the Create LRS Intersection tool to create an intersection feature class for a parent LRS Network. If the intersection feature class is not modeled in advance, the tool creates and registers it with the parent LRS Network.
Learn more about the intersection feature class fields and properties
To add intersections to the intersection feature class, run the Generate Intersections tool.
Learn more about generating and updating intersections
To create an intersection feature class, complete the following steps:
In ArcGIS Pro, open the Create LRS Intersection tool.
Click the Browse button
next to Parent LRS Network and browse to the LRS Network feature class to which the intersection is registered.The Network Description Field drop-down menu is populated based on the Parent LRS Network value.
If an LRS Network feature class doesn't exist in your LRS, you must create one.
Click the Network Description Field drop-down arrow and choose a field to use as the network description field.
Provide the name of the intersection to be registered in the Intersection Feature Class parameter.
An intersection feature class is created if it is not registered with the LRS Network.
Do the following to configure the Intersecting Layers value table:
Click the Intersection Layer drop-down arrow and choose an intersection layer.
Click the ID Field drop-down arrow and choose an ID field.
Click the Description Field drop-down arrow and choose a description field.
Provide an alphanumeric value to use as a name separator in the Name Separator text box.
Optionally, click the Add another button next to Intersecting Layers to add more intersecting layer value tables and define the value table fields for each intersecting layer.
Optionally, check the Consider z-values when generating intersections check box to use z-values during the generation of intersections.
Optionally, if the Consider z-values when generating intersections check box is checked, provide a z-tolerance value in the Z Tolerance parameter.
Click Run.
The intersection feature class is created.
Create an LRS intersection from an existing dataset
Use the Create LRS Intersection From Existing Dataset tool to create intersections for an LRS Network using an existing feature class.
To create an intersection feature class from an existing dataset, complete the following steps:
In ArcGIS Pro, open the Create LRS Intersection From Existing Dataset tool.
next to Parent LRS Network and browse to the LRS Network feature class to which the intersection is registered.Note:
Click the Intersection Feature Class drop-down arrow and choose the intersection feature class.
The remaining parameters are populated based on the chosen intersection feature class, with the exception of Intersecting Layers.
Use the default field or choose another intersection ID field from the Intersection ID Field drop-down menu.
Use the default field or choose another intersection name field from the Intersection Name Field drop-down menu.
Use the default field or choose another route ID from the Route ID Field drop-down menu.
Use the default field or choose another feature ID field from the Feature ID Field drop-down menu.
Use the default field or choose another start date field from the From Date Field drop-down menu.
Use the default field or choose another end date field from the To Date Field drop-down menu.
Provide the name of a field in the intersection feature class in the Measure Field parameter to use as a measure field.
Click Run.
Modify an LRS intersection
Use the Modify LRS Intersection tool to remap one or more LRS intersection fields in an LRS intersection feature class. You can use this tool to add or remove properties from an intersection feature class.
Before using this tool, create the fields for field remapping in the underlying LRS intersection feature class.
Tip:
Use the Calculate Intersecting Route Measures tool to create an output table of all the routes and measures at each intersection location.
To modify an LRS intersection, complete the following steps:
In ArcGIS Pro, open the Modify LRS Intersection tool.
Click the Intersection Feature Class drop-down arrow and choose the LRS intersection feature class to modify.
The input feature class must represent an LRS intersection.
Use the default field or choose another route ID field from the Route ID Field drop-down menu.
Use the default field or choose another feature class name field from the Feature Class Name Field drop-down menu.
Provide the name of a field in the Measure Field parameter to use as a measure field.
Click Run.
The LRS intersection fields are remapped.
