ArcGIS.Desktop.Framework Namespace / FrameworkApplication Class / IsBusy Property
Example
    IsBusy Property (FrameworkApplication)
    Gets a boolean value of true indicating the application is currently busy.
    Syntax
    Public Shared ReadOnly Property IsBusy As Boolean
    public static bool IsBusy {get;}
    Remarks
    The application is considered busy if a task is currently running on the main worker thread or any pane or dock pane reports that it is initializing or busy.
    Example
    Determine if the application is busy
      // The application is considered busy if a task is currently running on the main worker thread or any
      // pane or dock pane reports that it is busy or initializing.
      // Many Pro styles (such as Esri_SimpleButton) ensure that a button is disabled when FrameworkApplication.IsBusy is true
      // You would use this property to bind to the IsEnabled property of a control (such as a listbox) on a dockpane or pane in order
      // to disable it from user interaction while the application is busy.
      bool isbusy = FrameworkApplication.IsBusy;
    Requirements
