Parameters
- action
- The method to call.
- name
- The name of the new operation.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run |
Many API calls will automatically create operations and add them to the appropriate operation stack (OperationManager). If your function produces adds several operations to the stack and you instead only want to see one operation, use this function to group them.
Note, operations belonging to different categories cannot be interleaved. When a composite operation is being created, every operation belonging to a different ArcGIS.Desktop.Framework.Contracts.Operation.Category will start a new ArcGIS.Desktop.Framework.Contracts.CompositeOperation. For example, if your method calls five functions (A [category: Editing], B [Editing], C [Mapping], D [Mapping], E [Editing]), three composite operations will be created as two additional category shifts have occurred (Editing, Mapping, Editing).
