ArcGIS.Desktop.Framework Namespace / OperationManager Class / RedoAsync Method / RedoAsync() Method
Example
    RedoAsync() Method
    Redo the top operation on the redo stack.
    Syntax
    Public Overloads Overridable Function RedoAsync() As Task
    public virtual Task RedoAsync()
    Return Value
    A task that represents the work queued to execute in the ThreadPool.
    Exceptions
    ExceptionDescription
    If no operations are in the stack or the operation can't be redone.
    Remarks
    Awaits redoing the most recent operation in the redo stack and then adds it to the undo stack.
    Example
    Undo/Redo the Most Recent Operation
    // Demonstrates how to undo and redo the most recent operation using the map's operation manager.
      //undo
      if (activeMap.OperationManager.CanUndo)
        activeMap.OperationManager?.UndoAsync();//await as needed
      //redo
      if (MapView.Active.Map.OperationManager.CanRedo)
        activeMap.OperationManager?.RedoAsync();//await as needed
    Dockpane undo / redo
      // in order to find a dockpane you need to know its DAML id
      pane = FrameworkApplication.DockPaneManager.Find(dockPaneID);
      // get the undo stack
      OperationManager manager = pane.OperationManager;
      if (manager != null)
        // undo an operation
        // Use await with UndoAsync and RedoAsync
        if (manager.CanUndo)
          manager.UndoAsync().Wait();
        // redo an operation
        if (manager.CanRedo)
          manager.RedoAsync().Wait();
        // clear the undo and redo stack of operations of a particular category
        manager.ClearUndoCategory("Some category");
        manager.ClearRedoCategory("Some category");
    Requirements
