ArcGIS.Desktop.Framework Namespace / FrameworkApplication Class / GetPlugInWrapper Method
The DAML control identifier.
Load the component if it hasn't been created yet.
Example
    Returns a run-time wrapper around the specified DAML component.
    Syntax
    Public Shared Function GetPlugInWrapper( _
       ByVal id As String, _
       Optional ByVal create As Boolean _
    ) As IPlugInWrapper
    public static IPlugInWrapper GetPlugInWrapper(
       string id,
       bool create
    Parameters
    id
    create
    Return Value
    A
    Example
    Programmatically start Edit Annotation
    // programmatically activates the Edit Annotation tool by invoking the corresponding
    // plugin. The tool must be enabled for the operation to succeed.
      var plugin = FrameworkApplication.GetPlugInWrapper("esri_editing_EditVerticesText");
      if (plugin.Enabled)
        ((ICommand)plugin).Execute(null);
    Execute a command
      IPlugInWrapper wrapper = FrameworkApplication.GetPlugInWrapper("esri_editing_ShowAttributes");
      // tool and command(Button) supports this
      if (wrapper is ICommand command && command.CanExecute(null))
        command.Execute(null);
    Set the current tool
      // use SetCurrentToolAsync with await
      FrameworkApplication.SetCurrentToolAsync("esri_mapping_selectByRectangleTool").Wait();
      // or use ICommand.Execute
      if (FrameworkApplication.GetPlugInWrapper("esri_mapping_selectByRectangleTool") is ICommand cmd && cmd.CanExecute(null))
        cmd.Execute(null);
    Change a buttons caption or image
      IPlugInWrapper wrapper = FrameworkApplication.GetPlugInWrapper("MyAddin_MyCustomButton");
      if (wrapper != null)
        wrapper.Caption = "new caption";
        // ensure that T-Rex16 and T-Rex32 are included in your add-in under the images folder and have
        // BuildAction = Resource and Copy to OutputDirectory = Do not copy
        wrapper.SmallImage = buildImage;
        wrapper.LargeImage = buildImage2;
    Requirements
