ArcGIS.Desktop.Mapping Namespace / SymbolFactory Class / ConstructPolygonSymbol Method / ConstructPolygonSymbol(CIMFill,CIMStroke,CIMColor,SimpleStipplePattern) Method
Example
    Constructs a polygon symbol with a specific fill, stroke, and stipple pattern. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function ConstructPolygonSymbol( _
       ByVal fill As CIMFill, _
       ByVal outline As CIMStroke, _
       ByVal color As CIMColor, _
       ByVal stipplePattern As SimpleStipplePattern _
    ) As CIMPolygonSymbol
    Parameters
    fill
    outline
    color
    stipplePattern
    Return Value
    Exceptions
    ExceptionDescription
    Value cannot be null: color
    This method must be called within the lambda passed to QueuedTask.Run
    Remarks
    Specifying a null fill creates a stipple symbol with no background fill. Specifying a null stroke creates a stipple symbol with no outline. The stipple color is specified with "color". Note: the stipple pattern is generated with a marker not a fill.
    Example
    Create rectangle graphic with simple symbology
      //Create a simple 2D rectangle graphic and apply simple fill and
      //outline symbols.
      //Note: Must be on QueuedTask.Run
      //Build 2D envelope geometry
      Coordinate2D rec_ll = new Coordinate2D(1.0, 4.75);
      Coordinate2D rec_ur = new Coordinate2D(3.0, 5.75);
      Envelope rec_env = EnvelopeBuilderEx.CreateEnvelope(rec_ll, rec_ur);
      //Set symbology, create and add element to layout
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
        ColorFactory.Instance.BlackRGB, 5.0, SimpleLineStyle.Solid);
      CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
        ColorFactory.Instance.GreenRGB, SimpleFillStyle.DiagonalCross, outline);
      GraphicElement recElm = ElementFactory.Instance.CreateGraphicElement(
        layout, rec_env, polySym, "New Rectangle");
      //Or use Predefined shape
      GraphicElement recElm2 = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
                                layout, PredefinedShape.Rectangle, rec_env, polySym,
                                "New Rectangle2");
    Requirements
    ArcGIS Pro version: 3.1 or higher.
