Event behavior for route reversal
Available with the Linear Referencing license.
When you reverse a route, events are impacted depending on the configured event behavior for the event layer.
Events are not updated until you run the Apply Event Behaviors tool after route edits. If conflict prevention is enabled, you are prompted to run the Apply Event Behaviors tool before posting to the default version.
When you check the Recalibrate route downstream option during route editing, the tool applies the event behavior for route calibration to downstream sections. You can review configured event behaviors by viewing the LRS event properties.
The following sections describe route reversal and the corresponding event behaviors.
Route reversal scenario
Single or multiple adjoining routes that belong to the same line can be reversed in one edit.
In the following scenario, Route 1 is active from 1/1/2000. The reversal occurs on 1/1/2005 and reverses the entire route. The following graphics and tables demonstrate the route information before and after the reversal.
Route before reversal
The following diagram shows the route before the reversal:
The following table provides details about the route before the reversal:
| Route Name | From Date | To Date | From Measure | To Measure |
| Route1 | 1/1/2000 | <Null> | 0 | 20 |
| Route ID | From Date | To Date | From Measure | To Measure |
Route after reversal
The following diagram shows the route after the reversal:
The following table provides details about the route after the reversal:
| Route1 | 1/1/2000 | 1/1/2005 | 0 | 20 |
| Route1 | 1/1/2005 | <Null> | 0 | 20 |
Events before route reversal
There are two events on Route 1 that have a start date of 1/1/2000. The following diagram shows the route and events before the reversal.
The following table provides details about the events before the reversal:
| Event | Route Name | From Date | To Date | From Measure | To Measure |
| Event1 | Route1 | 1/1/2000 | <Null> | 5 | 12 |
| Event2 | Route1 | 1/1/2000 | <Null> | 12 | 20 |
| Event | Route ID | From Date | To Date | From Measure | To Measure |
The following sections detail how event behavior rules apply after you run the Apply Event Behaviors tool under this route reversal scenario.
Stay Put event behavior
The Stay Put behavior maintains the geographic location of the event, but the measures can change.
The route reversal described above has the following effects:
Event 1 is retired on the date of reversal because it is within the edit section. A new event is created with the reversal date being the start date. The start measure changes to 8 and the end measure changes to 15 to accommodate the reversed measures of Route 1.
Event 2 is retired on the date of reversal because it is within the edit section. A new event is created with the reversal date being the start date. The start measure value changes to 0 and the end measure value changes to 8 to accommodate the reversed measures of Route 1.
The following diagram shows the route and events after the reversal:
The retired event is not drawn in the previous diagram.
The following table provides details about the events after the reversal when Stay Put is the configured event behavior:
| Event | Route Name | From Date | To Date | From Measure | To Measure | Location Error |
| Event1 | Route1 | 1/1/2000 | 1/1/2005 | 5 | 12 | No Error |
| Event1 | Route1 | 1/1/2005 | <Null> | 8 | 15 | No Error |
| Event2 | Route1 | 1/1/2000 | 1/1/2005 | 12 | 20 | No Error |
| Event2 | Route1 | 1/1/2005 | <Null> | 0 | 8 | No Error |
| Event | Route ID | From Date | To Date | From Measure | To Measure | Location Error |
Move event behavior
The Move behavior maintains the measures of the event, but the geographic location can change.
Event 1 is retired on the date of reversal because it is within the edit section. A new event is created with the reversal date being the start date. Because the measures do not change for the Move behavior, the event maintains its original start measure of 5 and the end measure of 12.
Event 2 is retired on the date of reversal because it is within the edit section. A new event is created with the reversal date being the start date. Because the measures do not change for the Move behavior, the event maintains its original start measure of 12 and end measure of 20.
The following table provides details about the events after the reversal when Move is the configured event behavior:
| Event1 | Route1 | 1/1/2005 | <Null> | 5 | 12 | No Error |
| Event2 | Route1 | 1/1/2005 | <Null> | 12 | 20 | No Error |
Retire event behavior
The Retire behavior retires events intersecting the reversal region.
Event 1 retires on the date of reversal because it is completely inside the edit section.
Event 2 retires on the date of reversal because it is completely inside the edit section.
