Route reassignment
Available with the Linear Referencing license.
Reassignment is the technique by which all or a portion of a route or line in a linear referencing system (LRS) Network is moved, or reassigned, to the immediate upstream or downstream of another route or line.
One example of a route reassignment is to split your routes and merge (assign) them to another route after a pipeline has changed operation or ownership. Another example is to redesignate a portion of a pipe that falls on the other side of a boundary after an administrative boundary change.
One example is to redesignate a portion of a road that now falls on the other side of a boundary after administrative boundaries change.
Use the Reassign Route tool to perform route reassignment and update attributes and calibration points located along the reassigned route.
Before using this tool to edit a feature service, you must share branch versioned LRS data as a web layer. If the feature service is not yet published, see Share as web layers. If you are using a file geodatabase LRS dataset, this tool provides limited functionality.
Beta:
You can use the ArcGIS Pro Assistant (Beta) to perform route reassignment and to guide you through the workflow.
The following table lists parameters used for line networks in the Reassign Route tool:
Parameter Description
Network The network that supports lines in which the routes exist.
Effective Date This is the date when the reassignment has taken place on the ground.
Source: From Route Name The route where the reassignment starts.
Source: From Measure The measure on the source route where the reassignment starts; shown by the green point.
Source: To Route Name The route where the reassignment ends. For example, if the reassignment takes place on a single route, the source route and target route are the same. The source routes should belong to the same line.
Source: To Measure The measure on the source route where the reassignment ends, shown by the red point.
Target: Route Name The route to which the reassigned portion will be added. This can also be a new route.
Target: From Measure The start measure on the reassigned portion.
Target: To Measure The end measure on the reassigned portion.
The following table lists parameters used for nonline networks in the Reassign Route tool:
Network The network in which the routes exist.
Source: Route Name/ID The route where the reassignment starts.
Target: Route Name/ID The route to which the reassigned portion will be added. This can also be a new route.
There are three methods where you can implement the parameters above using the Reassign Route tool:
  • Merge to adjacent route—Either a portion of a route, the entire route, or multiple routes can be reassigned and merged with the adjacent route.
  • Form a new route—A new route is created either by merging source routes if multiple routes are selected in the source or by splitting the source route if a portion of a route is selected in the source. A route can also be renamed by selecting an entire route and providing a new route name or ID.
  • Transfer to another line—Routes are transferred to a new line if a new line name is provided, or routes are transferred to an adjacent line if an existing line name is provided.
Route reassignment scenarios
Scenarios that can be accomplished using the Reassign Route tool are described below. In the scenarios described below, you can select entire routes or partial routes.
Route merges to an existing route
Route X and Route Y are adjoining routes. You can use the Reassign Route tool to merge Route X with Route Y or vice versa. The existing Route X and Route Y are retired and a new Route Y is created on the date of reassignment. You can merge the reassigned portion to any immediate upstream or downstream route.
The date of reassignment is 1/1/2010.
Route X ends where Route Y starts.
Output for merging to an existing route
The following shows routes before reassignment:
Route ID From Date To Date
RouteX 1/1/2005 <Null>
RouteY 1/1/2005 <Null>
The following are inputs used for the Reassign Route tool:
Method
Source
Route ID
RouteX
From Measure
To Measure
20
Target
Route ID
RouteY
From Measure
To Measure
20
The following show routes after reassignment:
RouteX 1/1/2005 1/1/2010
RouteY 1/1/2005 1/1/2010
RouteY 1/1/2010 <Null>
Split to an existing route
Route XYZ has measures from 0 to 30. In the following example, the route is split in two: a new Route 1 and a new version of Route XYZ. The existing Route XYZ is retired as a result of this operation.
Input for splitting existing Route XYZ
Output for splitting existing Route XYZ with a new Route 1
The following shows the route before reassignment:
RouteXYZ 1/1/2005 <Null>
Method
Form a new route
Source
Route ID
RouteXYZ
From Measure
To Measure
19
Target
Route ID
Route1 (new)
From Measure
10
To Measure
29
The following shows routes after reassignment:
RouteXYZ 1/1/2005 1/1/2010
RouteXYZ 1/1/2010 <Null>
Route1 1/1/2010 <Null>
Route is renamed
You can rename an existing route and change its start (from) and end (to) measure values using the Reassign Route tool. In the following example, Route XYZ is renamed Route 123 and contains new measures. The existing Route XYZ is retired as a result of this operation.
