ArcGIS.Desktop.Core Namespace / FrameworkExtender Class / CreateMapPaneAsync Method / CreateMapPaneAsync(PaneCollection,Map,Camera,Nullable<MapViewingMode>,TimeRange) Method
The project's collection of panes returned from ArcGIS.Desktop.Framework.FrameworkApplication.Panes.
The map to display in the resulting view.
Sets the camera position for the view.
Specifies the perspective of the view.
Sets the time extent for the view.
Example
    Create and activate a new map pane which is a container for a ArcGIS.Desktop.Mapping.MapView.
    Syntax
    Public Overloads Shared Function CreateMapPaneAsync( _
       ByVal paneCollection As PaneCollection, _
       ByVal map As Map, _
       ByVal camera As Camera, _
       Optional ByVal viewingMode As Nullable(Of MapViewingMode), _
       Optional ByVal timeExtent As TimeRange _
    ) As Task(Of IMapPane)
    Parameters
    paneCollection
    map
    camera
    viewingMode
    timeExtent
    Return Value
    A Task returning a map pane.
    Exceptions
    ExceptionDescription
    Map can only be set for 2D views and SceneLocal and SceneGlobal can only be set for 3D views.
    Remarks
    When a new map pane is created the ArcGIS.Desktop.Mapping.MapView needs to initialize before any operations are performed on it. Be sure to await the Task to ensure the view has finished its initialization before performing any operations on the resulting ArcGIS.Desktop.Mapping.MapView.
    Example
    How to add a new map to a project
      //Note: see also MapFactory in ArcGIS.Desktop.Mapping
      var map = await QueuedTask.Run(() =>
        MapFactory.Instance.CreateMap("New Map", MapType.Map, MapViewingMode.Map, Basemap.Oceans));
      ArcGIS.Desktop.Framework.FrameworkApplication.Panes.CreateMapPaneAsync(map);
    Find a map within a project and open it
      //Finding the first project item with name matches with mapName
      MapProjectItem? mpi = Project.Current.GetItems<MapProjectItem>()
        .FirstOrDefault(m => m.Name.Equals("The Map", StringComparison.CurrentCultureIgnoreCase));
      var mapFromItem = await QueuedTask.Run(() => mpi?.GetMap());
      if (mapFromItem != null)
        //Open the map in a new map pane
        //Must be called from the UI thread
        await ProApp.Panes.CreateMapPaneAsync(map);
    Open a webmap
      //Assume we get the selected webmap from the Project pane's Portal tab
      if (Project.Current.SelectedItems.Count > 0)
        if (MapFactory.Instance.CanCreateMapFrom(Project.Current.SelectedItems[0]))
          map = MapFactory.Instance.CreateMapFromItem(Project.Current.SelectedItems[0]);
    Requirements