The following table details the events after the reversal when Retire is the configured event behavior:
Detailed route reversal behavior on routes in a line network with events that span routes
In this example, there are three routes on the same line and the routes are active from 1/1/2000. The reversal is set to occur on 1/1/2005, where all three routes are reversed. The following graphics and tables demonstrate the route information before and after the reversal.
Routes before reversal
The following diagram shows the routes before reversal:
The following table provides details about the routes before the reversal:
| Route Name | Line Name | Line Order | From Date | To Date | From Measure | To Measure |
| Route1 | LineA | 100 | 1/1/2000 | <Null> | 0 | 10 |
| Route2 | LineA | 200 | 1/1/2000 | <Null> | 15 | 25 |
| Route3 | LineA | 300 | 1/1/2000 | <Null> | 30 | 40 |
| Route ID | Line Name | Line Order | From Date | To Date | From Measure | To Measure |
Routes after reversal
The following diagram shows the routes after the reversal:
The following table provides details about the routes after the reversal:
| Route1 | LineA | 100 | 1/1/2000 | 1/1/2005 | 0 | 10 |
| Route1 | LineA | 100 | 1/1/2005 | <Null> | 0 | 10 |
| Route2 | LineA | 200 | 1/1/2000 | 1/1/2005 | 15 | 25 |
| Route2 | LineA | 200 | 1/1/2005 | <Null> | 15 | 25 |
| Route3 | LineA | 300 | 1/1/2000 | 1/1/2005 | 30 | 40 |
| Route3 | LineA | 300 | 1/1/2005 | <Null> | 30 | 40 |
Events before reversal
There are two spanning events on routes on Line A. The following diagram shows the routes and events before the reversal:
| Event ID | From Date | To Date | From Route Name | From Measure | To Route Name | To Measure |
| Event1 | 1/1/2000 | <Null> | Route1 | 7 | Route2 | 18 |
| Event2 | 1/1/2000 | <Null> | Route2 | 18 | Route3 | 35 |
The following sections describe how event behavior rules apply when you reverse routes on a line in a line network.
Event 1 is retired on the date of reversal because it is within the edit section. A new event is created with the reversal date being the start date. The start measure changes to 22 on Route 2 and the end measure changes to 3 on Route 1 to accommodate the new measure of the reversed routes.
Event 2 is retired on the date of reversal because it is within the edit section. A new event is created with the reversal date being the From Date. The From and To Measures are changed from measure 35 on Route 3 to measure 22 on Route 2 to accommodate the new measure of the reversed routes.
The following diagram shows the routes and events after the reversal:
| Event ID | From Date | To Date | From Route Name | From Measure | To Route Name | To Measure | Location Error |
| Event1 | 1/1/2000 | 1/1/2005 | Route1 | 7 | Route2 | 18 | No Error |
| Event1 | 1/1/2005 | <Null> | Route2 | 22 | Route1 | 3 | No Error |
| Event2 | 1/1/2000 | 1/1/2005 | Route2 | 18 | Route3 | 35 | No Error |
| Event2 | 1/1/2005 | <Null> | Route3 | 35 | Route2 | 22 | No Error |
Move event behavior
Event 1 is retired on the date of reversal because it is within the edit section. A new event is created with the reversal date being the start date. Because the measures do not change for the Move behavior, the event maintains its original start measure value of 18 on Route 2 and end measure value of 7 on Route 1. Note that the route start and end locations also switch to accommodate the event direction after route reversal.
Event 2 is retired on the date of reversal because it is within the edit section. A new event is created with the reversal date being the start date. Because the measures do not change for the Move behavior, the event maintains its original start measure value of 35 on Route 3 and end measure value of 18 on Route 2. Note that the route start and end locations also switch to accommodate the event direction after route reversal.
| Event1 | 1/1/2005 | <Null> | Route2 | 18 | Route1 | 7 | No Error |
| Event2 | 1/1/2005 | <Null> | Route3 | 35 | Route2 | 18 | No Error |
The following table provides details about the events after reversal when Retire is the configured event behavior:
| Event1 | 1/1/2000 | 1/1/2005 | Route1 | 5 | Route2 | 20 |
| Event2 | 1/1/2000 | 1/1/2005 | Route2 | 20 | Route3 | 35 |