Tip:
Use the Rename Route tool to rename all of the route records across all of the time slices without creating more time slices.
Input for renaming Route XYZ
Output for renaming a route when Route XYZ is renamed Route 123 and retired
Method
Form a new route
Source
Route ID
RouteXYZ
From Measure
To Measure
30
Target
Route
Route123
From Measure
15
To Measure
45
Route123 1/1/2010 <Null>
Route reassignment in a line network
Routes in a line network can be reassigned to new or existing routes as shown in the following examples.
Multiple routes merge to a new route
Route X, Route Y, and Route Z are consecutive routes that belong to the same line, Line 1. You can use the Reassign Route tool to merge all of them together into a new route, Route XYZ, which belongs to the same line.
Diagram of route before reassignment Diagram of route that is merged after reassignment
Route Name Line Name From Date To Date Line Order
RouteX Line1 1/1/2005 <Null> 100
RouteY Line1 1/1/2005 <Null> 200
RouteZ Line1 1/1/2005 <Null> 300
Method
Form a new route
Source
From Route
RouteX
From Measure
10
To Route
RouteZ
To Measure
60
Target
Route
RouteXYZ
From Measure
To Measure
30
Route XYZ has the line order of 100. Route X, Route Y, and Route Z are retired as a result of this operation. You can choose new start and end measure values for Route XYZ.
RouteX Line1 1/1/2005 1/1/2010 100
RouteY Line1 1/1/2005 1/1/2010 200
RouteZ Line1 1/1/2005 1/1/2010 300
RouteXYZ Line1 1/1/2010 <Null> 100
  • Both the From Route and the To Route values from the Source section can be partially reassigned.
  • Line orders of the remaining routes in the source line may be recalculated as a result.
Route X and Route Y are consecutive routes that belong to Line 1. You can use the Reassign Route tool to merge them with Route Z, which belongs to the adjoining Line 2.
The reassigned portion is from the start of Route X to the end of Route Y. The date of reassignment is 1/1/2010.
Diagram of routes to be merged into a single route before reassignment Diagram of merged routes into a single route after reassignment
RouteZ Line2 1/1/2005 <Null> 100
The following inputs are used for the Reassign Route tool:
Method
Source
From Route
RouteX
From Measure
10
To Route
RouteY
To Measure
40
Target
Route
RouteZ
From Measure
To Measure
20
In this example, the target route's start measure is set as 0. After clicking the Recalculate To Measure button , the To Measure input value becomes 20. 0 and 20 represent the start and end measure of the reassigned portion, respectively. The Recalibrate route downstream check box is checked.
After reassignment, Route X, Route Y, and Route Z are retired. The end measure of Route Z is 30 because the source measure length of Route X and Route Y, 20, is added to the source measure length of Route Z, 10.
RouteZ Line2 1/1/2005 1/1/2010 100
RouteZ Line2 1/1/2010 <Null> 100
  • Any one of the From Route and To Route values from the Source section can be partially reassigned to any immediate upstream or downstream route.
  • Routes from one line can be merged to an adjoining route in another line. Either the From Route or To Route value from the Source section in one line should touch the start or end of the target route in another line.
  • Routes from a line can be merged to an existing adjoining route in the same line.
Route splits
Route Z has measures from 40 to 60. As shown in this example, you can split the route into two: Route Y, which is a new route, and a new version of Route Z.
Diagram depicting route before splitting Diagram depicting routes split after reassignment
RouteZ Line1 1/1/2005 <Null> 200
Method
Form a new route
Source
From Route
RouteZ
From Measure
40
To Route
RouteZ
To Measure
50
Target
Route
RouteY
From Measure
30
To Measure
40
The source is not recalibrated downstream.
The existing Route Z retires as a result of this operation. Route Y has the line order of Route Z, and the new version of Route Z has the next line order value.
RouteZ Line1 1/1/2005 1/1/2010 200
RouteY Line1 1/1/2010 <Null> 200
RouteZ Line1 1/1/2010 <Null> 300
  • Choose the same From and To source route to split a single route.
Route splits and merges
Route Y has measures from 30 to 40. As shown in this example, you can split the route and then merge one of the parts to the adjoining route Route Z.
