ArcGIS.Desktop.Mapping Namespace / TimeTrack Class / CreateKeyframe Method
The value of the current time.
The time at which to insert the keyframe in the track.
The transition for start and end time of the time range. In the UI the default is ArcGIS.Core.CIM.AnimationTransition.Linear.
Example
    CreateKeyframe Method (TimeTrack)
    Create a new keyframe.
    Syntax
    Public Function CreateKeyframe( _
       ByVal time As TimeRange, _
       ByVal atTime As TimeSpan, _
       ByVal transition As AnimationTransition _
    ) As Keyframe
    Parameters
    time
    atTime
    transition
    Remarks
    If a keyframe already exists at that time it will be overwritten. The time is rounded to the nearest millisecond. When you create a keyframe the specified transition will be used for the start and end time of the time range. It is possible to change the transitions for the start or end time by settting the transition on the keyframe./>
    Example
    Create Time Keyframe
      var animation = mapView.Map.Animation;
      var timeTrack = animation.Tracks.OfType<TimeTrack>().First(); //There will always be only 1 TimeTrack in the animation.
      timeTrack.CreateKeyframe(mapView.Time, atTime, AnimationTransition.Linear);
    Requirements
