ArcGIS.Desktop.Framework Namespace / OperationManager Class / CanRedo Property
Example
    CanRedo Property (OperationManager)
    Gets a boolean value after checking if the first operation can be redone.
    Syntax
    Public ReadOnly Property CanRedo As Boolean
    public bool CanRedo {get;}
    Remarks
    If the operation cannot be redone, all the operations belonging to its same category are cleared from the undo stack.
    Example
    Undo/Redo the Most Recent Operation
    // Demonstrates how to undo and redo the most recent operation using the map's operation manager.
      //undo
      if (activeMap.OperationManager.CanUndo)
        activeMap.OperationManager?.UndoAsync();//await as needed
      //redo
      if (MapView.Active.Map.OperationManager.CanRedo)
        activeMap.OperationManager?.RedoAsync();//await as needed
    Dockpane undo / redo
      // in order to find a dockpane you need to know its DAML id
      pane = FrameworkApplication.DockPaneManager.Find(dockPaneID);
      // get the undo stack
      OperationManager manager = pane.OperationManager;
      if (manager != null)
        // undo an operation
        // Use await with UndoAsync and RedoAsync
        if (manager.CanUndo)
          manager.UndoAsync().Wait();
        // redo an operation
        if (manager.CanRedo)
          manager.RedoAsync().Wait();
        // clear the undo and redo stack of operations of a particular category
        manager.ClearUndoCategory("Some category");
        manager.ClearRedoCategory("Some category");
    Requirements