Diagram depicting route before splitting and merging Diagram depicting route after reassignment
The following are inputs for the Reassign Route tool:
Method
Source
From Route
RouteY
From Measure
35
To Route
RouteY
To Measure
40
Target
Route
RouteZ
From Measure
50
To Measure
55
The Recalibrate route downstream check box is checked. The existing Route Y and Route Z retire because of this operation. The new time slice of Route Y has the same line order as the previous one. The other split part of Route Y is merged to Route Z.
Route is renamed
You can rename an existing route and change its start and end measure values using the Reassign Route tool. Route X is renamed Route X_New and has new measures. The line order remains the same. The existing Route X retires because of this operation.
Diagram depicting route before reassignment Diagram depicting route after reassignment
Tip:
Method
Form a new route
Source
From Route
RouteX
From Measure
10
To Route
RouteX
To Measure
20
Target
Route
RouteX_New
From Measure
10.1
To Measure
20.1
RouteX_New Line1 1/1/2010 <Null> 100
Route transfers to an existing line
Routes can be transferred entirely or partially to an existing line. In this case, the reassigned portion must be on either the upstream or downstream end of the source line. As shown in the example, Route Z belongs to Line 2. You can take Route Z from Line 2 and transfer it to an existing adjoining line, Line 1.
Diagram of existing routes before transfer Diagram of routes after reassignment
Method
Source
From Route
RouteZ
From Measure
50
To Route
RouteZ
To Measure
60
Target
Line Name
Line1
Route
RouteZ
From Measure
50
To Measure
60
The original Route Z is retired on the date of reassignment. Route Z is recreated on Line 1 with the date of reassignment as its start date and its line order is updated.
  • Multiple adjoining routes from a line can be transferred to an adjoining line.
  • Line orders of the existing routes in the target line may be recalculated as a result.
  • If the source routes are transferred to another line in entirety, the original route names and route IDs as well as their measurements can be preserved. Alternatively, you can provide a new route name and start and end measures for the transferred routes.
  • If a portion of the source routes are transferred to another line, the original route names cannot be preserved, and a new route name must be selected for the transferred route.
Route transfers to a new line
Routes can be transferred entirely or partially to a new line. As shown in the example, Route Z belongs to Line 1. You can transfer it to a new line, Line 2.
Diagram depicting routes before transfer to a new line Diagram depicting routes after transfer to a new line
Method
Source
From Route
RouteZ
From Measure
50
To Route
RouteZ
To Measure
60
Target
Line Name
Line2
Route
RouteZ
From Measure
50
To Measure
60
The original Route Z is retired on the date of reassignment. Route Z is recreated on Line 2 with the date of reassignment as its start date and its line order is updated.
  • Multiple adjoining routes from a line can be transferred to a new line.
  • If the source routes are transferred to a new line in entirety, the original route names and route IDs, as well as their measurements, can be preserved. Alternatively, you can provide a new route name and start and end measures for the transferred routes.
  • If a portion of the source routes are transferred to a new line, the original route names cannot be preserved, and a new route name must be provided for the transferred route.
Calibration point transfers to a target route
Routes may contain calibration points to maintain known measures between points. When reassigning the route, there is an option to transfer the calibration points contained in the reassigned portion to the target route.
The Transfer calibration points to target route check box is checked by default and is the preferred method to maintain established measures.
Transferring calibration points to a target route
Newly transferred calibration points
The following are the inputs used for the Reassign Route tool:
Method
Form a new route
Source
From Route
RouteX
From Measure
To Route
RouteZ
To Measure
30
Target
Route
RouteXYZ (new)
From Measure
To Measure
25
In the following example, the date of reassignment is 1/1/2010.
Input for transferring calibration points to a target route
Output for transferring calibration points to a target route
Method
Source
Route ID
RouteX
From Measure
To Measure
20
Target
Route
RouteY
From Measure
To Measure
30
Downstream recalibration
The following examples describe downstream recalibration. You can choose whether to recalibrate the source route downstream when you reassign routes.
Reassignment with the source route not calibrated downstream
Route X is split into two routes: Route X and Route 1. Route 1 starts at the beginning of the old Route X and ends at the middle of the old Route X. The end measure value for the new Route 1 is set as 3 instead of the suggested measure of 5. The downstream measures for Route X remain intact because the Recalibrate route downstream check box is unchecked for the source route.
A source route before reassignment of a Route X section is split and not calibrated downstream
Newly reassigned section of Route 1 and Route X with the source route not calibrated downstream
Route Name From Date To Date
Method
Form a new route
Source
From Route
RouteX
From Measure
To Route (This option is only for line networks.)
