Event behavior for route reassignment
Available with the Linear Referencing license.
When you reassign a route, events are impacted in the edit section and upstream and downstream of the reassignment, depending on the configured event behavior for the event layer.
Events are not updated until you run the Apply Event Behaviors tool after route edits. If conflict prevention is enabled, you are prompted to run the Apply Event Behaviors tool before posting to the default version.
When you check the Recalibrate route downstream option during route editing, the tool applies the event behavior for route calibration to downstream sections. You can review configured event behaviors by viewing the LRS event properties.
There are three methods for route reassignment:
Merge to adjacent route—Reassign and merge a portion of a route, the entire route, or multiple routes with the adjacent route.
Form a new route—Create a new route either by merging source routes if you select multiple routes in the source or by splitting the source route if you select a portion of a route in the source. You can also rename a route by selecting an entire route and providing a new route name or ID.
Transfer to another line—Transfer routes to a new line if you provide a new line name, or to an adjacent line if you provide an existing line name.
