ArcGIS.Desktop.Mapping Namespace / StandaloneTable Class
    StandaloneTable Class Properties
    For a list of all members of this type, see StandaloneTable members.
    Public Properties
     NameDescription
    Public Property Gets the active definition query.
    Public Property Gets a value indicating whether the MapMember's pop-ups can be configured. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Property Gets a value indicating the MapMember's connection status. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Property Gets a list of all DefinitionQueries.
    Public Property Gets the where clause of the active definition query.
    Public Property Gets the display expression info.
    Public Property Gets the name of the attribute field that is used to identify each row or feature.
    Public Property Gets whether the StandaloneTable has any joins
    Public Property Gets whether the StandaloneTable has any relates
    Public Property Gets whether the standalone table is editable.
    Public Property Gets whether a MapMember is selectable.
    Public Property Gets whether the standalone table is set to automatically select related data.
    Public PropertyGets whether the standalone table is a member of SubtypeGroupTable.
    Public Property Get the map which the MapMember belongs to. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Property Gets the display name of the MapMember. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Property Gets the parent of the StandaloneTable. It is either the group layer it belongs to, or the map for tables that do not belong in any group layers.
    Public Property Gets the number of rows selected in the standalone table. This method must be called on the MCT. Use QueuedTask.Run.
    Public Property Gets a value indicating whether the MapMember is configured to show pop-ups when a feature is clicked. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Property Gets the subtype value that is used in the standalone table definition.
    Public Property Gets whether the MapMember supports metadata (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Property Gets the unique path of this MapMember. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Top
