| Name | Description | |
![]() ![]() | ActiveTab | Gets the DAML identifier of the currently active ribbon tab. |
![]() ![]() | ActiveTool | Gets the application's current tool. Only one tool is active at a time. |
![]() ![]() | ActiveWindow | Gets the ArcGIS.Desktop.Framework.Contracts.Pane or ArcGIS.Desktop.Framework.Contracts.DockPane that is currently active. |
![]() ![]() | ApplicationProperties | Gets the application properties. |
![]() ![]() | ApplicationTheme | Gets or sets the application's theme that dictates its visual style. Three themes are supported: default (metro), dark, and high contrast. |
![]() ![]() | ContextMenuDataContext | Gets the contextual data that is passed to the commands in a context menu. |
![]() ![]() | ContextMenuDataContextViewModel | Gets the current context menu's default data context as a view-model. This is for Esri internal use only. |
![]() ![]() | CurrentTool | Gets or sets the application's current tool. Only one tool is active at a time. |
![]() | Dispatcher | Gets the System.Windows.Threading.Dispatcher this System.Windows.Threading.DispatcherObject is associated with. (Inherited from System.Windows.Threading.DispatcherObject) |
![]() ![]() | DockPaneManager | Gets all the active dockpane instances; this singleton also lets you activate, create, and close dockpanes. |
![]() ![]() | EventAggregator | Gets the application's event aggregator. |
![]() ![]() | FloatingWindowName | Gets the default floating window name. |
![]() ![]() | FlowDirection | Gets the content flow direction for text and user interface elements. |
![]() ![]() | IncomingTool | Gets the Incoming tool. This is set when SetCurrentToolAsync is called. |
![]() ![]() | Initialized | Gets true once the application shell has been loaded and a license has been acquired. |
![]() ![]() | IsActive | Gets whether the application is the active application. |
![]() ![]() | IsBackstageOpen | Gets whether the application backstage is open. |
![]() ![]() | IsBusy | Gets a boolean value of true indicating the application is currently busy. |
![]() ![]() | IsEnabled | Gets or sets a value indicating whether the application's user interface is currently enabled. |
![]() ![]() | IsRibbonMinimized | Gets or sets whether the ribbon is currently minimized. |
![]() | MainWindow | Gets or sets the main window of the application. (Inherited from System.Windows.Application) |
![]() ![]() | Name | Gets or sets the application's name which is displayed in the application's title bar. Note, the title bar will switch to the Title property if it is not empty. |
![]() ![]() | NotificationInterval | Define the time span in seconds for showing the same notification to limit the toast display frequency. |
![]() ![]() | OutgoingTool | Gets the Outgoing tool. This is set when SetCurrentToolAsync is called. |
![]() ![]() | Panes | Gets all the active pane instances; this singleton also lets you activate, create, and close panes. |
![]() | Properties | Gets a collection of application-scope properties. (Inherited from System.Windows.Application) |
![]() | Resources | Gets or sets a collection of application-scope resources, such as styles and brushes. (Inherited from System.Windows.Application) |
![]() ![]() | ScaleFactor | Get or sets the current user interface scaling factor. |
![]() | ShutdownMode | Gets or sets the condition that causes the System.Windows.Application.Shutdown method to be called. (Inherited from System.Windows.Application) |
![]() | StartupUri | Gets or sets a UI that is automatically shown when an application starts. (Inherited from System.Windows.Application) |
![]() ![]() | State | Gets the application's state object. |
![]() ![]() | SubTitle | Gets or sets the application's SubTitle. |
![]() | ThemeMode | (Inherited from System.Windows.Application) |
![]() ![]() | Title | Gets or sets the application's Title. |
![]() ![]() | TitleBarImageSource | Gets or sets the application's Titlbar image when the title has a popup. |
![]() | Windows | Gets the instantiated windows in an application. (Inherited from System.Windows.Application) |
