ArcGIS.Desktop.Framework Namespace / OperationManager Class / UndoAsync Method / UndoAsync(String) Method
The category of operation of undo.
Example
    Rolls back the most recent operation belonging to a specific category.
    Syntax
    Public Overloads Overridable Function UndoAsync( _
       ByVal category As String _
    ) As Task
    public virtual Task UndoAsync(
       string category
    Parameters
    category
    Return Value
    A task that represents the work queued to execute in the ThreadPool.
    Exceptions
    ExceptionDescription
    Thrown when the operation's ArcGIS.Desktop.Framework.Contracts.Operation.CanUndo method returns false.
    Remarks
    The most recent operation of a particular category in the stack is undone by calling its ArcGIS.Desktop.Framework.Contracts.Operation.UndoAsync method. The operation is then added to this OperationManager's redo stack.
    Example
    Undo/Redo Edit Operations
    // Executes an edit operation and demonstrates how to undo the operation programmatically.
    await QueuedTask.Run(() =>
      var editOp = new EditOperation
        Name = "My Name"
      if (!editOp.IsEmpty)
        //Execute and ExecuteAsync will return true if the operation was successful and false if not
        var result = editOp.Execute();
        if (result == true)
          // If the operation was successful, you can undo it
          editOp.UndoAsync();
    Undo/Redo the Most Recent Operation
    // Demonstrates how to undo and redo the most recent operation using the map's operation manager.
      //undo
      if (activeMap.OperationManager.CanUndo)
        activeMap.OperationManager?.UndoAsync();//await as needed
      //redo
      if (MapView.Active.Map.OperationManager.CanRedo)
        activeMap.OperationManager?.RedoAsync();//await as needed
    Requirements
