ArcGIS.Core.CIM Namespace / CIMExternalTableView Class
Properties Methods Events
    CIMExternalTableView Class Members
    The following tables list the members exposed by CIMExternalTableView.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether other contingent value fields should be automatically populated after a value is changed when only one match is valid. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Public Property Gets or sets a value indicating the height for the column header row in the table. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Public Property Gets or sets the data connection for the table view's table.
    Public Property Gets or sets a value indicating whether to display subtype and domain descriptions. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Public Property Gets or sets the extent of the table view. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Public Property Gets or sets the field order as a string of field names. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Public Property Gets or sets a property set of field width information. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Public Property Gets or sets the count of frozen fields. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Public Property Gets or sets a value indicating whether invalid contingent value fields should be highlighted in the table. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Public Property Gets or sets a value indicating whether to honor ranges on the table view. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Public Property Gets or sets a value indicating whether to honor time on the table view. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Public Property Gets or sets the instance identifier of this view. (Inherited from ArcGIS.Core.CIM.CIMView)
    Public Property Gets or sets a value indicating whether to qualify field names when the table contains fields from a join. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Public Property Gets or sets the ranges of the table view. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Public Property Gets or sets a value indicating the height for the rows in the table. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Public Property Gets or sets a value indicating whether to view the table in selection mode. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Public Property Gets or sets a value indicating whether the table field visibility settings should be overridden to only show fields that are part of one or more contingent value field groups. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Public Property Gets or sets a property set containing sort information. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Public Property Gets or sets the current time of the table view. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Public Property Gets or sets a time relation which allows the start and end times to be included or excluded in the time query. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Public Property Gets or sets the path of the item in the view. (Inherited from ArcGIS.Core.CIM.CIMView)
    Public Property Gets or sets the view type as a string. (Inherited from ArcGIS.Core.CIM.CIMView)
    Public Property Gets or sets the zoom level of the table view. (Inherited from ArcGIS.Core.CIM.CIMTableView)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMExternalTableView.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMExternalTableView with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMExternalTableView and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
