ArcGIS.Desktop.Framework Namespace / PropertySheet Class / ShowDialog Method / ShowDialog(String,String,Object[]) Method
The DAML property sheet identifier.
Optionally, the DAML identifier of the page to start on.
Any data that should be made available to the pages.
    Opens the specified property sheet and returns only when the newly opened window is closed.
    Syntax
    public static Nullable<bool> ShowDialog(
       string id,
       string defaultPageID,
       params object[] parameters
    Public Overloads Shared Function ShowDialog( _
       ByVal id As String, _
       Optional ByVal defaultPageID As String, _
       ByVal ParamArray parameters() As Object _
    ) As Nullable(Of Boolean)
    Parameters
    id
    defaultPageID
    parameters
    Return Value
    A Nullable<T> value of type Boolean that specifies whether the activity was accepted (true) or canceled (false). The return value is the value of the DialogResult property before a window closes.
    Requirements
