Procedural symbology
Procedural symbology uses script-based logic to construct complex 3D objects and textures from simple geometries to display point, polygon, or multipatch features. For example, procedural symbology can be used to render point features as realistic-looking trees, polygon features as seventeenth-century Parisian buildings, or multipatch features with rule-based painted textures.
Both fill symbol layers and marker symbol layers can be procedural when they are in a 3D context. In a 2D context, procedural symbol content is ignored and does not draw.
Procedural symbols leverage the logic in a CityEngine rule package (.rpk) to draw features. Rule packages are designed such that certain symbol properties are exposed for configuration. You can customize the appearance of procedural symbol layers by adjusting these symbol properties or by connecting the properties to feature attribute fields.
ArcGIS Pro includes system styles with symbols that contain procedural symbol layers. Alternatively, you can author procedural symbols in CityEngine and export them as .rpk files for use in ArcGIS Pro. You can find and download additional rule packages in ArcGIS Online.
Tip:
When searching a gallery for symbols that contain procedural layers, you can type procedural or rpk as a search term.
When searching ArcGIS Online for rule packages, search for rpk.
To make a procedural symbol, complete the following steps:
In the Contents pane, click the symbol to modify.
The Symbology pane appears in Format Symbol mode, displaying the current symbol.
In the Symbology pane, switch to the Properties view and click the Layers tab
to see the symbol layers of the current symbol.There may be only one symbol layer.
Highlight an existing marker symbol layer or fill symbol layer in the symbol, or from the Structure tab
, add a new symbol layer first.Procedural marker symbol layers can only exist within point symbols. Procedural markers along a line, along a polygon outline, or within a polygon are not supported.
Procedural fill symbol layers can exist in polygon symbols, mesh symbols, point symbols (with a symbol effect), and line symbols (with a symbol effect).
On the drop-down menu in the heading of the symbol layer, choose Procedural marker (for marker symbol layers) or Procedural fill (for fill symbol layers).
Click the Rule button to choose a rule package.
Marker symbol layer (in a point symbol)
The
@StartRuleof the rule package must specify@InPointannotation to indicate that it is intended for point geometry.Fill symbol layer in a polygon, point, or line symbol
The
@StartRuleof the rule package must specify@InPolygonannotation to indicate that it is intended for polygon geometry.Fill symbol layer in a mesh symbol
The
@StartRuleof the rule package must specify@InMeshannotation to indicate that it is intended for multipatch geometry.The properties exposed by the rule package are shown in the pane. Symbol properties in a rule package whose name and data type match feature attribute fields are automatically connected to that field.
The properties of the procedural rule have a default value, which is shown next to each property. But the power of procedural symbology comes when you connect some of these properties to fields in the data or write expressions. To do either of these, click the No attribute mapping defined button
next to a property. On the Set attribute mapping dialog box, choose a field or write an expression in ArcGIS Arcade or VBScript by clicking the Set an expression button
.Caution:
With Windows 11, version 24H2, VBScript becomes a feature on demand and requires the VBScript capability.
Do one of the following:
Convert the expression type to Python or Arcade.
Enable the VBScript optional feature in the Windows system settings.
Tip:
Consider removing all other symbol layers, as they will likely interfere with the appearance of the procedural symbol layer. On the Structure tab
, click the Delete button
next to a symbol layer to delete it.