RouteX
To Measure
Target
Route
Route1 (new)
From Measure
To Measure
RouteX 1/1/2010 <Null>
Reassignment with the source route calibrated downstream
Route X is split into two routes: Route X and Route 1. Route 1 starts at the beginning of the old Route X and ends at the middle of the old Route X. The end measure value for the new Route 1 is set as 3 instead of the suggested measure of 5. If the Recalibrate route downstream check box is checked for the source route, the downstream route's (Route X) measures change to a start measure value of 0 and an end measure value of 5.
A source route before reassignment of a Route X section is split and calibrated downstream
Newly reassigned section of Route 1 and Route X with the source route calibrated downstream
Method
Form a new route
Source
From Route
RouteX
From Measure
RouteX
To Measure
Target
Route
Route1 (new)
From Measure
To Measure
Reassignment with the target route calibrated downstream
A part of Route X is merged with the adjoining route, Route Y. The reassignment takes place from the middle of Route X on the downstream side. Because the Recalibrate route downstream check box is checked for the target route, the measure of Route Y downstream of the reassigned portion is recalibrated. The new version of Route Y now has an end measure value of 9.
Input for reassignment of a section of Route X merged with Route Y with the target route calibrated downstream
Output for reassignment with the target route calibrated downstream
Method
Source
From Route
RouteX
From Measure
To Measure
10
Target
Route
RouteY
From Measure
To Measure
9
Complex route reassignment scenarios
Complex route reassignment scenarios for complex routes and shapes, including loop, lollipop, branch, and barbell shapes are described below.
Reassignment resulting in a loop
In the following example, Route X and Route Y are merged to create a loop route after reassignment. Route X has measures 0 to 2 and Route Y has measures 0 to 2:
Input for reassignment resulting in a loop
Method
Source
From Route
RouteX
From Measure
To Measure
Recalibrate source route
No
Target
To Route
RouteY
From Measure
To Measure
Recalibrate target route
Yes
The date of reassignment is 1/1/2010. After reassignment, a calibration point is added at measure 1, and Route Y is recalibrated with measures 0 to 4.
Output for reassignment resulting in a loop
RouteY Line1 1/1/2010 <Null> 100
In the following example, Route X and Route Y are merged to create a loop route after reassignment. Route X has measures 0 to 2, and Route Y has measures 2 to 4:
Example 1: Input for reassignment resulting in a loop
Method
Source
From Route
RouteX
From Measure
To Measure
No
Target
To Route
RouteY
From Measure
To Measure
Yes
Example 1: Output for reassignment resulting in a loop
Loop splits
In the following example, Route X, on a loop with measures 0 to 12, is split and the edit section is reassigned to a new route (Route Y):
Input for splitting an existing loop
Method
Form a new route
Source
From Route
RouteX
From Measure
To Measure
Yes
Target
To Route
RouteY
From Measure
To Measure
The date of reassignment is 1/1/2010. After reassignment, Route Y is created with measures 0 to 4. The calibration point formerly at 8 is updated to 4, and Route X is recalibrated with measures 0 to 8.
Route X retains its line order of 100, and the new Route Y is assigned a line order of 200.
Output for split an existing loop
RouteX Line1 1/1/2010 <Null> 100
Example 1: Input for splitting an existing loop
Method
Form a new route
Source
From Route
RouteX
From Measure
To Measure
Yes
Target
To Route
RouteY
From Measure
To Measure
Example 1: Output for splitting an existing loop
Reassignment resulting in a lollipop
Route X has measures 0 to 4 and Route Y has measures 0 to 1. In the following example, a loop route (Route X) is merged with a simple route (Route Y) to create a lollipop route after reassignment:
Input for reassignment resulting in a lollipop
RouteY Line1 1/1/2005 <Null> 100
RouteX Line1 1/1/2005 <Null> 200
Method
Source
From Route
RouteX
From Measure
To Measure
No
Target
To Route
RouteY
From Measure
To Measure
Yes
The date of reassignment is 1/1/2010. After reassignment, the resulting lollipop route (Route Y) has updated measures 0 to 5.
The line order for Route Y is updated from 200 to 100.
