| Name | Description | |
![]() | Activated | Occurs when an application becomes the foreground application. (Inherited from System.Windows.Application) |
![]() | Deactivated | Occurs when an application stops being the foreground application. (Inherited from System.Windows.Application) |
![]() | DispatcherUnhandledException | Occurs when an exception is thrown by an application but not handled. (Inherited from System.Windows.Application) |
![]() | Exit | Occurs just before an application shuts down, and cannot be canceled. (Inherited from System.Windows.Application) |
![]() | FragmentNavigation | Occurs when a navigator in the application begins navigation to a content fragment, Navigation occurs immediately if the desired fragment is in the current content, or after the source XAML content has been loaded if the desired fragment is in different content. (Inherited from System.Windows.Application) |
![]() | LoadCompleted | Occurs when content that was navigated to by a navigator in the application has been loaded, parsed, and has begun rendering. (Inherited from System.Windows.Application) |
![]() | Navigated | Occurs when the content that is being navigated to by a navigator in the application has been found, although it may not have completed loading. (Inherited from System.Windows.Application) |
![]() | Navigating | Occurs when a new navigation is requested by a navigator in the application. (Inherited from System.Windows.Application) |
![]() | NavigationFailed | Occurs when an error occurs while a navigator in the application is navigating to the requested content. (Inherited from System.Windows.Application) |
![]() | NavigationProgress | Occurs periodically during a download that is being managed by a navigator in the application to provide navigation progress information. (Inherited from System.Windows.Application) |
![]() | NavigationStopped | Occurs when the StopLoading method of a navigator in the application is called, or when a new navigation is requested by a navigator while a current navigation is in progress. (Inherited from System.Windows.Application) |
![]() | SessionEnding | Occurs when the user ends the Windows session by logging off or shutting down the operating system. (Inherited from System.Windows.Application) |
![]() | Startup | Occurs when the System.Windows.Application.Run method of the System.Windows.Application object is called. (Inherited from System.Windows.Application) |
