Add and modify table frames
Table frames are containers for tables on a page. They can reference a feature table in any map or scene in a project. The table's fields can be added or removed from the table frame at any time, and the table frame updates automatically on the layout. You can modify the format of the entire frame or individual fields by selecting them in the Contents pane.
Table frames can be static—displaying all records in the table—or they can be dynamic—updating whenever the map frame extent is changed to show only the records visible in the map extent. The behavior of the table is determined by the set query.
Insert a table frame
To insert a table frame, complete the following steps:
Open a layout with a map frame.
Table frames can only point to data that exists in a map frame on the layout. If there is no map frame, the table frame is blank.
In the Contents pane, select the layer to use to create the table.
On the Insert tab, in the Map Surrounds group, click Table Frame.
Click the upper half of the button to insert the current default table style item. Click the lower half of the button to choose from a gallery of table frame style items.
On the layout, draw a rectangle to define the limits of the table frame.
Display fields
By default, the first 10 fields of a table are displayed. After a table frame is added to the layout, the fields can be added, removed, reordered, or turned on and off. If there is not enough space on the table for all the fields to appear, fields are dropped from the table and the overflow icon
appears. If you resize the table or change the fitting strategy so all fields appear, the icon disappears.
The visibility setting for each field is honored. If a field is missing, confirm the field's visibility in the Contents pane. To switch its visibility, check its check box.
Add fields
To add fields to the table frame, complete the following steps:
In the Contents pane, right-click the table frame and click Add field.
Select a field from the menu.
To change the order of the fields in the table frame, in the Contents pane, expand the table frame and drag the fields to the new locations.
Edit fields
Table frame fields use the formatting (aliases, significant digits, and so on) set up in the Fields view. To edit the fields in this view, complete the following steps:
Right-click the table frame and click Open.
On the Table tab, in the Field group, click Fields.
Make the appropriate changes.
Modify a table frame
To modify a table frame, select the table frame in the Contents pane and click the Table Frame tab on the ribbon. Here, you can change the text symbol and its size and position. Additional options are available in the Element pane, which you can open by right-clicking the table frame in the Contents pane and choosing Properties. To modify individual fields, see Add and modify table frame fields.
Once you've modified the table frame, you can save it to a style to use in future projects without reformatting it. A saved table style item can be applied to a selected table by choosing one from the Table Frame Gallery drop-down menu
on the Table Frame tab.
Options
In the Element pane, the following can be set under Options:
Name—Change the name of the table as it appears in the Contents pane.
Visible—Turn the table's visibility on or off on the layout.
Locked—Lock the table so it can no longer be selected on the layout.
Maximum scale
—Choose the maximum scale at which the table frame is visible. When the map frame is zoomed in beyond this scale, the table frame doesn't draw on the layout.Minimum scale
—Choose the minimum scale at which the table frame is visible. When the map frame is zoomed out beyond this scale, the table frame doesn't draw on the layout.Display only when populated—Draw the table frame only if data is being returned. When this is unchecked, the table frame headers and decorations draw even if there is no data in the table.
Map frame—Choose the map frame containing the layer or stand-alone table the table frame references. If you change this value, the Table combo box is automatically updated to the first stand-alone table in the map, or the first layer if no stand-alone tables exist.
Table—Choose the layer or stand-alone table the table frame references.
Query—Choose the data rows to display. You can display all rows, only rows for features visible in the map frame's extent, or if the layout contains a spatial map series, single rows for each index feature.
Filter—Apply an SQL query to filter the table data further. The filter is applied on top of the set query.
Row limit—Set the maximum number of rows displayed in the table frame. The limit is applied after the query type and any filters.
Fields—Modify field appearance and display properties for all fields. For more information, see Add and modify table frame fields.
For stand-alone tables, the only query option is All rows because a stand-alone table is not visible in the map extent. Additionally, when using the Visible rows query, visibility within the map extent is determined by the symbol visibility not the coordinate values.
Table frame arrangement
You can also modify the arrangement of the fields in the table frame.
Fitting strategy
By default, fields take up the entire frame. The fields expand or compress as you resize the table frame, and the table frame expands or compresses when fields are added or removed. The following fitting options change the behavior of the table and its items:
Adjust font size—Adjusts the table to fit the frame by automatically reducing the font size or increasing the number of frame columns. You can set the minimum font size along with the maximum number of frame columns, and the application reduces the font size up to the minimum size or increases the number of frame columns up to the maximum value as needed.
Adjust columns—Adjusts the table to fit the frame by automatically flowing rows to multiple frame columns.
Adjust columns and font size—Adjusts the table to fit the frame by automatically flowing rows to multiple frame columns and reducing the font size. You can set the minimum font size, and the application reduces the font size up to the minimum size as needed.
You can also check the Balance columns option for any fitting strategy to make all the table columns approximately the same length. This may result in all the columns being smaller than the table frame length. Uncheck this option to have one column fill completely before a new column is added. This may result in the last column being smaller than the others.
If a column does not fit when you complete the fitting strategy, the entire field is dropped from the table frame. For example, if a table frame item contains 15 records but only 10 records fit, the entire field is dropped. When this occurs, you cannot add items to the table frame even if another field in the list fits. Keep this in mind when ordering items in the table frame. If any items are dropped from the table frame, the overflow icon
appears.
When fitting a field into the frame, column settings for individual fields are respected unless Adjust columns is selected as the fitting strategy. With Adjust columns selected, column settings for fields are overridden and a new column is created whenever the entire height of the table frame is filled.
If Adjust font size is selected, table contents are compressed to fit more items into the table until a minimum font size is reached. Once this font size is reached by any field, fields that do not fit are dropped.
The fitting strategies that adjust font size include an option to specify the Minimum font size threshold, so as the table frame is adjusted, the font size is never smaller than the specified size.
Sorting
Sorting is an efficient means of organizing data in alphabetical or sequential order, which can help you better understand it. You can discover the largest and smallest values or the most and least significant features in the table. When sorting a column's values in ascending order, the values are ordered from A to Z or from 1 to 10. In descending order, a column's values are arranged from Z to A or from 10 to 1. To add fields to sort, click the Add button
. With multiple fields, you can interactively sort using a table sorting dialog box, which allows you to sort more than one column. Use the custom sort box to sort based on multiple fields, clear the current sort order of the table, or make a case-sensitive sort.
Spacing
Gaps allow you to specify the vertical and horizontal spacing between table frame elements. The following options can be adjusted by changing their point value:
Columns—The gap between each column
Headings and rows—The vertical gap between the heading and rows
Text and border (horizontal)—The horizontal margin of the text
Text and border (vertical)—The vertical margin of the text
Display
The table and its frame, heading, rows, and fields can also be symbolized individually. Each border, background, and shadow can be formatted to individual specifications using the following options:
Table Frame—The symbol of the frame's border, background, and shadow symbols can be modified and their corners rounded. The x and y gaps allow you to specify the vertical and horizontal spacing between elements.
Table—The text symbol for all text in the table, all borders around each cell, and the border around the column frame can be specified.
Heading—Add a border, add or change the underline symbol, and add or change a background for all headings. Uncheck Show heading to remove all headings from the table.
Rows—Set a border around each row. Backgrounds 1 and 2 allow you to alternate background colors for a more effective reading of the table.
Fields—Modify field appearance and display properties for multiple fields. For more information, see Add and modify table frame fields.
Individual cells in a table frame cannot be formatted. To highlight specific cell values, consider using dynamic text outside of the table.
Placement
To change the table frame's size and position, adjust the width, height, x and y positions, and rotation. To preserve the aspect ratio when selected elements are resized, click the link button.