Output for reassignment resulting in a lollipop
RouteY Line1 1/1/2005 1/1/2010 100
RouteX Line1 1/1/2005 1/1/2010 200
Example 1: Input for reassignment resulting in a lollipop
Method
Source
From Route
RouteX
From Measure
To Measure
No
Target
To Route
RouteY
From Measure
To Measure
Yes
Example 1: Output for reassignment resulting in a lollipop
Lollipop splits
Route X has measures 0 to 5 and Route Y has measures 0 to 1. In the following example, the stick portion of a lollipop route (Route X) is split and reassigned to an existing route (Route Y):
Input for splitting an existing lollipop
Method
Source
From Route
RouteX
From Measure
To Measure
Yes
Target
To Route
RouteY
From Measure
To Measure
Yes
The date of reassignment is 1/1/2010. After reassignment, both routes are recalibrated. The updated simple route (Route Y) has measures 0 to 2, and the loop route (Route X) has measures 0 to 4.
The line order for the two routes remains the same.
Output for split an existing lollipop
Example 1: Input for splitting an existing lollipop
Method
Source
From Route
RouteX
From Measure
To Measure
Yes
Target
To Route
RouteY
From Measure
To Measure
Yes
Example 1: Output for splitting an existing lollipop
Multiple routes merge to create a barbell
In the following example, a loop route (Route X) with measures 0 to 4 is merged with a lollipop route (Route Y) that has measures from 0 to 5:
Input for merge multiple routes to create a barbell
Method
Form a new route
Source
From Route
RouteX
From Measure
To Route
RouteY
To Measure
No
Target
Target Route
RNew
From Measure
To Measure
9
The date of reassignment is 1/1/2010. After reassignment, a new barbell route (RNew) is created from the merged routes. RNew has recalibrated measures 0 to 9.
The new route has line order 100.
Output for merge multiple routes to create a barbell
RNew Line1 1/1/2010 <Null> 100
Example 1: Input for merging multiple routes to create a barbell
Method
Source
From Route
RouteX
From Measure
To Measure
No
Target
Target Route
RouteY
From Measure
To Measure
9
Yes
The date of reassignment is 1/1/2010. After reassignment, a new barbell route (Route Y) is created from the merged routes. Route Y has recalibrated measures from 0 to 9.
Example 1: Output for merging multiple routes to create a barbell
Simple routes merge to create a branch
Route Y and Route Z have contiguous measures of 0 to 5 and 6 to 11, respectively, and Route X has measures 0 to 6. In the following example, two simple routes (Route Y and Route Z) are merged with a third simple route (Route X) to create a branch route after reassignment:
Input for merge simple routes to create a branch
Method
Source
From Route
RouteY
From Measure
To Route
RouteZ
To Measure
11
No
Target
To Route
RouteX
From Measure
6
To Measure
16
Yes
The date of reassignment is 1/1/2010. After reassignment, Route Y and Route Z are merged with Route X to create a branch route that has recalibrated measures 0 to 16.
The line order for the remaining route remains 100.
Output for merge simple routes to create a branch
In this example, a simple route (Route Y) is merged to another simple route (Route X) to create a branch route after reassignment. Route X has measures 0 to 6, and Route Y has measures from 5 to 10.
Example 1: Input for merging simple routes to create a branch
Method
Source
From Route
RouteY
From Measure
To Measure
10
No
Target
To Route
RouteX
From Measure
6
To Measure
11
Yes
The date of reassignment is 1/1/2010. After reassignment, Route Y is merged with Route X to create a branch route with recalibrated measures 0 to 11.
Example 1: Output for merging simple routes to create a branch
Infinity route splits
In the following example, an existing infinity route (Route X) with measures 0 to 24 is split to create an alpha route and a new simple route (RNew):
Input for splitting an infinity route
Method
Form a new route
Source
From Route
RouteX
From Measure
18
To Measure
24
Yes
Target
To Route
RNew
From Measure
To Measure
6
The date of reassignment is 1/1/2010. After reassignment, Route X is an alpha route with measures 0 to 18, and RNew has measures 0 to 6.
The line order for Route X remains 100, and the line order for RNew is 200.
Output for split an infinity route
RNew Line1 1/1/2010 <Null> 200
Example 1: Input for splitting an infinity route
Method
Form a new route
Source
From Route
RouteX
From Measure
18
To Measure
24
Yes
Target
To Route
RNew
From Measure
To Measure
6
Example 1: Output for splitting an infinity route
RNew 1/1/2010 <Null>
